I've been trying to add more NMEA sentences stored as data tables to the program for my GPS project, but am getting strange results. I can only describe the problem - don't really want to post my full code as it's a bit messy at the moment and you will all laugh
Right, so previously I had the following two sentences stored: Code:
gpgga addwf PCL, F DT "$PSRF103,00,01,00,00", 0 gpvtg addwf PCL, F DT "$PSRF103,05,01,00,00", 0 This is the loop i'm using to send each character: Code:
messgga
clrf loop
msgloop movf loop,W
call gpgga
addlw 0
btfsc STATUS,Z
goto msgdone
call send
incf loop,F
goto msgloop
msgdone
movlw 0x0D ; CR
call send
movlw 0x0A ; LF
call send
return
LCDGallery |
It sounds like your table is crossing a 256 byte boundary?, a BIG problem if you don't know about it - assuming your tables aren't too large?, easiest solution is to move them to the start of memory (ensure you have a 'goto' to jump past them though). Next easiest, is to move them to their own 256 byte boundary, but you have to set bit's correctly before you call the table. The more complicated option is to write the table routine so it automatically compensates for the boundary - and code for this has been posted here many times.
You legend Nigel! Put my tables at the beginning of memory and it works fine.
I can't believe in all the work i've done with PICs before that i've never even heard about this boundary limitation. I now understand why there is such a limitation though, but never found it mentioned in any of the tutorials I started with years ago - granted i've not fully been through yours so it might be in there. Thanks
LCDGallery |
May I suggest an alternative that allows in-line code strings which can be longer than 256 bytes and can straddle 256 byte boundaries (by correctly manipulating PCLATH along with PCL)?
Regards, Mike Code:
; example usage of the _Print macro in your program
_Print "$PSRF103,00,01,00,00\r\n"
_Print "$PSRF103,05,01,00,00\r\n"
; _Print macro - print a string to the RS-232 port
_Print macro str ;
local String, Print
movlw low String ;
movwf PTRL ;
movlw high String ;
movwf PTRH ;
goto Print ;
String dt str,0
Print call PutString ; print string
endm
; PutStr - setup PTRL and PTRH to string address before entry
; - string must be terminated with a 00 byte
PutString
call GetTable ; get a table character |B0
andlw b'11111111' ; |B0
btfsc STATUS,Z ; a 00 byte, last character? |B0
return ; yes, return |B0
call Put232 ; output char |B0
incfsz PTRL,F ; increment pointer |B0
goto PutString ; |B0
incf PTRH,F ; |B0
GetTable
movf PTRH,W ; |B0
movwf PCLATH ; |B0
movf PTRL,W ; |B0
movwf PCL ; |B0
You're very welcome Nigel. And for PIC18 (16-bit instruction core), there's another very tight and clean method I like that uses the return address from the stack and TBLPTR registers.
A nice feature on the PIC18's is that two ASCII characters are stored in each 'word' of memory in the DB tables. Regards, Mike Code:
; macro usage examples
_Print "K8LH Az/El Controller 1.041123\n\n\r"
_Print "Satellite AOS:\n\r"
_Print "Satellite LOS:\n\r"
; _Print macro
_Print MACRO str ; print in-line string macro
call PutString ;
db str,0
ENDM
; PutString - print in-line string via Stack and TBLPTR
; string must be terminated with a 00 byte and does not need
; to be word aligned
PutString
movff TOSH,TBLPTRH ; copy return address to TBLPTR
movff TOSL,TBLPTRL ;
clrf TBLPTRU ; assume PIC with < 64-KB
PutNext
tblrd *+ ; get in-line string character
movf TABLAT,W ; last character (00)?
bz PutExit ; yes, exit, else
rcall Put232 ; print character
bra PutNext ; and do another
PutExit
btfsc TBLPTRL,0 ; odd address?
tblrd *+ ; yes, make it even (fix PC)
movf TBLPTRH,W ; setup new return address
movwf TOSH ;
movf TBLPTRL,W ;
movwf TOSL ;
return ;
