+ Reply to Thread
Results 1 to 2 of 2
Thread: PIC 18F4431 Power PWM , i am lost!
  1. #1
    max_imum2000 Bad
    Join Date
    Mar 2006
    Posts
    83
    Default PIC 18F4431 Power PWM , i am lost!
    i am playing around with these 40pin pics .
    i am trying to control three 12v DC motors (not steppers , not servo) over h-bridge, with no feedback.
    the 18F4431 has power pwm module that comes build in to provide up to 8 channels in complemntry mode
    however i read the datasheet on the power pwm module and cant understand how to work with this module easly.
    i downloaded several application notes, but most of them are reffering to ccp pwm .
    i will appricate any help or any step by step instruction on how to do that
    thank you
  2. #2
    motion Newbie
    Join Date
    Jul 2003
    Location
    Quezon City.PH
    Posts
    560
    Here is a code snippet to initialize the PWM module. It is not yet been tested since I had set that project aside for now. I hope it helps you get started.
    You define the value of PTPER_VAL to set the PWM frequency. See table 17-2 of the PIC18F4431 datasheet for the suggested values.
    ;   Init PWM module
             MOVLW    1<<PTMOD1       ; 1:1 prescale,1:1 postscale, up/down
             MOVWF    PTCON0
             MOVLW    1<<PWMEN2|1<<PWMEN1|1<<PMOD1|1<<PMOD0
             MOVWF    PWMCON0
             MOVLW    0               ; 1:1 Postscale
             MOVWF    PWMCON1
             MOVLW    LOW  PTPER_VAL
             MOVWF    PTPERL
             MOVLW    HIGH PTPER_VAL
             MOVWF    PTPERH
             CLRF     DTCON
             BSF      PTCON1,PTEN     ; Fire up the PWM module
    "Having to do with Motion Control"
+ Reply to Thread
Tags for this Thread
