Old 29th March 2006, 04:09 PM   #1
Default Need some help with a code provided by ATMEL
Hello,
After long days and nights of work, i finally found a code that worked on a 89c2051 chip, to be able to interface a 24CXX eeprom.
now i made modification to output the AKNOLEDGE on a pin of the uC, to chack and see if everything i working properly, and everything seems ok. the only problem is: i was not able to output a byte of data on port 3.. just for testing, can anybody help me on that, i'll provide you with the original code i got from atmel website, and plese can anybody do the required changes to output a byte of data to port 3 (any byte, this is just for testing)
you will notice that this sample code of atmel, writes the same byte alloevr all the bytes of the eeprom.
here is the code:
NAME Control_AT24Cxx
; This collection of routines allows an AT89C2051 microcontroller to read
; and write the AT24Cxx family of serial CMOS EEPROMS. This version of the
; code is compatible only with the AT89C2051 due to the location of the
; data buffer and stack in RAM. The code may be modified to work with the
; AT89C1051 by relocating or resizing the buffer and stack to fit into the
; smaller amount of RAM available in the AT89C1051. Note that the minimum
; size of the buffer is determined by the page size of the AT24Cxx.
; All five AT24Cxx device operations are supported. Byte Write, Current
; Address Read and Random Read are implemented by the functions WRITE_BYTE,
; READ_CURRENT and READ_RANDOM, respectively. Page Write and Sequential Read
; are special cases of functions WRITE_BLOCK and READ_BLOCK, respectively.
; WRITE_BLOCK and READ_BLOCK process from one byte to the number of bytes
; in a page and transfer data between the AT24Cxx and the RAM buffer.
; The code supports multiple AT24Cxx devices per bus, each with a unique
; address determined by the wiring of the address pins (A0, A1, A2). The
; three-bit programmable address is passed to the WRITE_BYTE, READ_CURRENT,
; READ_RANDOM, WRITE_BLOCK and READ_BLOCK functions, where it is combined
; with the AT24Cxx fixed address (FADDR) and used to address a device on the
; bus. Refer to the AT24Cxx family data sheets for additional information on
; device addressing.
; Functions BYTE_FILL, VERIFY_BYTE_FILL, PAGE_FILL and VERIFY_PAGE_FILL are
; artifacts from the debug process and serve to illustrate the use of the
; device read and write functions with an AT24C64. To modify the code for a
; different member of the AT24Cxx family, simply redefine the values of SIZE
; (the number of bytes per device) and PSIZE (the number of bytes per page).
; To change the fill value, redefine FILL. To change the programmable portion
; of the device address, redefine PADDR to a value from zero to seven.
; The code meets all AT24Cxx family timing requirements when executed by an
; AT89Cx051 microcontroller with a 12 MHz clock. Code modifications may be
; required if a faster clock is substituted.
FADDR EQU 0a0h ; fixed address for AT24Cxx EEPROMs
PADDR EQU 0 ; programmable address (0..7)
SIZE EQU 2000h ; bytes per AT24C64
PSIZE EQU 32 ; bytes per page for AT24C64
FILL EQU 55h ; example fill value
; Register definitions.
index EQU r0 ; buffer pointer
kount EQU r1 ; byte count register
zdata EQU r1 ; data register
addr_lo EQU r2 ; 2-byte address register
addr_hi EQU r3 ;
; Microcontroller connections to AT24Cxx serial bus lines.
SCL BIT p1.2 ; serial clock
SDA BIT p1.3 ; serial data
DSEG AT 20H
ORG 40H
buffer: DS PSIZE ; storage for read/write data
ORG 60H ; stack origin
stack: DS 20H ; stack depth
CSEG
ORG 0000H ; power on/reset vector
jmp on_reset
ORG 0003H ; external interrupt 0 vector
reti ; undefined
ORG 000BH ; timer 0 overflow vector
reti ; undefined
ORG 0013H ; external interrupt 1 vector
reti ; undefined
ORG 001BH ; timer 1 overflow vector
reti ; undefined
ORG 0023H ; serial I/O interrupt vector
reti ; undefined
ORG 0080H ; begin code space
USING 0 ; register bank zero
on_reset:
mov sp, #(stack-1) ; initialize stack pointer
; Initialize AT24Cxx serial bus lines.
setb SDA ; high
setb SCL ; high
call byte_fill
jc fault
call verify_byte_fill
jc fault
call page_fill
jc fault
call verify_page_fill
jc fault
fault:
jmp $
byte_fill:
; Fill every byte in an AT24Cxx with the same value.
; Writes one address at a time (page mode is not used).
; Returns CY set to indicate write timeout.
; Destroys A, B, DPTR, XDATA, ADDR_HI:ADDR_LO.
mov zdata, #FILL ; set up fill data
mov dptr, #0 ; initialize address pointer
x51:
mov addr_lo, dpl ; set up address
mov addr_hi, dph ;
mov b, #120 ; retry counter
x52:
mov a, #PADDR ; programmable address
call write_byte ; try to write
jnc x53 ; jump if write OK
djnz b, x52 ; try again
setb c ; set timeout error flag
jmp x54 ; exit
x53:
inc dptr ; advance address pointer
; mov a, dpl ; check low byte
; cjne a, #(LOW SIZE), x51 ; jump if not last
mov a, dph ; check high byte
cjne a, #(HIGH SIZE), x51 ; jump if not last
clr c ; clear error flag
x54:
ret
verify_byte_fill:
; Verify that all bytes in an AT24Cxx match a fill value.
; Reads and verifies one byte at a time (page mode is not used).
; Performs a Random Read function to initialize the internal
; address counter and checks the contents of the first address.
; Then performs multiple Current Address Read functions to step
; through the remaining addressess.
; Returns CY set to indicate read timeout or compare fail.
; Destroys A, B, DPTR.
mov dptr, #0 ; initialize address pointer/counter
mov addr_hi, dph ;
x81:
call read_random ; try to read
jnc x82 ; jump if read OK
djnz b, x81 ; try again
jmp x86 ; set error flag and exit
x82:
cjne a, #FILL, x86 ; jump if compare error
jmp x85 ; do remaining addresses
x83:
mov a, #PADDR
call read_current
jc x87 ; jump if read fails
x85:
cjne a, #(HIGH SIZE), x83 ; jump if not last
jmp x87 ; exit
x86:
setb c ; set error flag
x87:
ret
page_fill:
; Writes one page at a time.
; Destroys A, B, DPTR, KOUNT, INDEX, ADDR_HI:ADDR_LO.
; First fill buffer.
mov b, #PSIZE ; bytes per page
mov index, #buffer ; point to buffer
x61:
mov @index, #FILL ; put fill value in buffer
inc index ; advance pointer
djnz b, x61 ; next byte
; Copy buffer to device, one page at a time.
x62:
mov addr_hi, dph ;
mov kount, #PSIZE ; bytes per page
x63:
call write_block ; try to write
jnc x64 ; jump if write OK
djnz b, x63 ; try again
jmp x66 ; exit
x64:
; Add page size to address pointer.
mov a, dpl ; get low byte
add a, #PSIZE ; add page size
mov dpl, a ; save low byte
jnc x65 ; jump if high byte not affected
inc dph ; increment high byte
x65:
; cjne a, #(LOW SIZE), x62 ; jump if low byte not last
cjne a, #(HIGH SIZE), x62 ; jump if not last
x66:
ret
verify_page_fill:
; Reads and verifies one page at a time.
; Copy device page to buffer.
x71:
mov addr_hi, dph ;
x72:
call read_block ; try to read
jnc x74 ; jump if read OK
djnz b, x72 ; try again
x73:
jmp x77 ; exit
x74:
; Verify buffer contents.
x75:
cjne @index, #FILL, x73 ; jump if compare fails
djnz b, x75 ; next byte
jnc x76 ; jump if high byte not affected
x76:
; cjne a, #(LOW SIZE), x71 ; jump if low byte not last
cjne a, #(HIGH SIZE), x71 ; jump if not last
x77:
ret
write_block:
; Write from one byte to one page of data to an AT24Cxx.
; Called with programmable address in A, address of first byte
; in register pair ADDR_HI:ADDR_LO, data in BUFFER, byte count
; in register KOUNT.
; Does not wait for write cycle to complete.
; Returns CY set to indicate that the bus is not available
; or that the addressed device failed to acknowledge.
; Destroys A, KOUNT, INDEX.
call start
jc x38 ; abort if bus not available
rl a ; programmable address to bits 3:1
orl a, #FADDR ; add fixed address
clr acc.0 ; specify write operation
call shout ; send device address
jc x37 ; abort if no acknowledge
mov a, addr_hi ; send high byte of address
call shout ;
mov a, addr_lo ; send low byte of address
call shout ;
x36:
mov a, @index ; get data
call shout ; send data
inc index ; advance buffer pointer
djnz kount, x36 ; next byte
x37:
call stop
x38:
ret
read_block:
; Read from one byte to one page of data from an AT24Cxx.
; Performs a Random Read which is extended into a Sequential Read
; when more than one byte is read. Called with programmable address
; in A, address of first byte in register pair ADDR_HI:ADDR_LO,
; byte count in register KOUNT.
; Returns data in BUFFER. Returns CY set to indicate that the bus is
; not available or that the addressed device failed to acknowledge.
; Send dummy write command to address first byte.
call start
jc x35 ; abort if bus not available
mov index, a ; save copy of device address
jc x34 ; abort if no acknowledge
call shout ;
call shout ;
; Send read command and receive data.
call start ; second start for read
jc x34 ; abort if bus not available
mov a, index ; get device address
setb acc.0 ; specify read operation
x31:
call shin ; receive data byte
mov @index, a ; save data
cjne kount, #1, x32 ; jump if not last byte
call NAK ; do not acknowledge last byte
jmp x33 ; done
x32:
call ACK ; acknowledge byte
djnz kount, x31 ; next byte
x33:
x34:
call stop
x35:
ret
write_byte:
; AT24Cxx Byte Write function.
; Called with programmable address in A, byte address in
; register pair ADDR_HI:ADDR_LO, data in register XDATA.
; Destroys A.
call start
jc x49 ; abort if bus not available
jc x48 ; abort if no acknowledge
call shout ;
call shout ;
mov a, zdata ; get data
x48:
call stop
x49:
ret
read_current:
; AT24Cxx Current Address Read function.
; Called with programmable address in A. Returns data in A.
call start
jc x45 ; abort if bus not available
jc x44 ; abort if no acknowledge
call NAK ; do not acknowledge byte
x44:
call stop
x45:
ret
read_random:
; AT24Cxx Random Read function.
; register pair ADDR_HI:ADDR_LO. Returns data in A.
push b
mov b, a ; save copy of programmable address
; Send dummy write command to set internal address.
call start
jc x47 ; abort if bus not available
jc x46 ; abort if no acknowledge
call shout ;
call shout ;
; Call Current Address Read function.
mov a, b ; get programmable address
call read_current
jmp x47 ; exit
x46:
call stop
x47:
pop b
ret
start:
; Send START, defined as high-to-low SDA with SCL high.
; Return with SCL, SDA low.
; Returns CY set if bus is not available.
setb SDA
setb SCL
; Verify bus available.
jnb SDA, x40 ; jump if not high
jnb SCL, x40 ; jump if not high
nop ; enforce setup delay and cycle delay
clr SDA
nop ; enforce hold delay
nop ;
nop ;
nop ;
nop ;
clr SCL
jmp x41
x40:
x41:
ret
stop:
; Send STOP, defined as low-to-high SDA with SCL high.
; SCL expected low on entry. Return with SCL, SDA high.
clr SDA
nop ; enforce SCL low and data setup
nop
setb SCL
nop ;
nop ;
nop ;
nop ;
setb SDA
ret
shout:
; Shift out a byte to the AT24Cxx, most significant bit first.
; SCL, SDA expected low on entry. Return with SCL low.
; Called with data to send in A.
; Returns CY set to indicate failure by slave to acknowledge.
; Destroys A.
push b
mov b, #8 ; bit counter
x42:
rlc a ; move bit into CY
mov SDA, c ; output bit
setb SCL ; raise clock
nop ; enforce SCL high
nop ;
nop ;
nop ;
clr SCL ; drop clock
djnz b, x42 ; next bit
setb SDA ; release SDA for ACK
nop ; enforce SCL low and tAA
nop ;
setb SCL ; raise ACK clock
nop ;
nop ;
nop ;
mov c, SDA ; get ACK bit
clr SCL ; drop ACK clock
pop b
ret
shin:
; Shift in a byte from the AT24Cxx, most significant bit first.
; SCL expected low on entry. Return with SCL low.
; Returns received data byte in A.
setb SDA ; make SDA an input
push b
x43:
nop ;
nop ;
nop ;
mov c, SDA ; input bit
rlc a ; move bit into byte
djnz b, x43 ; next bit
pop b
ret
ACK:
; Clock out an acknowledge bit (low).
; SCL expected low on entry. Return with SCL, SDA low.
clr SDA ; ACK bit
nop ;
nop ;
nop ;
nop ;
ret
NAK:
; Clock out a negative acknowledge bit (high).
; SCL expected low on entry. Return with SCL low, SDA high.
setb SDA ; NAK bit
nop ;
nop ;
nop ;
nop ;
ret
END
THanks a lot.
Ika.
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 23rd January 2007, 03:46 PM   #2
Default Atmel AT24Cxx
Here is my code that worked.
I had to toggle the SDA and SCL lines in START because the original code from Atmel does notn wait for the Bus to be available thereby giving error.
Pay attention to the following. AT24C01 and AT24C02 use 7-bit WORD ADDRESS so you do not need addr_hi.
Hope this will help.
zdata EQU 00H ; data register
addr_lo EQU 00H ; 2-byte address register
addr_hi EQU 00H ;
SCL BIT p3.4 ; serial clock
SDA BIT p3.5 ; serial data
Ajmp on_reset
on_reset:
setb SDA ; high
setb SCL ; high
; Write to the EEPROM
MOV addr_lo,#00H
MOV zdata,#01H
acall write_byte
ACALL DELAY_STOP
clr P3.7
MOV zdata,#02H
acall write_byte_nstop
ACALL DELAY_STOP
SETB P3.7
mov zdata,#03H
ACALL DELAY_STOP
CLR P3.7
ACALL stop
; Now Read the EEPROM
EE_READ: MOV addr_lo,#00H
acall read_random
MOV NO_1,A
setb P3.7
MOV addr_lo,#01H
acall read_random
MOV NO_2,A
mov addr_lo,#02H
acall read_random
MOV NO_3,A
LOOP:
AJMP LOOP ; Loop here forever. Of course you can puit in here your own code
; to make use of the Read/Write functions
write_byte_nstop:
; Destroys A.
mov a,zdata ; get data
acall shout ; send data
;clr P3.7
ret
write_byte:
; Destroys A.
acall start
orl a,#FADDR ; add fixed address
acall shout ; send device address
/*mov a,addr_hi ; send high byte of address
call shout ;
jc x48 ; abort if no acknowledge */
mov a,addr_lo ; send low byte of address
acall shout ;
;clr P3.7
x48:
;acall stop
x49:
ret
read_current:
call start
; mov a,#PADDR
x44:
call stop
x45:
ret
read_random:
MOV a,#PADDR
push b
call start
;clr p1.2
call shout ;
jc x46 ; abort if no acknowledge */
call shout ;
mov a,b ; get programmable address
call read_current
jmp x47 ; exit
x46:
call stop
x47:
pop b
ret
start:
YY: setb SDA ; TOGGLE HERE TO WAIT FOR THE LINES.
setb SCL
jnb SDA,YY
jnb SDA,x40 ; jump if not high
jnb SCL,x40 ; jump if not high
clr SDA
nop ;
nop ;
nop ;
nop ;
clr SCL
jmp x41
x40:
x41:
ret
stop:
clr SDA
nop
setb SCL
nop ;
nop ;
nop ;
nop ;
setb SDA
ret
shout:
; Destroys A.
push b
mov b,#8 ; bit counter
x42:
mov SDA,c ; output bit
nop ;
nop ;
nop ;
djnz b,x42 ; next bit
XX: MOV C,SDA
nop ;
JC XX
nop ;
nop ;
nop ;
mov c,SDA ; get ACK bit
pop b
ret
shin:
push b
x43:
nop ;
nop ;
nop ;
mov c,SDA ; input bit
djnz b,x43 ; next bit
pop b
ret
ACK:
clr SDA ; ACK bit
nop ;
nop ;
nop ;
nop ;
ret
NAK:
setb SDA ; NAK bit
nop ;
nop ;
nop ;
nop ;
ret
DELAY_STOP:
Init_timer0:
Clr TF0
Mov TMOD,#01h ;clear Timer 0
Mov TL0,#00h ;value set by user
Mov TH0,#0DCh ;value set by user
Mov IE,#082h
Setb TR0 ;TCON.4 start timer
X_100ms:
MOV R0,MILISEC
CJNE R0,#064H,X_100ms
MOV MILISEC,#00H
CLR TR0
CLR TF0
RET
END
oyeyele is offline
atmel, code, provided
