concerning this code,
LCD_Busy bsf STATUS, RP0 ;set bank 1 movlw 0x0f ;set Port for input movwf LCD_TRIS bcf STATUS, RP0 ;set bank 0 bcf LCD_PORT, LCD_RS ;set LCD for command mode bsf LCD_PORT, LCD_RW ;setup to read busy flag bsf LCD_PORT, LCD_E swapf LCD_PORT, w ;read upper nibble (busy flag) bcf LCD_PORT, LCD_E movwf templcd2 bsf LCD_PORT, LCD_E ;dummy read of lower nibble bcf LCD_PORT, LCD_E btfsc templcd2, 7 ;check busy flag, high = busy goto LCD_Busy ;if busy check again bcf LCD_PORT, LCD_RW bsf STATUS, RP0 ;set bank 1 movlw 0x00 ;set Port for output movwf LCD_TRIS bcf STATUS, RP0 ;set bank 0 return 1. why is rs set to command mode? 2.How come it is not set back to symbol mode 3. Why did you swop the intput of lcd port, i changed the code so that it just read bit 3, and it still seems to work, was there any other reason for the swop command Code:
LCD_Busy bsf STATUS, RP0 ;set bank 1 movlw 0x0f ;set Port for input movwf LCD_TRIS bcf STATUS, RP0 ;set bank 0 bcf LCD_PORT, LCD_RS ;set LCD for command mode bsf LCD_PORT, LCD_RW ;setup to read busy flag bsf LCD_PORT, LCD_E movf LCD_PORT, w ;read upper nibble (busy flag) bcf LCD_PORT, LCD_E movwf templcd2 bsf LCD_PORT, LCD_E ;dummy read of lower nibble bcf LCD_PORT, LCD_E btfsc templcd2, 3 ;check busy flag, high = busy goto LCD_Busy ;if busy check again bcf LCD_PORT, LCD_RW bsf STATUS, RP0 ;set bank 1 movlw 0x00 ;set Port for output movwf LCD_TRIS bcf STATUS, RP0 ;set bank 0 return |
As it's four bit mode you need two reads to get the 8 bits (although one is a dummy, as it doesn't contain the bit you're checking), so you would normally use 'swapf' for one of the reads - I saw no reason to change it?.
As for command mode, presumably it's required to be in that mode?, it's been many years since I read the datasheet and wrote those routines. In any case, they work great - and "if it's not broke, don't try and fix it" :lol: |
As soon as an LCD is turned on, the first line or at least the first 1/2 line will consist of black blocks.
What you need to do is set LCD to command mode, and inject the code into the LCD's data pins so that it is setup properly, and there is a code that turns on the display. Check the HD47780 LCD command set for details. Once you done eveything right, the bars should disappear. At this point, go to symbol mode and your characters can now be sent.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
