Hello, Im sure as a new member there is a protocol im not following, I have read the sticky FAQ and a large number of posts about people fantastic projects. Which makes it all the much more pathetic that i cant get my simple atempt to work. The code should be a simple counter - the units and tens being desplayed on 1 LED each - tens are represented by blue LED's and units by white. The only problem is it dosent work at all... hmm Could someone possibly have a look at the code bellow and give me some pointers - both on getting it to work & on any style or best practice tips Thanks very much Piers ************************************************** *********** ; HEADER628C.ASM for 16F628. Using internal 37kHz RC ; PortA bits 0 to 7 are inputs ; PortsB bits 0 to 7 are outputs ; Prescaler /32 ;************************************************* ********************************** ; EQUATES SECTION TMR0 EQU 1 ;means TMR0 is file 1. OPTION_R EQU 1 ;the OPTION register is file 1 PORTA EQU 5 ;means PORTA is file 5. PORTB EQU 6 ;means PORTB is file 6. TRISA EQU 5 ;TRISA (the PORTA I/O selection) is file 5 TRISB EQU 6 ;TRISB (the PORTB I/O selection) is file 86H STATUS EQU 3 ;means STATUS is file 3. ZEROBIT EQU 2 ;means ZEROBIT is bit 2. CARRY EQU 0 EEADR EQU 1BH EEDATA EQU 1AH EECON1 EQU 1CH EECON2 EQU 1DH RD EQU 0 WR EQU 1 WREN EQU 2 PCON EQU 0EH COUNT EQU 20H ;COUNT is file 20H, a register to count events. PC EQU 2 TIMEU EQU 21H TIMET EQU 22H TIMEPA EQU 23H TIMEPB EQU 24H TEMP EQU 25H TIMETEMP EQU 26H ;************************************************* ******** LIST P=16F628 ; we are using the 16F628. ORG 0 ;the start address in memory is 0 GOTO START ; goto start! ;************************************************* ******** ;SUBROUTINE SECTION. ;1 second delay. DELAY1 MOVLW 10 MOVWF COUNT LOOPB CALL DELAYP1 DECFSZ COUNT GOTO LOOPB RETLW 0 ; 0.1 second delay. DELAYP1 CLRF TMR0 LOOPA MOVF TMR0,W SUBLW .29 BTFSS STATUS,ZEROBIT GOTO LOOPA RETLW 0 ;UNITS SUB UNITS INCF TIMEU MOVF TIMEU,W SUBLW .10 BTFSC STATUS,ZEROBIT CALL TENS ;CALL TENS SUB IF TIMEU = 10 RETLW 0 ;TENS SUB TENS INCF TIMET MOVF TIMET,W SUBLW .6 BTFSC STATUS,ZEROBIT CLRF TIMET ;CLEAR TIMET IF IS 6 CLRF TIMEU RETLW 0 UNITTABLE ADDWF PC RETLW B'00000000' ;0 RETLW B'00000001' ;1 RETLW B'00001001' ;2 RETLW B'00001011' ;3 RETLW B'01001011' ;4 RETLW B'01001111' ;5 RETLW B'01011111' ;6 RETLW B'11011111' ;7 RETLW B'11111111' ;8 MOVLW B'00000001' ;9 SET PORTA MOVWF TIMEPA RETLW B'11111111' ;TENS DISPLAY TABLE TENSTABLE ADDWF PC RETLW B'00000000' ;0 RETLW B'00000010' ;1 RETLW B'00000110' ;2 RETLW B'01000110' ;3 RETLW B'01001110' ;4 RETLW B'11001110' ;5 ;CONVERT UNITS TO DISPLAY CONVUNITS CLRF TIMEPA MOVF TIMEU,W CALL UNITTABLE MOVWF TIMEPB RETLW 0 ;CONVERT TENS TO DISPLAY CONVTENS MOVF TIMET,W CALL TENSTABLE IORWF TIMEPA RETLW 0 ;DISPLAY DISPLAY MOVF TIMEPB,W MOVWF PORTB MOVF TIMEPA,W MOVWF PORTA RETLW 0 ;************************************************* ******** ;CONFIGURATION SECTION START BSF STATUS,5 ;Turns to Bank1. MOVLW B'00000000' ;PORTA are OUTPUT MOVWF TRISA MOVLW B'00000000' ;ddd MOVWF TRISB ;PORTB is OUTPUT MOVLW B'00000100' ;Prescaler is /32 MOVWF OPTION_R ;TIMER is 1/32 secs. CLRF PCON BCF STATUS,5 ;Return to Bank0. CLRF PORTA ;Clears PortA. CLRF PORTB ;Clears PortB. MOVLW 7 MOVWF 1FH ;************************************************* ******** ;Program starts now. BEGIN CLRF TEMP TEST CALL UNITS CALL CONVUNITS CALL CONVTENS CALL DISPLAY CALL DELAY1 GOTO TEST END ;END | |
The first thing that stands out is the lack of a CONFIG instruction. A config line that should work is Code: __config 0x3d10 The other thing you should do is to include the definition file. This will define all the special function registers like TMR0. At the top of your code you should have:- Code: processor 16f628
#define __16f628
include "p16f628.inc"
Mike. edit - typo. | |
| | #3 | |
1. In pasting code to the forum, you can surround your code using the pair of "[ code ]" attribute and the code will then appear just as they do in your editor for easy viewing. 2. You said the program did not work. What did it show? All LEDs off, some on some off or changing randomly. All these are pointers to debugging. 3. When the program does not work, do it in steps. Do not debug the whole program. First try to light half of the LEDs on a port to see whether you can do just that, follows with the GOTO instruction to loop forever. Gradually adding other parts to your program bit by bit to build it up.
__________________ L.Chung | ||
| | #4 | |
In your particular case I would suggest doing the 'display' section first, use a simple incrementing counter to feed it varying values. | ||
| hep, request |
