whats wrong in my code because all pins showing pulse at same time meance there is no phase shift even if i 've given that much delay and toggle next pin after that where i'm doing wrong pls tell me
#include "p18f458.inc"
;------------------BIT DEFINITIONS------------------------------------
F EQU 0x0001
;COUNT1 EQU 200
;COUNT2 EQU 0x0003
;COUNT3 EQU 0x0004
red equ B'10101010'
green equ B'01010101'
var UDATA
COUNT1 res 1
COUNT2 res 1
COUNT3 res 1
COUNT4 res 1
temp_1 res 1
temp_2 res 1
temp_3 res 1
;------------------VECTORS--------------------------------------------
org 0x000000 ; reset vector
bra START
org 0x000008 ; high priority interrupt vector
bra TMR3_ISR
org 0x000070
;--------------------PROGRAM-----------------------------------
START
clrf LATD
rcall INIT
;Set up priority interrupts.
bsf RCON,IPEN ;enable priority interrupts.
bsf IPR2,TMR3IP ;set Timer3 as a low priority interrupt source
bcf PIR2,TMR3IF ;clear the Timer3 interrupt flag
bsf PIE2,TMR3IE ;enable Timer3 interrupts
bsf INTCON,GIEH ;set the global interrupt enable bits
bsf INTCON,GIEL ; "
MOVLW 0X02
MOVWF temp_1
clrf T3CON
bsf T3CON,TMR3ON ;turn on Timer3
movlw 0xd0
movwf TMR3H ;write 0xf000 to Timer3
clrf TMR3L
movlw 0x01
movwf COUNT4
MLOOP
goto MLOOP
;-------------------------------SUBROUTINES---------------------------------
TMR3_ISR ;low priority isr
CPFSEQ COUNT4
LP1 goto lpl
LP2
BTG LATD,7
BTG LATD,6
movlw 0x02
movwf COUNT1
movwf COUNT2
movlw 0x01
movwf COUNT3
bcf PIR1,TMR1IF ;Clear the Timer1 interrupt flag.
lppl
movlw 0xff
movwf TMR3H
movlw 0xfe
movwf TMR3L
T1POLLl
btfss PIR2,TMR3IF ;Poll TMR11 interrupt flag to wait for another
; TMR1 overflow.
bra T1POLLl
movlw 0xff
movwf TMR3H
movlw 0xfe
movwf TMR3L
bcf PIR2,TMR3IF ;Clear the Timer1 interrupt flag again.
decfsz COUNT1,F
bra lppl
decfsz COUNT2,F
bra lppl
decfsz COUNT3,F
bra lppl
INCF COUNT4
MOVLW 0X02
CPFSEQ COUNT4
LPP1
goto lpl
LPP2
bcf PIR2,TMR3IF ;Clear the TMR3 interrupt flag.
movlw 0xd0
movwf TMR3H
movlw 0x00
movwf TMR3L
T1POLLl1
; TMR1 overflow.
bra T1POLLl1
DECF COUNT4
GOTO LP3
LP3
BTG LATD,5
BTG LATD,4
movlw 0xd0
MOVLW 0X01
clrf TMR3L
;GOTO LP2
lpl
retfie
INIT
movlw red
movwf LATD
clrf LATC ; setup portb for outputs
clrf TRISC
clrf TRISD
return
END
Now that you have presented code in the proper manner, could you give some more info? Which pins have to be 120 degrees delayed w.r.t each other? Try to give as much info as possible so we don't have waste time trying to decrypt your code.
Help us to help you.
"Having to do with Motion Control" |
sir, thanks for replying me actually i want a phase shift of 120degree in between PORTD7 and PORTD5 and again 120degree phase shift in between PORTD5,and PORTC7 these pins will be high first and at the same time PORTD6,PORTD,4 and PORTC,6 will be low having 120degree phase shift in between them this will be like this R=PORTD,7 ~R=PORTD,6 y=PORTD,5 ~Y=PORTD,4 B=PORTC,7 ~B=PORTC,6 WITH 120DEGREE PHASE SHIFT IN BETWEEN R-Y-B AND SAME FOR ~R-~Y-~B CAN I CALL A DELAY(FOR PHASE SHIFT) ROUTINE IN ISR ROUTINE AND AT THE SAME TIME I WANT A PULSE OF 50HZ ON EACH PIN I'M USING A CRYSTAL OF 4.9152MHZ FOR THAT DID I CALCULATED THE CORRECT VALUES AND IS IT NECESSORY TO LOAD 0X07 IN CMCON REGISTER TO INITIALIZE PORTD BECAUSE IF I GIVE LOW INPUT TO PINS PORTD,6,4 AND PORTC,6 THEN THESE PINS REMAINS LOW AT ALL TIME AND EVEN IF I TOGGLED THE PORTD,5 AND PORTC,7 PIN AFTER PHASE SHIFT DELAY THEN ALSO THESE PINS STARTS TOGGLING AT THE SAME TIME AS PORTD,7 PIN TOGGLES HWERE I'M DOING WRONG SIR |
I haven't had time to go through you code because frankly it looks like a mess! It looks like you have a delay loop within the ISR.
Anyway as suspected, you are trying to make a 3-phase inverter, possibly a motor inverter. The way I would approach is to use a lookup table to index through. During a periodic interrupt, you take the values from this lookup table, indexing one step at each interrupt, and output them at the corresponding pins. At the end of the table, you start from the beginning on the next interrupt. Since you want to output 50Hz square wave, you need to interrupt at 6X this rate or 300Hz. The table values will be as follows: Code:
retlw b'10010100' retlw b'10100100' retlw b'10101000' retlw b'01101000' retlw b'01011000' retlw b'01010100' HTH
hello sir,
i tried whatever you told me in prev reply and it was working but there was pulses only on portd 7 5 and portc,7 pins and there was more fluctuation in pulses thatswhy i again tried this code, this code is giving the results whatever i want but there is some dropping of pulse after each 3 or 4 second why this is hapning and is this correct code for interfacing 3-phase 50hz power supply (120degree phase shift ) with pic18f458 and how to remove that dropping fault thanks Code:
#include "p18f458.inc" ;------------------BIT DEFINITIONS------------------------------------ F EQU 0x0001 ;COUNT1 EQU 200 ;COUNT2 EQU 0x0003 ;COUNT3 EQU 0x0004 red equ B'10101010' green equ B'01010101' var UDATA COUNT1 res 1 COUNT2 res 1 COUNT3 res 1 COUNT4 res 1 temp_1 res 1 temp_2 res 1 temp_3 res 1 ;------------------VECTORS-------------------------------------------- org 0x000000 ; reset vector bra START org 0x000008 ; high priority interrupt vector bra TMR3_ISR org 0x000070 ;--------------------PROGRAM----------------------------------- START rcall INIT ;Set up priority interrupts. bsf RCON,IPEN ;enable priority interrupts. bsf IPR2,TMR3IP ;set Timer3 as a low priority interrupt source bcf PIR2,TMR3IF ;clear the Timer3 interrupt flag bsf PIE2,TMR3IE ;enable Timer3 interrupts bsf INTCON,GIEH ;set the global interrupt enable bits bsf INTCON,GIEL ; " MOVLW 0X02 MOVWF temp_1 clrf T3CON bsf T3CON,TMR3ON ;turn on Timer3 movlw 0xd0 movwf TMR3H ;write 0xf000 to Timer3 clrf TMR3L movlw 0x01 movwf COUNT4 MLOOP goto MLOOP ;-------------------------------SUBROUTINES--------------------------------- TMR3_ISR ;low priority isr CPFSEQ COUNT4 LP1 goto lpl LP2 BTG LATD,7 BTG LATD,6 rcall delay240 incf COUNT4 MOVLW 0X02 CPFSEQ COUNT4 LPP1 goto lpl LPP2 incf COUNT4 GOTO LP3 LP3 BTG LATD,5 BTG LATD,4 rcall delay120 movlw 0x03 cpfseq COUNT4 lp4 bra lpl lp5 btg LATC,7 btg LATC,6 decf COUNT4 decf COUNT4 lp6 movlw 0xd0 movwf TMR3H clrf TMR3L lpl retfie INIT clrf LATD movlw red movwf LATD clrf PORTC clrf TRISD clrf LATC ; setup portb for outputs clrf TRISC bsf LATC,7 bcf LATC,6 return delay240 timer3 delay for .763sec return delay120 timer3 delay for .381sec return END |
(permalink) | ||
hello sir,
here is the code which is giving me correct output only when i give support to ckt and i diasabled the watchdog timer also Code:
#include "p18f458.inc" ;------------------BIT DEFINITIONS------------------------------------ F EQU 0x0001 ;COUNT1 EQU 200 ;COUNT2 EQU 0x0003 ;COUNT3 EQU 0x0004 red equ B'10101010' green equ B'01010101' var UDATA COUNT1 res 1 COUNT2 res 1 COUNT3 res 1 COUNT4 res 1 temp_1 res 1 temp_2 res 1 temp_3 res 1 ;------------------VECTORS-------------------------------------------- org 0x000000 ; reset vector bra START org 0x000008 ; high priority interrupt vector bra TMR3_ISR org 0x000070 ;--------------------PROGRAM----------------------------------- START rcall INIT ;Set up priority interrupts. bsf RCON,IPEN ;enable priority interrupts. bsf IPR2,TMR3IP ;set Timer3 as a low priority interrupt source bcf PIR2,TMR3IF ;clear the Timer3 interrupt flag bsf PIE2,TMR3IE ;enable Timer3 interrupts bsf INTCON,GIEH ;set the global interrupt enable bits bsf INTCON,GIEL ; " clrf T3CON bsf T3CON,TMR3ON ;turn on Timer3 movlw 0xd0 movwf TMR3H ;write 0xf000 to Timer3 clrf TMR3L movlw 0x01 movwf COUNT4 MLOOP goto MLOOP ;-------------------------------SUBROUTINES--------------------------------- TMR3_ISR ;low priority isr CPFSEQ COUNT4 LP1 goto lpl LP2 BTG LATD,7 BTG LATD,6 rcall delay240 incf COUNT4 MOVLW 0X02 CPFSEQ COUNT4 LPP1 goto lpl LPP2 incf COUNT4 GOTO LP3 LP3 BTG LATD,5 BTG LATD,4 rcall delay120 movlw 0x03 cpfseq COUNT4 lp4 bra lpl lp5 btg LATD,3 btg LATD,2 decf COUNT4 decf COUNT4 lp6 movlw 0xd0 movwf TMR3H clrf TMR3L lpl retfie INIT clrf PORTD clrf LATD movlw red movwf LATD clrf TRISD return delay240 movlw D'200' movwf COUNT1 movlw D'2' movwf COUNT2 halt1: decfsz COUNT1,1 goto halt1 decfsz COUNT2,1 goto halt1 movlw 0xd0 movwf TMR3H clrf TMR3L bsf T3CON,TMR3ON return delay120 movlw D'200' movwf COUNT1 halt12: decfsz COUNT1,1 goto halt12 movlw 0xd0 movwf TMR3H clrf TMR3L bsf T3CON,TMR3ON return END |
sir,
finally its working i disabled watchdog timer , enabled power up timer ,disabled brown out detect , disabled ccp2 mux , disabled low voltage prog, and finally its giving the correct results but you told that we can't call delay routine in ISR routine then is my code wrong ? and then how to phase shift delay without delay routine ?you helped me a lot and thnks a lot fot that. |
As motion said, you need to interrupt at 6 times your frequency. 6*50Hz = 300Hz. You need to set your timer so it interrupts every 3.3mS. You then set the outputs from values that are in a table.
Alternatively, you can rotate a variable to generate the necessary outputs. Code:
; initialise the variable to have 3 bits set.
movlw b'00111000'
movwf Phase
; in your ISR rotate the variable like this.
rrf Phase,F
bcf Phase,7
btfsc STATUS,C
bsf Phase,5
HTH Mike. |
thank you sir,
i tried whatever you told its working now problem is that for next 3 second i want just reverse that of first according to your sugg. pins 5 and 2 ,pins 4 and 1, pins 3 and 0 was exactely reverse can i use the same data meance can i use pin 2 values for pin 5 to get reverse of first. pls help me thank you. |
To reverse a 3 phase sequence, you simply swap 2 phases.
Mike. |
thank you sir for replying me ,
actually when i swaped two phases like i'm using portd 5,4,3,2,1,0 pins and for that 5 is red ,3 is blue and 1 yellow and 2 is compliment of 5, 0 is of 3 and 4 is of 1 now when i want reverse motivation of motor then i want pulse of 2 on 5 and 0 on 3 and 4 on 1 and viceversa in first cycle we were passing 00111000 and for 6 intrruption cycle pulse was coming correctely but for next reverse cycle when i swap 2 phases then i've to pass 00110010 isn't it but for that pulses was not coming correctely and duty cycle was not 50% then what i done is i've taken the values for 6 intruption and swap these values for the respective pins by updating a flag and its giving the results but is this a right way and one more thing is that now i want to give 5microsecond delay in between top and bottom meance in between R and ~R , y and ~y , b and ~b how can it be possible waiting for reply thank you. |
;PROJECT NAME::ARD INVERTER
; FILENAME:1912.asm(main)
; RELETED FILES:BCD.asm,p2plsp18.lkr
;3-PHASE 50Hz SUPPLY TO PORT D WITH 120 DEG. PHASE SHIFT
;PORTD.5-R,PORTD.2- ~R
;PORTD.3-B,PORTD.0- ~B
;PORTD.1-Y,PORTD.4- ~Y
;FOR FIRST 3 SEC MOTOR SHOULD RUN IN ONE DIRECTION
;AFTER 1 SEC HALT AGAIN FOR NEXT 3-SEC MOTOR SHOULD RUN IN REVERSE DIRECTION
;IN BETWEEN THIS CHECK THE VTG OF EACH DIRECTION WITH ADC
;COMPARE THE VTGS OF 2 MODES RUN THAT MODE WHICH HAS LOW VTG CONTINUOUSLY
;DATE:21/12/05
; list P = 18C452
#include "P18F452.inc"
; DECLARATION OF REGISTERS
TENMSH EQU 50
TENMSL EQU 243
RED EQU B'10101010'
phase equ B'00111000'
revphase equ B'00000111'
F EQU 0x0001
VARIEBALS UDATA
COUNT1 RES 1
COUNT2 RES 1
T2 RES 1
t1 RES 1
#define _C STATUS,0
org 0x000000
goto START
org 0x000008
bra INT0ISR
org 0x00000526
START
rcall INIT
bSf INTCON,GIEH ;set the global interrupt enable bits
bSf INTCON,GIEL ; "
BSF INTCON,INT0IE
BCF INTCON,INT0IF ;SET INT0 INTRUPT ON LOW EDGE
BCF INTCON2,INTEDG0
btfsc PORTC,6
rt1:
bra $-2
rt2:
rcall sample
rcall DELAY3sec
rcall DELAY1sec
rcall sample1
rcall DELAYrev3sec
rcall DELAY1sec
loop0
rcall VOLTAGE_C
GOTO loop0
INIT:
setf PORTD
setf LATD ;setup portd for outputs
movlw 0x00
movwf TRISD
setf PORTC ;setup portc for outputs
setf LATC
movlw 0x00
movwf TRISC
setf PORTB
setf LATB ;setup portd for outputs
movlw 0x00
movwf TRISB
clrf t1
MOVLW 0X04
MOVWF T2
return
INT0ISR
setf PORTD
SETF LATD
clrf TRISD
bcf PORTC,6
retfie
;INTIALISATION OF PORT PINS IN NORMAL MODE
sample:
BCF PORTC,7
clrf LATD
clrf PORTD
clrf TRISD
movlw phase
movwf PORTD
return
;PORT PINS IN REVERSE MODE
sample1:
clrf LATD
clrf PORTD
clrf TRISD
movlw revphase
movwf PORTD
return
delay5us:
movlw 0xFF ;Load TMR3 with the value 0xF000
movwf TMR3H
movlw 0xFC
movwf TMR3L
bSf T3CON,TMR3ON ;Clear the Timer3 interrupt flag again.
T3POLL
btfss PIR2,TMR3IF ;Poll TMR3 interrupt flag to wait for another TMR3 overflow.
bra T3POLL
bcf T3CON,TMR3ON ;Clear the Timer3 interrupt flag again.
bcf PIR2,TMR3IF ;Clear the Timer3 interrupt flag again.
return
DELAY1sec:
movlw D'255'
movwf COUNT1
MOVLW 0X06
MOVWF COUNT2
sec1: movlw 0xF2 ;Load TMR3 with the value 0xF2FA
movwf TMR3H
movlw 0xFA
movwf TMR3L
T3POLL1
bra T3POLL1
decfsz COUNT1,1
goto sec1
decfsz COUNT2,1
GOTO sec1
return
;DELAY FOR WHICH TWO MODES SHOULD BE RUN
DELAY3sec:
movlw D'200'
movwf COUNT1
MOVLW 0X02
MOVWF COUNT2
sec3: movlw 0xD8 ;Load TMR3 with the value 0xD8F0
movwf TMR3H
movlw 0xF0
movwf TMR3L
T3POLL3
bra T3POLL3
rcall TENMS
rcall ADC
decfsz COUNT1,1
goto sec3
DECFSZ COUNT2,1
GOTO sec3
btg PORTC,5
movf temp_1,W
movwf comp_0
movf temp_3,W
movwf comp_4
movf temp_4,W
movwf comp_5
return
DELAYrev3sec:
movlw D'200'
movwf COUNT1
MOVLW 0x02
MOVWF COUNT2
rsec3: movlw 0xD8 ;Load TMR3 with the value 0xD8F0
movwf TMR3H
movlw 0xF0
movwf TMR3L
T3POL3
bra T3POL3
rcall TENMSre
rcall ADCc
decfsz COUNT1,1
goto rsec3
DECFSZ COUNT2,1
GOTO rsec3
btg PORTC,4
movf temp_1,W
movwf comp_1
movf temp_3,W
movwf comp_2
movf temp_4,W
movwf comp_3
return
;5HZ FREQ ROUTINE FOR FIRST 3 SEC ONE DIRECTION
TENMS
MOVLW TENMSH
MOVWF COUNTH
MOVLW TENMSL
MOVWF COUNTL
TEN1
DECFSZ COUNTL,F
GOTO TEN1
DECFSZ COUNTH,F
GOTO TEN1
rrcf PORTD,F
bcf PORTD,7
btfsc STATUS,C
bsf PORTD,5
TENMSEND
return
;5HZ FREQ ROUTINE FOR NEXT 3 SEC REVERSE DIRECTION
TENMSre
MOVLW TENMSH
MOVWF COUNTH
MOVLW TENMSL
MOVWF COUNTL
TEN1re
DECFSZ COUNTL,F
GOTO TEN1re
DECFSZ COUNTH,F
GOTO TEN1re
incf t1
MOVLW 0X01
CPFSGT T2
O1
GOTO O2
O3
rrcf PORTD,F
bcf PORTD,7
btfsc STATUS,C
bsf PORTD,5
DECF T2
O2
movlw 0x04
cpfseq t1
pl1
goto l3
pl2
movlw 0x18
movwf PORTD
incf t1
CLRF T2
l3
movlw 0x05
cpfseq t1
l4
goto l5
l6
movlw 0x1c
movwf PORTD
l5
movlw 0x06
cpfseq t1
l7
goto l8
l9
movlw 0x0A
movwf PORTD
INCF t1
l8
movlw 0x07
cpfseq t1
l10
goto pl10
l11
movlw 0x0A
movwf PORTD
INCF t1
pl10
movlw 0x08
cpfseq t1
l12
goto l13
l14
movlw 0x0e
movwf PORTD
l13
movlw 0x09
cpfseq t1
l15
goto l16
l17
movlw 0x03
movwf PORTD
INCF t1
l16
movlw 0x0a
cpfseq t1
l18
goto l19
l20
movlw 0x03
movwf PORTD
INCF t1
l19
movlw 0x0b
cpfseq t1
l21
goto l22
l23
movlw 0x07
movwf PORTD
movlw 0x01
movwf t1
MOVLW 0X04
MOVWF T2
l22
TENMSreEND
RETURN
END
hello sir,
first thank you for replying and helping me now its working but now problem is that i want to give 5microsecond delay in betwen top and bottom i.e dead band in between R and ~R and others also how i can achieve this waiting for reply thank you . |
