| | #16 | |
Target Vdd 5.00V Target Vpp 13.42V MPLAB ICD 2Vpp 13.58V Ah!I got it.Here's the schematic I got from the guy who designed the ICD2 clone I have in hand.The Vpp is generated by a step-up booster.I don't know whether there's any similar design over the web. Regards, Alex | ||
| | #17 |
Thanks Alex, That's a pretty clever circuit and would be great for a single voltage supply... Happy Holidays... Regards, Mike | |
| | #18 | |
You're welcome.And I hope this will help Jeff.BTW,when does the college winter break start in the U.S please? :wink:
__________________ Regards, Alex | ||
| | #19 |
Cool, now I dont have to hunt down a transformer that could give me the 13V. I think alot of colleges were done last week, which is when I finished up. Came out with a 3.16 for the semester (which consisted of 19 credits of senior level EE courses). Which is pretty good, considering that I worked 20+ hours every week, and spent time with my woman as well.
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| | #20 |
so for that crappy programmer, how do I configure it? Which oscillator do I choose? WDT? ect..
| | #21 | |
Oscillator HS WDT OFF Power Up Timer OFF Brown Out Detect OFF Low Voltage Program Disabled (Criticaly important) Data EE Read Protect OFF Code Protect OFF I got my PCB from a friend of my friend's.It perfectly matched into a plastic box commonly found in the market.Back then I didn't have a PIC16F877 or the A version,but some samples of PIC16LF877A.I borrowed a programmer from my friend and treated the LF as the F,Burnt the bootloader inside and it worked.I remember posting the picture somewhere in this forum. Got it!It's here: http://www.electro-tech-online.com/v...r=asc&start=15 And I have the whole project including schematics and PCB in my computer.If it can help you,I would like to share it with you guys here.This is a Protel99(SE) project,because most people here use protel.Even if someone manipulates Eagle well,he still can't get the PCB manufactured as the manufacturers use protel only.
| | #22 |
hmm...so are those the settings I would use for this programmer here: http://home.vrweb.de/~lotharstolz/st...vpc/index.html to load my bootloader to my 877A?
| | #23 |
The LVP-Cable?Tell me this is not your ICD2.I assume you are going to use this cable to program your ICD2 clone's PIC16F877A.I need to see the schematics of your ICD2 clone rather than this one to tell you what settings you need to burn the PIC.Maybe you should consider the project I referred to.Could anybody here offer Jeff a site of a real ICD2 clone?I don't know which one best fits him.Thank you.
| | #24 |
Hello All Heres a site I recently found. http://www.sixca.com/eng/articles/icd2_clone/index.html Its an ICD2 thats a little different then the one on STOLZ site. I've attempted to make an ICD2 on stolz site sevreal times now with no luck. Thinking my progbelm is getting the bootloader into the 16f876(A) using the LVP cable. Maybe this site will help you or someone else. | |
| | #25 | |
I'll look into the link that you gave Alex
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | ||
| | #26 |
The Config Fuses are stored in the Hex file. Just load the file and program ![]() But I don't know whether patched, A version has fuse settings integrated into hex, just set them as on picture:
__________________ "I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! | |
| | #27 |
ok, I had thought the fuses were saved in the hex but i wasnt sure. Maybe there is a problem with my serial cable. I don't need my 20Mhz oscillator connected either? Also, when you select the 'A' version, the fuses and code protect stuff changes. (it looks for a range for WRT) Thanks, Jeff
| | #28 |
No, you don't need to connect the oscilator if you are programming. The A version has slightly different fuses, try to trust settings that are stored in the hex.
| | #29 | |
| | #30 |
Things are finally starting to settle down a bit. I should have some time to play with this again. I couldnt get the low voltage programmer to work. Now that school is back in session, I'm going to go bug my microcontrollers professor and see if she can load the bootloader needed for the ICD that Jay has in his sig...She has a real ICD programmer, so it should work. I'm also planning on using the modification that Alex posted as well. is there any problem with doing that? More questions will follow most likely...
| compiler, dspic, programmer |
