Hi all, I am fairly new to programming and I am programming a PIC16F88 with Picbasic Pro. The purpose of this code is to... When the unit is turned on, the lcd will display the ambient air temperature, via the A/D converion within the Port A.3 and a serout from portA.2. As long as the temperature is under a certian value, the buzzer will remain silent. Once it goes over a value, the buzzer will go off indefinitly. Also, once a switch is turned on, a fan will be driven by a motor and a led will confirm this. Once another switch is flipped on a stepper motor will go into action for as long as the switch is on. Notice I do not have the code for the stepper motor. This is for another day lol. Basically, my question is am I on the right track? Learning how to program is difficult but I would like to learn. Thanks for any input on this matter By the way, I have included 2 attachments.....one in text edit and another in Word. I use a Mac so I was unsure about textedit on windows 8) Jonathan | |
Whoops guess it didnt attach Here's the code 'Our program for Space Heater DEFINE OSC 8 'Sets to 8Mhz DEFINE ADC_CLOCK 64 'Set clock source (rc=64) WHATS THIS MEAN DEFINE ADC_BITS 10 'Set number of bits in result DEFINE ADC_SAMPLEUS 50 'Sets sampling time to 50 microseconds temp VAR WORD 'create temp to store result buzzer VAR PORTA.1 'renames PortA.4 as buzzer onswitch VAR PORTB.2 'renames the ports as switches stepswitch VAR PORTB.3 OSCCON.4=1 OSCCON.5=1 OSCCON.6=1 cmcon.0=1 cmcon.1=1 cmcon.2=1 cvrcon.6=0 cvrcon.7=0 ansel= %0000001 'Turns on channel 0 TRISB=%00110000 'sets PortB.2,3 as inputs and rest outputs TRISA=%00001000 'as of now setting PORTA.3 as input ADCON1=%00001000 'Sets PORTA.3 as analog input (right justified?) ADCIN 0, temp 'Read channel 0 to temp Pause 500 'Wait .5 sec loop: While (onswitch=1) 'lights up "on" led Gosub Fan Wend ADCIN 0, temp serout PORTA.2,2,[$0C] 'clears screen serout PORTA.2,2 ["The Temperature is"] 'sends the string The Temperature is serout PORTA.2,2 [$FE,$C0] 'moves the cursor to second line serout PORTA.2,2,[DEC temp] 'displays the decimal value of temp OR SHOULD USE #? Pause 500 'pauses display for .5 sec If (DEC temp<30) 'So if temp is less that 30C, the buzzer doesn't sound Then buzzer=0 Else buzzer=1 'Once the temp is greater than 30C, the buzzer goes off indefinitley Endif While (stepswitch=1) 'lights up "stepper" led OR would IF statements be better? Gosub Stepper Wend Goto loop 'does it forever End Fan: High PORTB.4 'this port is the port that goes into transistor for motor circuit return Stepper: 'Wait till lab return | |
anyone? thanks, Jonathan | |
| | #4 | |
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. | ||
| code, comment |
