I am using the PIC16F877A uC.
I wanted to do sampling at a fixed rate. The special event trigger simplifies matters since, when TMR1 count matches CCPR2, A/D conversion should automatically begin according to the data sheet. But in my program that is not happening. :cry: I have switched on the A/D module. I wanted to know do we have to manually start the A/D conversion by setting the GO/nDONE in ADCON0 Here's the relevant code: movlw B'00000000' ;Timer1 set for internal clock with 1:1 prescale value & ensured that it is off movwf T1CON clrf TMR1H ;clear Timer1H & Timer1L registers clrf TMR1L clrf CCPR2H movlw B'00001011' ;Special event trigger mode for ADC sampling at fixed rate movwf CCP2CON Pulse1 ;To ensure interrupts are disabled bcf INTCON,GIE btfsc INTCON,GIE goto Pulse1 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; movlw H'9E' ;ADRESL - Low byte storage of A/D result movwf FSR movlw B'10000001' ;Fosc/32 for 1.6us T-AD, AN0 as i/p channel, A/D module made on movwf ADCON0 movlw H'C8' ;40uS sampling time movwf CCPR2L bsf T1CON,TMR1ON REPEAT bcf PIR2,0 ;Clear CCP2IF flag movf INDF,W movwf PORTB ;portB o/ps 8 LSBs movf ADRESH,W movwf PORTD ;PortD's 2 LSBs contain 2 MSB's of digital outputs BACK btfss PIR2,0 ;Wait for CCP2IF flag to be set. goto BACK NOTOVER btfsc ADCON0,2 goto NOTOVER ;Polls to see whether conversion over goto REPEAT Kindly check & let me know the flaw in the program. Thanks in advance... |
It all looks fine.
The only things I can see that may be wrong are. IRP <> 0 ADCON1 not set up - but default should be OK Fosc < 20MHz The one unusual thing is you read the result before you check CCPR2 and therefore, your first result will be meaningless. If you find the answer then please let us know as it looks an interesting problem. Mike. |
