Hello,
I was just improving my PIC programmer hardware, and suddenly it seems like the MCLR pin is kept low on a PIC16F628 (short circuit inside the PIC?). If I connect 12V to the MCLR, and GND to GND with no other pins connected (not even Vdd), heavy current will run through the MCLR pin (>250mA and probably more if my power supply didn't have current limit). The voltage on the MCLR pin will only rise to approx. 2V. If I connect the PIC to 5V supply and GND (no MCLR connected) the program in the PIC will run fine. What happened to the PIC? If it makes a difference, the PIC was obtained as a sample from Microchip. Regards, Futterama |
PIC's are extremely hardy devices, so you must have done something particularly 'nasty' to it - but sticking 12V from a PSU directly in the MCLR pin doesn't sound like you've treated it with much love or care?. |
Well, I think PICs are rough devices and I didn't do anything nasty...
Actually, there is a transistor between MCLR pin and the PSU, but does it make a difference? And I would never hurt my little babyes on purpose :lol: |
Microchip's sample is just like an ordinary PIC that you buy from stores and would not self distruct after a certain time.
You might have connected a voltage higher than 15V to the MCLR pin and this could damage it. Do not improve something if it ain't broken.
L.Chung |
to amplify the current running to it i guess? Shocks! :shock: [/b]
Everybody can but not everybody will. |
The voltage at Vpp have been below 13V at all times (12.82 to be accurate). I have to improve my programmer, so it can program other PICs than the 16F628 :wink: Well, I guess this is what can happen. I'll leave it in the ESD safe box for a few weeks, and it will be ready to reprogram again |
L.Chung |
The ability to control the Vdd.
My programmer works fine with PIC16F628 and a constant Vdd at programming cycle.
Nigel, I ALWAYS use the internal osc and I have programmed the PIC16F628 MANY times with this simple programmer...
(permalink) | ||
