I've tried the delay generator from piclist and I can't seem to get it working. It compiles without errors but the delay doesn't seem to work: Code:
LIST p=16F628 ;tell assembler what chip we are using
#include <p16F628.inc>
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _BODEN_ON & _MCLRE_OFF
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
movlw 7
movwf CMCON
clrf PORTA
clrw
tris PORTA ; porta all output
clrf PORTB
movlw 0xf0
tris PORTB
bsf STATUS, RP0 ; bank 1
bcf OPTION_REG, NOT_RBPU ;internal pullups on port B enabled
bcf STATUS, RP0 ;bank 0
Loop
movlw 0xff
movwf PORTA ;set all bits on
movwf PORTB
call Delay
movlw 0x00
movwf PORTB
call Delay
goto Loop
Delay
; Delay = 2 seconds
; Clock frequency = 4 MHz
; Actual delay = 2 seconds = 2000000 cycles
; Error = 0 %
cblock
d1
d2
d3
endc
;1999996 cycles
movlw 0x11
movwf d1
movlw 0x5D
movwf d2
movlw 0x05
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;4 cycles (including call)
return
end
Code: LIST p=16F628 ;tell assembler what chip we are using #include <p16F628.inc> __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _BODEN_ON & _MCLRE_OFF cblock 0x20 ;start of general purpose registers count1 ;used in delay routine counta ;used in delay routine countb ;used in delay routine endc org 0x0000 ;org sets the origin, 0x0000 for the 16F628, ;this is where the program starts running movlw 7 movwf CMCON clrf PORTA clrw tris PORTA ; porta all output clrf PORTB movlw 0xf0 tris PORTB bsf STATUS, RP0 ; bank 1 bcf OPTION_REG, NOT_RBPU ;internal pullups on port B enabled bcf STATUS, RP0 ;bank 0 Loop movlw 0xff movwf PORTA ;set all bits on movwf PORTB call Delay call Delay call Delay call Delay call Delay call Delay call Delay call Delay ; end of 2 secs movlw 0x00 movwf PORTA ;set all bits on movwf PORTB call Delay call Delay call Delay call Delay call Delay call Delay call Delay call Delay goto Loop Delay movlw d'250' ;delay 250 ms (4 MHz clock) movwf count1 d1 movlw 0xC7 movwf counta movlw 0x01 movwf countb Delay_0 decfsz counta, f goto $+2 decfsz countb, f goto Delay_0 decfsz count1 ,f goto d1 retlw 0x00 end | |
That's what you get for not writing your own code, or at least not understanding it. The way cblock is used is wrong in your program. The article on the Piclist probably assumed readers to know how to properly use cblocks... From MPASM's Help File, cblock section :cblock - Define a Block of Constants Syntax cblock [expr] label[:increment][,label[:increment]] endc Description Defines a list of named sequential symbols. The purpose of this directive is to assign address offsets to many labels. The list of names end when an endc directive is encountered. expr indicates the starting value for the first name in the block. If no expression is found, the first name will receive a value one higher than the final name in the previous cblock. If the first cblock in the source file has no expr, assigned values start with zero.
__________________ Time is nature\'s way of keeping everything from happening at once. http://membres.lycos.fr/jrainville/ | |
Joel, thanks for the reply. I've got it to work using: Code: cblock 0x20 d1 d2 d3 endc Code: movlw 0x11 movwf d1 movlw 0x5D movwf d2 movlw 0x05 movwf d3 | |
| | #4 | |
In the Piclist code, since there is no expr (which means no starting address, unlike Nigel's code which specifies 0x20), d1 is then given address 0x00, d2 0x01 and d3 0x02. This is bad. Your program is probably gonna wreak havoc writing to these addresses. For example, take your code Code: movlw 0x5D movwf d2
__________________ Time is nature\'s way of keeping everything from happening at once. http://membres.lycos.fr/jrainville/ | ||
Ahh - thanks! that explains why it kept jumping around when I tried it with a simulator :lol: | |
| | #6 |
I have tried to understand how many cycles the code takes but could not get exactly the required value of 1,999,996 cycles. Code: Delay ;1999996 cycles movlw 0x11 movwf d1 movlw 0x5D movwf d2 movlw 0x05 movwf d3 Delay_0 decfsz d1, f goto $+2 decfsz d2, f goto $+2 decfsz d3, f goto Delay_0 ;4 cycles (including call) return Thanks
__________________ L.Chung | |
| | #7 | |
I don't know how to calculate the number of times decfsz takes 2 cycles instead of 1, that's what bugs me.
| delay, routine, working |
