Anyone here knows how the SRF08 works in the way of capturing ranges to a 8501-based microcontroller? I'm in the middle of my project but I do not know how to check the status of the range finder. It can return ranges in cm but I am not sure whether it transfer the range in whole number only or with decimal point?
In other way of asking, how accurate the range finder can capture? How to test whether it is working before writing the I2C bus program?
Th range finder seems spoilt, I found out that the SCL and SDA line are shorted with the ground when I tested it with my mulitmeter.
My I2C program works for I2C Serial EEPROM. It should be the same for the range finder right?
Please help me with it... Thanx alot!!!
