Old 16th June 2005, 07:29 AM   #1
Default EEPROM Memory
I am looking into EEPROM memory from Microchip and would like to get some input on how they work. Does anyone have any schematics on how to connect them to a PIC? Also do they hold there memory when their power is cut or do they empty it?
GatorGuy is offline
Old 16th June 2005, 08:56 AM   #2
Default Re: EEPROM Memory
Why would you like to do that? If your answer is you need more space than Internal EEPROM, that's ok. If not, Internal PIC EEPROMs have a capacity of 256-512 Bytes, that's pretty much. What do you want to store there?
Also, try tu use Internal Program memory to do the job, it's ususally pretty empty and is very fast.
If you still want to use external EEPROM, use one with SPI(25xxx) or I2C(24xxx) serial bus connection.
Ofcourse they Don't "forget" when power is removed.
"I share, thus I am"
Jay.slovak
Read this!
ICD2 Clone
Best PIC/DsPIC Bootloader
Read my Inchworm ICD2 review!
Jay.slovak is offline
Old 16th June 2005, 11:18 AM   #3
Pretty much to just add more memory. At this point it is only research. I am learning what I can now for future projects. For now internal memory is enough for what I need to do. But I might see a need for it later.
GatorGuy is offline
Old 16th June 2005, 11:21 AM   #4
Oh I see, that's alright.
Jay.slovak
Read this!
ICD2 Clone
Old 16th June 2005, 12:04 PM   #5
I encountered this problem with my recent project, if u remember Jay... I needed much more memory, so I had either to get EEPROM or shorten the program... I chose the latter one, though my teacher stated that it isn't hard to work with EEPROMs: connect'em from PIC ports to pins, looking at teh datasheet (obviously) of the EEPROM...
May God be with you.
My Blog
Agent 009 is offline
Old 16th June 2005, 12:12 PM   #6
Yep I do...
Using external serial memory is not hard, but You should have some experiences before you do so.
Jay.slovak
Read this!
ICD2 Clone
Old 16th June 2005, 12:20 PM   #7
Trial and error is the key :wink: ...
No really, I think the datasheet and knowing assembly would just do
My Blog
Old 16th June 2005, 02:19 PM   #8
The serial EEPROMs have an I2C interface, which is really easy...just two pins and resistor pullups. I have some JAL code if you want to look at it.
Mike
upand_at_them is offline
Old 16th June 2005, 02:27 PM   #9
I2C... Is that serial communication?
My Blog
Old 16th June 2005, 03:14 PM   #10
Yes, it is 2wire, Half-Duplex synchronus serial communication in speeds from 100Khz thru 400Khz to 1Mhz max.
Jay.slovak
Read this!
ICD2 Clone
Old 16th June 2005, 03:36 PM   #11
But my PIC is driven by a 4MHz oscillator... What 2 do???
My Blog
Old 16th June 2005, 03:51 PM   #12
agent009 he said Kilo HZ not MHZ
a 4 mhz PIC should be able to handle 100 KHZ easily..
williB is offline
Old 16th June 2005, 05:12 PM   #13
Or you can use PIC with I2C peripheral, and that very easy and fast.
Jay.slovak
Read this!
ICD2 Clone
Old 16th June 2005, 05:14 PM   #14
Yeah, but if he said from 100Khz thru 400Khz to 1Mhz max... 4 MHz in not included???
My Blog
Old 16th June 2005, 05:26 PM   #15
That's not PIC frequency, it's the BUS speed.
Jay.slovak
Read this!
ICD2 Clone
eeprom, memory
