| | #17 | |
__________________ "I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! | ||
| | #18 |
Can it then transfer 1Mbit/s if its run at 1Mhz? :shock: thats about 100 KB/s and thats fast enugh for digital audio transfer. Is it realy that fast?
| | #19 | |
BTW: If speed is desired, you can use SPI @ 10Mhz, now that's fast!.
| | #20 | |
Firstly, I get the impression that the original question was asking about adding PROGRAM MEMORY to a PIC? - you can't do this for almost all PIC's, and I2C EEPROM wouldn't be suitable anyway. I2C EEPROM would only add another form of slow EEPROM data memory. Secondly, I2C is a relatively slow system, designed for a very specific purpose (connecting IC's together on large PCB's, using just two wires on a common bus). As such, it's fairly slow and complicated (it was never designed to be fast!) - but as it's a syncronous system the speed of it is totally dependent on the speed of the master clock thats feeding the slaves - AS LONG AS THE SLAVE CAN KEEP UP!. I2C EEPROM's are slow devices, you can read them a LOT faster than you can write them - and there are various projects available that can playback audio from an EEPROM using a PIC - but they use various clever methods to overcome the limitations. But you can't record the audio data in real time, the EEPROM is far too slow. | ||
| | #21 | ||
__________________ "I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! | |||
| | #22 |
I knew SPI was fast but i didnt know that I2C is that fast. Thanks for the shocking info on full speed you cod proboby run 100 uncompresd audio streams in real time over SPI
| | #23 | |
| | #24 |
I was thinking low qualety audio mono 11kHz,8 bit (good ebugh for speach)
| | #25 | |
| eeprom, memory |
