Ok here is the situation we are using the original CMUcam and we have to code loaded and the camera mounted. Our problem is that its not working, we tried different baud rates we tried the CMUCam2 and on the LCD display all we get is CMU Prg and a bunch of parameters, but its not all the ones that its supposed to display, it only displays half of the parameters and only one servo works and it drives in a circle, its not picking up the object.. So here is the schematic and code, i hope someone can help us here. Since the CMUcam is not working we went to the CMUCam2, So if anyone can help use i would appreciate it alot. We are currently using the CMUcam2 but if anyone has anymore info about either cams. Code 'Camera Tracking Program define osc 16 recdata var byte[10] x var byte confid var byte trisb=0 portb=0 pause 1500 serout portb.1,6,["CMU Prg."] serout portb.2,2,["RS", 13] pause 1250 'Reset Camera serout portb.2,2,["RS", 13] gosub display 'Turn green camera LED on serout portb.2,2,["L1 1",13] gosub display portb.3 = 1 'Turn on auto lighting adjust & flourscent band filter serout portb.2,2,["CR 45 7 18 44", 13] gosub display serout portb.1,6,["A L"] pause 20000 'Turn off auto lighting adjust serout portb.2,2,["CR 18 44 19 32", 13] gosub display 'Turn green Camera LED off serout portb.2,2,["L1 2",13] gosub display portb.3 = 0 'Set poll mode--1 packet serout portb.2,2,["PM 1", 13] pause 100 'Set raw data serout portb.2,2,["RM 3", 13] for x = 0 to 10 portb.3 = 1 pause 250 portb.3 = 0 pause 250 next x portb.6 = 1 'Track window command looks at center of Camera window 'Grabs data and sends it to track color function 'Track: serout portb.2,2,["TW", 13] pause 2000 portb.6 = 0 main: portb.3 = 1 'Send command--track 'Will track last color grabbed by TW command serout portb.2,2,["TC", 13] 'Gather the m statistics packet from TW command serin2 portb.0,84,[str recdata\10] confid = recdata[9] if recdata[2] > 50 and confid > 20 then left if recdata[2] < 40 and confid > 20 then right if recdata[8] < 175 and confid > 25 then fwd if recdata[8] > 200 and confid > 25 then bwd serout portb.1,6,[254,1,"S"] portb.3 = 0 pulsout portb.4, 668 pulsout portb.5, 676 pause 18 portb.3 = 1 goto main left: serout portb.1,6,[254,1, "L", #recdata[2]] for x= 1 to 7 pulsout portb.4, 696 pulsout portb.5, 676 pause 20 next x goto main: right: serout portb.1,6,[254,1,"R",#recdata[2]] for x= 1 to 7 pulsout portb.4, 668 pulsout portb.5, 648 pause 20 next x goto main: fwd: serout portb.1,6,[254,1, "F" , #recdata[8]] for x= 1 to 7 pulsout portb.4, 696 pulsout portb.5, 648 pause 20 next goto main: bwd: serout portb.1,6,[254,1,"B" , #recdata[8]] for x= 1 to 7 pulsout portb.4, 640 pulsout portb.5, 704 next x goto main: display: serin2 portb.0,84,20,main, [str recdata\3] for x = 0 to 3 serout2 portb.1,16468,[" ",recdata[x]] next x pause 1500 serout2 portb.1,16468,[254,1] return [/img] | |
Which bits work and which don't. Try to test each part separately and see if they work. For example. The code: pause 1500 serout portb.1,6,["CMU Prg."] serout portb.2,2,["RS", 13] pause 1250 Should display "CMU Prg." on the display and reset the camera. Can you put a stop instruction after it? Then move the stop instruction and work your way thought it and find out where it is going wrong. Does the code "serout portb.2,2,["L1 1",13]" turn on the green camera LED - I assume you can see it. Without datasheets for the camera and the serial display then I'm afraid I can't be much more help. Mike. | |
| problems, vehicle |
