Hi everyone, I would like to know if u can take a look into this program, may work allright, or not?. if you people can give me some advice, it will be well taken. Im beginning program to these PICS and i find the fascinating. Any help will be nice.....Greatings....Thanks P.D.: This is my first program, receive a 4 bit data on port C (less significant bits) and put those 4 bits on PortB LSB. When its done, the program activate a demux enable (74LS154). And the demux do the rest...This is controlling 3 demux....as a final project, i have to control about 25 i guess....thanks again.....see ya | |
I made the ff. changes: 1. Added the line: "LIST P=16F877" 2. Replaced instances of ",0" and ",1" with ",W" and ",F" respectively. 3. Please see the ASSIGN routine. Take time to read the contents of the file "PIC16F877.INC". In there you will find all the predefined constants relevant to the PIC16F877. Make use of the predefined constants like W, F and others. Using the constants will make your code easier to read and less prone to errors. In addition, it will make your program easier to adapt to other PIC devices & families like the PIC18F family. Code: ;::::::::::::::::::::::::::::::::::::::::::::::::::::::::
; Author: Rafael Franceschi :
; Date: 02/06/05 :
; Version: 2.7 :
; Title: Prueba 2 ( 7 modificaciones ) :
; Description: Toma la senal de entrada del puerto C :
; y la coloca en el puerto de salida B, :
; senales TTL (High and Low tanto en la :
; entrada como en la salida) :
; You forgot to put the ff. line before the include.
LIST P=16F877
INCLUDE "P16F877.INC"
__CONFIG _CP_OFF & _DEBUG_OFF & _WRT_ENABLE_ON & _CPD_OFF & _LVP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
;****************set up the constants****************
;*** Some of the constants are already defined in "PIC16F877.INC"
;STATUS EQU 03h
;TRISB EQU 86h
;TRISC EQU 87h
;PORTB EQU 06h
;PORTC EQU 07h
COUNT1 EQU 21h
COUNT2 EQU 22h
TEMP EQU 23h
ORG 0x00
GOTO CONFIGURATION
CONFIGURATION
BSF STATUS,5 ;Go to bank 1
CLRF TRISB ;Put 00 into TRISB - all pins set to output
MOVLW b'00001111' ;Put 255 into W
MOVWF TRISC ;Put 255 into TRISC - RC0/RC3 set as input
BCF STATUS,5 ;Come back to bank 0
CALL DIRECCION1
CALL DIRECCION2
CLRF PORTB
CLRF PORTC
START CALL INITIALIZE
CALL LOOP1
CALL ASSIGN
CALL ACT_ENABLE1
CALL ACT_ENABLE2
CALL LOOP2
GOTO START
;************Start of Delay 1***********************************
LOOP1 DECFSZ COUNT1,F ;Substract 1 from 255 - initial value of register 21h
GOTO LOOP1 ;If COUNT1 is Zero, jump this instruction
CALL DIRECCION1
RETURN
;***********Add Another OFF delay********************************
LOOP2 DECFSZ COUNT2,F ;Substract 1 from 255 - initial value of register 22h
GOTO LOOP2 ;If COUNT1 is Zero, jump this instruction
CALL DIRECCION2
RETURN
;************Subroutines Counters*********************************
DIRECCION1 MOVLW .50 ;Counter time - from "x" to zero
MOVWF COUNT1
RETURN
DIRECCION2 MOVLW .50 ;Counter time - from "x" to zero
MOVWF COUNT2
RETURN
;*************Initialize the ports and comands********************
INITIALIZE BSF PORTC,5
BSF PORTC,6
BSF PORTC,7
CLRF PORTB
CLRW
RETURN
;*************Enable the demuxs (2 at first)**********************
ACT_ENABLE1 BCF PORTC,5 ;Clears Enable Bit - Activates First Enable
RETURN
ACT_ENABLE2 BCF PORTC,6 ;Clears Enable Bit - Activates Second Enable
RETURN
;*************Assigning the Vectors*******************************
ASSIGN MOVF PORTC,W
ANDLW b'00001111'
MOVWF TEMP
MOVF PORTB,W
ANDLW b'11110000'
IORWF TEMP,W
MOVWF PORTB
RETURN
;**********************END of Program****************************
END
__________________ "Having to do with Motion Control" | |
im using MPLAB from microchip.....and when i compile it....it keeps having a warning...the message says Message[302] C:\PRUEBA27.ASM 32 : Register in operand not in bank 0. Ensure that bank bits are correct. i know that i configure the register in bank 1....but the program keep saying that...should i be worried about that? | |
It's just a friendly reminder to set the appropriate bank register bits. Use the ff. line near the beginning of your program to suppress it. Code: ERRORLEVEL -302
| | #5 | |
The assembler isn't clever enough to know that you have already selected the correct bank, so either ignore it, or disable it. | ||
| code |
