Is there a good way to do multiple PIC devices on a serial bus? They're devices I'd design, so I have an ability to do some nonstandard things.
I assume one PIC could transmit to multiple devices in parallel, and each device would just look for a byte string that tells it the stream is intended for that device or not. Correct? Now on the other issue is some devices will need to return data. Of course there cannot be two on the bus at the same time. Can the PIC put just its transmitter in tristate and later switch to driving the line while not affecting the receiving portion, without any glitches? Is this practical? |
Hi Oznog
I've done something along the lines of what you're thinking... This was with multiple 16F84's (20 of em) where I used RS232 comms from a PC, all the PICs were identical except each had a 'personality' byte numbered from 0 upwards. So each command from the PC addressed a particular PIC which would then respond with a multibyte string. Since the PC was the master and all PICs slaves there was never any contention. You may want to look at I2C enabled devices which will I think do exactly what you require and a similar scheme to that above could be easily implemented. Best of Luck Ed |
Thanks, I've actually been using I2C but the cable length is long and will get longer if I add more devices. The PIC has a lot higher current sink capability than the I2C spec requires and thus can drive longer than spec cable lengths, but I'm still pushing it, and can't put an I2C EEPROM on there because it can't sink enough current to meet timing on that cable length.
"I share, thus I am" Jay.slovak Read this! ICD2 Clone Best PIC/DsPIC Bootloader Read my Inchworm ICD2 review! |
You could try looking for "PICNET USB", a PIC networking scheme which uses USB, which also includes an older system that uses serial connections.
The link I have here doesn't work at the moment though?. |
It's not for the 84, the USB section uses the 16C745 USB PIC, but the older serial version is fine with the 84. |
(permalink) | |||
LOL USB and 16F84... :shock:
Hi Y'all
really it all comes down to the data rate necessary to solve the original problem, if it's simply a matter of taking in data from multiple, slow speed sensors then the data rate can be equally slow. If however, there are a number of subsystems which require action *NOW* then the bandwidth requirement is that much greater and requires every part of the system to be fast or faster. Bearing in mind that PIC's generally have a max clock of a fairly pedestrian 20MHz, let's lay back and smell the coffee Ed 8) |
Hi
I should know already, ask Oznog. But I guess he has a datarate/distance problem :lol: Ed |
(permalink) | ||
Hiya Oznog,
Eh mate have ya thought of going wireless? Those 433mhz devices are getting pretty cheap like over here in Oz there only $8 each and there's a heap of info out there to get started. Once I get me shed finished I'll finally be able to start a few projects that are on the back burner and 1 of them a is a wireless system for checking the tank levels for my water storage tanks.( it's too far to walk now knowing I can make sumthing to keep me in front of the footy game and still be working hahaha) Cheers Bryan
" The only way to avoid human error is to avoid the use of humans" |
I guess the harness is around 6 ft right now, if I added more devices, it could easily double. I've had it running on I2C for awhile now with some relatively low ohm pullup resistors.
I'm keeping this low power in sleep mode, there is no "off" switch and the bus should be able to wake the part up. I2C line driver chips would probably present a problem here, plus there's just no room on the board. The power consumption when running is not such an issue though. I can't add the I2C EEPROM with the bus loaded with so much more capacitance than spec though. It's unlikely the EEPROM has enough driving capability that its response would meet the timing spec. So I was toying with the idea of serial again, which generally should have been the logical choice. Bandwidth requirement is not so great, I already set it at a lower speed. |
