24th May 2003 08:17 AM #1
AD converter....
Hello every body... Hope you all are in good health...
I have these codes and I need an explanation of it...(line by line)....
can any ony anwer my question?
This is the program, it is for converting A/D for 8-bits:
' PicBasic Pro program to display result of
' 8-bit A/D conversion on LCD
' Connect analog input to channel-0 (RA0)
' Define LCD registers and bits
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
adval VAR BYTE ' Create adval to store result
TRISA = %11111111 ' Set PORTA to all input
ADCON1 = %00000010 ' Set PORTA analog and LEFT justify result
ADCON0 = %11000001 ' Configure and turn on A/D Module
Pause 500 ' Wait .5 second
loop: ADCON0.2 = 1 ' Start Conversion
notdone: Pause 5
IF ADCON0.2 = 1 Then notdone ' Wait for low on bit-2 of ADCON0, conversion finished
adval = ADRESH ' Move high byte of result to adval
LCDOut $fe, 1 ' Clear screen
LCDOut "Value: ", DEC adval ' Display the decimal value
Pause 100 ' Wait .1 second
GoTo loop ' Do it forever
End
