Old 31st March 2005, 04:48 AM   #1
Default Motor control interface
Hi all,
Could anyone review the code for programming the LM629 that I have written ?. I have tried to follow the sample code given in the programming guide but it does not seem to work . Could anyone possibly review the code ? Possibly some one who has worked with the 629 before .This is written in PIC C . I have also included a schematic of my circuit . Could any one review the circuit for errors . Please find below the links that i've used to help me in my design . Thanks a ton for your time and effort.
// ****  Kindly maximize the screen , (c) D.Ajay kumar , March , 2005  ****
// This Program is written in PIC C to interface a PIC16F877 to a LM629 , The program is expected to execute the following
// operation ," Independent of the current resting position of the motor shaft , the shaft will complete thirty revolutions
// in the reverse direction . Total time for the move is fifteen seconds. Total time for accn and deceleration is five secs"
// **         ---- This system uses a 2500 cpr encoder ----            **
// Total counts for this position 2500 cpr x 4 counts/cycle = 10000 counts / rev.
// 10000 x 30 rev = 300000 counts
// 300000/5 = 60000 counts during acceleration and deceleration
// 60000/2 = 30000 counts during acceleration
// Sample perion of system = 2048 x (1/6x10e6) =  341 x 10e-6 seconds/sample.   ---- note : 6 MHz clock ----
// The number of samples during accn. (and deceleration) = 2.5 secs / (341x10e-6) = 7332 samples during accn/ decleration.
// s=ut + 1/2 at^2
// a=2s/t^2  = (2 x 30000 counts) / (7332 samples)^2 = 0.00111 counts / sample^2
// Total counts travelled at max velocity is 4/5th of total counts travelled
// (4x 300000)/5 = 240000 counts.
// Number of samples at maximum velocity  10 seconds / (341 x 10e-6) = 29325  samples.
// Using counts/sample velocity is found  :  240000/29325 = 8.184 counts / sample.
// Scale acceleration values: 0.00111 x 65536 = 72.744 counts /sample^2
// Scale velocity values : 8.184 x 65536 = 536346.624 counts/sample.
// Round values to the nearest integer:
// Acceleration = 73 = 00 00 00 49 hex counts/sample ^2 ----------------------------------------------(1)
// Velocity = 536347 = 00 08 2F 1B hex counts/sample    ----------------------------------------------(2)
// Position =-300000 = FF FB 6C 20 hex counts           ----------------------------------------------(3)
#include "C:\pic\Examples\motorfin.h"
#byte TRISB=0x86     // Initialize PORTB
#byte TRISD=0x88     // Initialize PORT D
#byte PORTB=0x06     // Set up PORT B
#byte portd=0x08     // Set up PORT D
#bit rst=0x08.7      // Define RESET pin to PORT B7
#bit ps=0x08.6       // Define Port Select to PORT B6
#bit wr=0x08.5       // Define Write to PORT B5
#bit rd=0x08.4       // Define Read to PORT B4
#bit RB0=0x06.0      // Define RB0 (busy-bit pin)
void init_mod(void);
void filter_mod(void);
void busy_bit(void);
void status_check(void);
void out_c(short);
void out_d(short);
int sw;
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_spi(FALSE);
   setup_psp(PSP_DISABLED);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
while(1)
   TRISD=0x00;      // Set PORT D as INPUT
   init_mod();      // Call Initialize function
   filter_mod();    // Call Filter function
   out_c(0x1f);     // Call out_command module and load the trajectory parameters input buffers
   busy_bit();      // Call busy bit check module
   out_d(0x00);     // Call out data module and output HB of trajectory control word
   out_d(0x2b);     // All three parameters (pos,vel,acc) will be loaded and all are relative
   out_d(0x00);     // Accn. data HIGH word HB, refer note ......(1)
   out_d(0x00);     // Accn. data HIGH word LB
   out_d(0x00);     // Accn data LOW word HB
   out_d(0x49);     // Accn data LOW word LB
   out_d(0x00);     // Vel. HIGH word HB, refer note ............(2)
   out_d(0x08);     // Vel. HIGH word LB
   out_d(0x2f);     // Vel. LOW word HB
   out_d(0x1b);     // vel. LOW word LB
   out_d(0xff);     // Pos. HIGH word HB, refer note ............(3)
   out_d(0xfb);     // Pos. HIGH word LB
   out_d(0x6c);     // Pos. LOW word HB
   out_d(0x20);     // Pos. LOW word LB
   out_c(0x01);     // STT issued to execute trajectory
                    // ** BUSY BIT CHECK MODULE ** //
busy_bit()
//                **   CS pin is permanently grounded (Low)   **
TRISB=0xff;         // Set PORT B as OUTPUT
portd = 0xFF;       // Output '11111111' on PORT D
ps=0;               // Set PS=0
rd=0;               // Set RD=0
while(RB0);         // Wait till Busy_bit pin is set (RB0)
ps=1;               // Set PS=1
rd=1;               // Set RD=1
portd = 0xFF;       // Output '00000000' on PORT D
                    // ** INITIALIZATION MODULE ** //
init_mod()
portd = 0xFF;
begin:              // Label
rst=0b0;            // Set Reset Low
delay_ms(1);        // Call Delay 1 ms.
rst=0b1;            // Set Reset High
delay_ms(3);        // Call Delay 3 ms.
status_check();     // Call Status Check function
                    // Check if Status Word is hex 'c4' or '84'
if(!(sw==0xc4 || sw==0x84)) goto begin;
    else
       out_c(0x1d); // Tells which Interrupts to reset as indicated by zero's in the next data word
       out_d(0x00); // Don't Care data.
       out_d(0x00); // All interrupts will be reset
                    // Check if status word is hex 'c0' or '80'
if(!(sw==0xc0||sw==0x80))
           goto begin;
                    // ** FILTER PROGRAMMING MODULE ** //
out_c(0x1e);        // LFIL command - initiates loading filter co-efficients.
out_d(0x00);        // Filter control word , indicates which values Kp,Ki,Kd,Il will be loaded
out_d(0x0e);        // selects that kp,ki,kd values will be loaded
out_d(0x00);        // kp values 8 bit HB
out_d(0x0a);        // LB
out_d(0x00);        // ki values 8 bit HB
out_d(0x00);        // LB
out_d(0x00);        // kd values 8 bit HB
out_d(0x00);        // LB
out_c(0x04);        // Transfer new filter co-efficients to Working register
                    // ** DATA OUT FUNCTION ** //
out_d(int dat)
TRISB=0xff;         // Set PORT B as outputs
ps=1;               // Set PS high
rd=1;               // Set RD high
wr=0;               // Set WR low
PORTB=dat;          // Output 'dat' on PORT B
wr=1;               // Set WR high for sending next byte
                    // ** COMMAND OUT FUNCTION **//
out_c(int com)
ps=0;               // Set PS low
wr=0;               // Set WR low
PORTB=com;          // Output 'com' on PORT B
                    // ** STATUS CHECK FUNCTION ** //
status_check()
portd = 0xFF;       // Set PORT D as outputs
ps=0;               // Set PS low
rd=0;               // Set RD low
delay_ms(1);        // Call Delay for 1 ms
sw=PORTB;           // Store PORTB value in 'sw'
Links:
1. LM629 data sheet.
2. LM 629 programming guide.
3. LM 629 User Guide
4. LMD 18200 User Guide.
5. Circuit Schematic
the best bet yet...
dreamproject is offline
control, interface, motor
