+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 23 of 23
Thread: when shd i use a "call" and a "goto"? wh
  1. #16
    bmcculla Newbie
    Join Date
    Sep 2003
    Location
    California, USA
    Posts
    898
    I think the answer is lazy developers - if it works and you have enough flash why bother to make your code good. Of course this sort of thinking will come back and bite you when you try to add features or maintain the code.
    Make sure you're careful when turning on optimisations because they can break bad code.
  2. #17
    Desert Leo Newbie
    Join Date
    Feb 2005
    Location
    Bulgaria
    Posts
    5
    I'm agree with you Nigel, but I didn't mean to exclude goto instruction at all.
    goto is very usefull in combination with decfsz, incfsz, etc.
    But if I can use subroutine in my code, I will "call" it , not goto it.
    Gotos generated by compilers of high level languages (C-compilers are good example), as well as another disadvantages - mainly unpredicted code size force me to use assembler only. ... At least till the moment when I will fing a really good compiler.
  3. #18
    dak246 Newbie
    Join Date
    May 2004
    Location
    PSU
    Posts
    53
    Quote Originally Posted by bmcculla
    This is exactly what I used to do when i wrote C programs for the PC. Poor memory management and lazy techniques. Programming pics has taught me alot.
  4. #19
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by dak246
    I'm currently having fun improving the 'optimised' C code in assembler, although some of it's optimisations I don't like, and I'll probably make some sections longer, but more readable.
    One improvement I've just done (very applicable to the title of this thread), it to make one four line piece of code into a subroutine, as it's called 13 times this saves 38 words of memory - and makes the program more readable. I've been doing the same with other multiple pieces of code.
  5. #20
    bmcculla Newbie
    Join Date
    Sep 2003
    Location
    California, USA
    Posts
    898
    With a good compiler you should be able to make the code longer without generating any extra instructions.
    You should be able to turn on and off specific optimisations for code segments. #pragma ot(5) is Keil's directive to use optimisation level 5 for the next code segment. The down side is that stuff like this is nonstandard C.
    Nigel you really should look at SDCC. Its an open source C compiler. They are in the process of retargeting it to the PIC. Its online manuals have good info about a bunch of different compiler optimisation techniques.
  6. #21
    dak246 Newbie
    Join Date
    May 2004
    Location
    PSU
    Posts
    53
    Quote Originally Posted by Nigel Goodwin
    What exactly do you mean? Are you optimizing C code with assembly?
  7. #22
    bmcculla Newbie
    Join Date
    Sep 2003
    Location
    California, USA
    Posts
    898
    It's actually quite easy to go through the assembly code generated by a compiler and hand optimise the critical sections of the code. Most compilers generate an output for the debugger that has the C code as comments on the generated assembly. It's a good idea to do the best you can with C first though because its really hard to maintain code that has been done this way - you basicly have to do assembly programming after you make any changes, for all your future revisions too.
    I think Nigel is just doing a "port" of the C code to assembly using the compilers output.
  8. #23
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    To make it clear, I'm working on the HEX file generated by the C compiler (I don't like C, and never use it!) - I've used the disassembler I wrote as part of WinPicProg to generate the assembly code from the HEX file.
    From the assembler code generated I've been commenting the code, and naming the subroutines and variables - once I had that all done, I assembled the code to make sure it produced the exact same HEX file.
    Then from that fully working assembly code I've been improving it, making it smaller and more readable - although (as I mentioned before) I will be making some sections slightly larger to improve their readability.
+ Reply to Thread
Page 2 of 2
First 1 2
Tags for this Thread
