greetings i build project using 16f877 and seiko lcd (l167100j00) 1x16 char. i try long hard but only get 8 digits to display. i sur it only minor problem for someone knowing more than me. hoping to get answer. my grateful for help. sorry bad english,hope you able understand. seb metal.c / / nom: metal.C / / date: 07 / 08 / 2004 / / version: 1.00 / / circuit: circuit final detecteur pi / / auteur: sj / / micro: pic16f877 7.3728mhz - > tcycl = 0.5425 us / / = = = = = = = = = = = = = = = = = = = = = = = = = = #include "metal.h" #include "lcd.h" / / #include "string.h" / / fusibles de configuration, eeprom interne(256 octets), n°identification __config(wdtdis & hs & pwrten & unprotect & bordis & lvpdis & debugdis) ; / / eeprom interne: 256 octets max / / __eeprom_data(0, 1, 2, 3, 4, 5, 6, 7) ; #Define version1 "* Seb PI Metal *\n\r" #Define version2 "(c)by Seb 07-08-2004\n\r" / / __idloc(1234) ; / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / macro blocage interruptions / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / * static Bit tmpgie2; / / flag pour GIE #Define flag_gie_save2 tmpgie2 = 0;if(GIE) tmpgie2 = 1;gie = 0; #Define flag_gie_rest2 If(tmpgie2) GIE = 1; / / Save + rest = 7 rom * / / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / thus all the 'persistent' variables will be kept together, and you can / / get the bounds of this psect from the following declarations: / / pour stockage permanent en eeprom des variables utiliser: / / read_from_eeprom(_lnvram, _hnvram - _lnvram) ; / / write_to_eeprom(_lnvram, _hnvram - _lnvram) ; / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = extern char _lnvram[], _hnvram[]; / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / essayer de passer sur 7bits!!!! / / * definition des 8 caracteres en cg - ram * / / / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Const char cg_ram[] = {0x0e, 0x11, 0x0e, 0x14, 0x0f, 0x04, 0x1a, 0x02, / / 0x00 bon.gauche 0x0e, 0x11, 0x0e, 0x05, 0x1e, 0x04, 0x0b, 0x08, / / 0x01 bon.droit 0x0e, 0x11, 0x0e, 0x04, 0x1f, 0x04, 0x0a, 0x11, / / 0x02 bon.milieu 0x20, 0x20, 0x15, 0x20, 0x1f, 0x20, 0x20, 0x20, / / 0x03 continu = 0x20, 0x0a, 0x15, 0x20, 0x1f, 0x20, 0x20, 0x20, / / 0x04 alternatif ~_ 0x18, 0x14, 0x14, 0x18, 0x03, 0x04, 0x04, 0x03, / / 0x05 continu DC 0x08, 0x14, 0x1c, 0x14, 0x03, 0x04, 0x04, 0x03, / / 0x06 alternatif ac 0x04, 0x04, 0x0e, 0x0a, 0x0a, 0x0e, 0x04, 0x04, / / 0x07 resistance 0x00 / / fin }; / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / parametres de reglage du debit du port serie / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / (BRGH = 1) SPBRG = fosc / (16 * baudrate) - 1 Const char debitspbrg[] = / / { 103, 51, 16, 8, 0}; / / 16mhz / / { 155, 77, 25, 12}; / / 24mhz { 47, 23, 7, 3}; / / 7.3728mhz / / 9600 19200 57600 115200 #Define debitinit 3 / / 115kbps / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / variables main + isr / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = #Define tmr1_set 0b00110000 / / prescaler 1: 8, osc off, fosc / 4, stop timer1 #Define tmr1_set1 0b00000000 / / prec 1: 1, osc off, fosc / 4, stop tmr1 #Define intcon_set 0b01000000 / / GIE = 0, pie unmasked #Define option_set 0b10101000 / / prescaler 1: 1 sur RA4 unsigned char tmr1h2; / / timer High nb2 - > compteur 16777216 / / unsigned char hh = 0, mm = 0, ss = 0; / / horloge bank1 volatile char bufferrx[80]; / / tampon de reception rs232 #Define sizeofbufferrx 80 unsigned char indexrx = 0; / / index de position dans bufferrx unsigned char carrx = 0; / / dernier caractere recu static Bit bufferrxovf; / / '1' si overflow bufferRX / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / initialise le timer 1 pour des temporisations / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / temporisation 16 bits tmr1h2 - TMR1H / / horloge: 24mhz = > 0.166us soit 6.000.000 * 0.166us = 1s / / = = > timer1: prescale 1: 8 = > 6.000.000 / 8 = 750.000 / / = = > tmr1h2 = > 15 * 50.000 = 750.000 / / 65536 - 50000 = 0x3cb0 void init_tmr1() { tmr1h2 = 256 - 15; TMR1IF = 0; TMR1H = 0x3c; TMR1L = 0xb0; T1CON = tmr1_set; / / 0b00110000 = prescaler 1: 8, osc off, fosc / 4, stop timer1 TMR1ON = 1; / / activer PIE1 + GIE dans INTCON, TMR1IE dans PIE1, } / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / interruptions / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = static void Interrupt isr(void) { If(TMR1IF) { / / horloge(duree de fonctionnement) TMR1H = 0x3c; TMR1L = 0xb0; tmr1h2 + + ; If(tmr1h2 = = 0) { tmr1h2 = 256 - 15; / / led1 = !led1; } TMR1IF = 0; / / efface le flag isr } / * If(T0IF) { / / TMR0 = tmr0_set; efface le compteur / / tmr0high + + ; T0IF = 0; / / efface le flag isr } * / If(RCIF) { / / reception rs232 = > bufferrx If(OERR = = 1) { / / overrun error CREN = 0; CREN = 1; carrx = rcreg; } carrx = rcreg; bufferrx[indexrx] = carrx; indexrx + + ; If(indexrx >= sizeofbufferrx) { indexrx = 0; bufferrxovf = 1; } / / bootloader If(bufferrx[0] = = 'A') { RCIF = 0; GIE = 0; / / tempo 1 / 15s = 65ms(configurer cd2m avec 10 try a 65ms) TMR1H = 0x3c; TMR1L = 0xb0; led1 = 1; led2 = 1; While(!tmr1if) ; led1 = 0; led2 = 0; asm("ljmp 0x0000") ; / / = = > bootloader(reset) } led2 = !led2; / / echo caractere recu While(TRMT = = 0) ; / / attendre que le tampon soit vide TXREG = carrx; / / emet le caractere echo RCIF = 0; / / reset flag isr } } / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / initialisation des parametres / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = init_system(void) { / / = = = = = = = = = = = = = = = initialisation des ports i / o = = = = = = = = = = = = = PORTA = 0; / / sorties PORTA a 0 PORTB = 0; / / sorties PORTB a 0 / / PORTC = 0; / / sorties PORTC a 0 PORTC & = 0xc0; / / sorties PORTC a 0 sauf RC6 / 7 PORTD = 0; / / sorties PORTD a 0 PORTE = 0; / / sorties PORTE a 0 / / ADCON0 = 0xc5; ADCON0 = 0x85; / / 0b10000101(fosc / 32, RA0, GO, 0, a / D On) / / ADCON1 = 0x0e; / / 0b00001110(left justify(8bits), RA0 ana) ADCON1 = 0b10000010; / / (right justify(10bits), RA0 - 5 ana) TRISA = trisaconf; / / '1' entree ; '0' sortie TRISB = trisbconf; / / '1' entree ; '0' sortie TRISC = triscconf; / / '1' entree ; '0' sortie TRISD = trisdconf; / / '1' entree ; '0' sortie TRISE = triseconf; / / '1' entree ; '0' sortie / / #Define option_set 0b10101000 / / prescaler 1: 1 sur RA4 option = 0b00000000; / / charge masque registre option = > pull - up On RB / / = = = = = = = = = configuration des interruptions = = = = = = = = = = / / PIE1 = 0b00100001; / / RCIE(usart rx) + timer1 PIE2 = 0b00000000; RCIF = 0; INTCON = 0b01000000; / / masque interruption, GIE + pie / / = = = = = = = = = initialisation des peripheriques = = = = = = = = = / / bobi = 1; / / bobine off cmd_samp = 1; / / 4066 off init232(debitspbrg[debitinit]) ; / / port serie, 115kbds, pas de parite, 8bits, 1 stop / / / / tempo(3) ; / / tempo 0.5ms init_tmr1() ; lcd_init() ; / / init lcd 4 bits lcd_putcmd(0x40) ; / / chargement des caracteres redefinis lcd_puts(cg_ram) ; / / en cgram lcd_clear() ; / / efface le lcd(added by cgram) GIE = 1; / / interruptions On } / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / initialisation affichage introduction / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = init_intro(void) { unsigned char cpt; version() ; / / tx232_puts: version1, version2 tx232( '>'); // prompt / / / lcd_bitmap(bmp0) ; / / seb scope / / tempo_x65ms(50) ; lcd_putcmd(disp_on) ; lcd_clear() ; lcd_putchar(0x00) ; / / 12345678901234567890 lcd_puts("PI metal Detect SJ\x01\x02") ; tempo_x65ms(18) ; lcd_clear() ; lcd_puts("by Seb 02-13(c)2005") ; tempo_x65ms(15) ; lcd_clear() ; / / test 12v ###### / / 12345678901234567890 lcd_puts(" Battery Test !!") ; For(cpt = 8; cpt > 0; cpt - -) { lcd_putcmd(disp_off) ; tempo_x65ms(3) ; lcd_putcmd(disp_on) ; / / beepxkhz(0) ; tempo_x65ms(5) ; } } / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / detection bootloader / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / * test_loader() { If(RCIF) { If(rx232() = = 'A') { lcd_off() ; asm("ljmp 0x0000") ; / / reset } } } * / / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / info de version rs232 / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = version(void) { tx232_puts(version1) ; tx232_puts(version2) ; } / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / decodage commande rs232 / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = / / main / / reglage r12(pot droit): ajuster pour avoir pb = 500 / / = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = #Define nbmenu 5 void main(void) { unsigned char i = 0, fpwm = 255, / / 255 = > 450hz menu = 0; / / 165, 165, 45, 4 / / 148, 78, 133, 31 / / 150, 78, 33, 35 / / transfo / / 188, 78, 33, 135 / / bat / / 138, 78, 33, 135 / / 120, 67, 38, 216 bob2 transfo unsigned char m_pulse = 154, / / duree de l 'impulsion (us) m_wait = 35, / / pause apres impulsion(us) m_samp = 40, / / acquisition(4066)(us) m_wait_short = 240, / / pause apres acquisition(us) m_wait_long = 45; / / 35 / / 4; / / pause entre 2 pulses(ms) / / us * 0.855us = > vrai us unsigned int ana_out, / / signal detection metal 2 ana_pb, / / filtre passe - bas ana_samp, / / signal detection metal 1 ana_12v, / / surveillance + 9v(batterie) ana_15v, / / surveillance + 15v(icl7660) tmpint, / / pour moyenne ana zero_out, / / zero ana_out zero_pb; / / zero ana_pb / / configurations des entrees / sorties / * SPBRG = 0x00; / / #corrige bug bootload TXSTA = 0x02; RCSTA = 0x00; * / init_system() ; / / affichage de l 'INTRODUCTION init_intro() ; lcd_clear() ; init_pwm() ; For(;;) { If(bufferrxovf = = 1) { bufferrxovf = 0; tx232_puts("\n\rBuffer Overflow !\n\r>") ; } If((carrx = = '\n')||(carRX=='\r')) { parse232() ; } / / 10khz ana_out = 0; ana_pb = 0; ana_samp = 0; GIE = 0; / / faire 5 pulses de stabilisation For(i = 64 + 5; i! = 0; i - -) { / / 32 bobi = 0; / / bobine On delayus(m_pulse) ; bobi = 1; / / bobine off delayus(m_wait) ; cmd_samp = 0; / / 4066 On delayus(m_samp) ; / / conversions analogique 10bits.. . adc_read(ana_out, &tmpint) ; / / signal detection metal 2 If(i <= 64) ana_out + = tmpint; adc_read(ana_pb, &tmpint) ; / / filtre passe - bas If(i <= 64) ana_pb + = tmpint; adc_read(ana_samp, &tmpint) ; / / signal detection metal 1 If(i <= 64) ana_samp + = tmpint; cmd_samp = 1; delayus(m_wait_short) ; } GIE = 1; / / duree = ((m_pulse + m_wait + m_samp + m_wait_short) *.855us + 5us * 3) * 64 / / duree = [17300us;56000us] / / ana(1ch) = 32 / 7.3728e6 ana_samp = ana_samp > > 6; / / div 64 / / 32 > > 5 ana_out = ana_out > > 6; / / div 64 / / 32 ana_pb = ana_pb > > 6; / / div 64 / / 32 / / affichage 10bits = > 2^10 = 1024 max / / 12345678901234567890 / / o = xxxx S = xxxx ???? lcd_goto(0x08) ; / / position 0(ligne 1) lcd_puts("O=") ; lcd_uint(ana_out, 2) ; lcd_puts(" P=") ; lcd_line2() ; / / revised lcd_puts("=") ; / / inutile: transitions trop rapide(revised) lcd_uint(ana_pb, 9) ; switch(menu) { case 0: / / m_pulse lcd_puts(" pu=") ; lcd_uchar(m_pulse, 17) ; break; case 1: / / m_wait lcd_puts(" wa=") ; lcd_uchar(m_wait, 17) ; break; case 2: / / m_samp lcd_puts(" sa=") ; lcd_uchar(m_samp, 17) ; break; case 3: / / m_wait_short lcd_puts(" ws=") ; lcd_uchar(m_wait_short, 17) ; break; case 4: / / m_wait_long lcd_puts(" wl=") ; lcd_uchar(m_wait_long, 17) ; break; case 5: / / zero_out - ana_out lcd_puts(" D=") ; lcd_uint(fpwm, 16) ; break; } / / fpwm = 115200 / (PR2 + 1) = > [450hz - 115khz] / / fpwm = ana_samp > > 2; If(ana_out >= zero_out + 2) { / / ana_out - zero_out > 2 / / 3 fpwm = 70 + (((zero_out - ana_out) > > 0) < < 1) ; / / > > 1 < < 2 / / 100 + / / (((ana_pb - zero_pb) > > 3) < < 2) ; } Else { fpwm = 0; } update_pwm(fpwm) ; / / conversion ana 12v 15v adc_read(ana_15v, &ana_15v) ; / / surveillance + 15v(icl7660) adc_read(ana_12v, &ana_12v) ; / / surveillance + 9v(batterie) If(!bp_up) { / / fpwm + + ; / / m_pulse + + ; / / While(!bp_up) ; switch(menu) { case 0: m_pulse + + ; break; case 1: m_wait + + ; break; case 2: m_samp + + ; break; case 3: m_wait_short + + ; break; case 4: m_wait_long + + ; break; } } If(!bp_down) { / / fpwm - -; / / m_pulse - -; / / While(!bp_down) ; switch(menu) { case 0: m_pulse - -; break; case 1: m_wait - -; break; case 2: m_samp - -; break; case 3: m_wait_short - -; break; case 4: m_wait_long - -; break; } } If(!bp_enter) { / / lcd_puts("bp ENTER") ; / / tx232_puts("test BP ENTER\n\r") ; menu + + ; If(menu > nbmenu) menu = 0; While(!bp_enter) ; } If(!bp_esc) { menu - -; If(menu = = 255) menu = nbmenu; While(!bp_esc) ; } If(!bp_zero) { / / 12345678901234567890 / / 12v = xxxx 15v = xxxx ???? zero_out = ana_out; zero_pb = ana_pb; lcd_clear() ; lcd_puts("12V=") ; lcd_uint(ana_12v, 4) ; lcd_puts(" *15V=") ; lcd_uint(ana_15v, 14) ; / * lcd_puts(" O=") ; / / valeur zero_out lcd_uint(zero_out, ??) ; * / While(!bp_zero) ; lcd_clear() ; } / / While((bp_port & bp_mask) ! = bp_mask) ; / / antirebond / / test bp puis timeout timer0 / 1 / 2?? delayms(m_wait_long) ; / / ?? } / / fin du For(;;) } / / eof / / lcd.c //================================================== ====================================== // NOM: lcd.c // Date: 02/08/2004 // Version: 1.00 // Circuit: circuit final PI detect // Auteur: SJ // Micro: PIC16F877 7.3728MHz -> tcycl = 0.5425us // Revision: correction rw_start_eeprom //================================================== ====================================== #include "lcd.h" /*static bit tmpGIE; // flag pour GIE #define FLAG_GIE_SAVE tmpGIE = 0;if (GIE) tmpGIE = 1;GIE = 0; #define FLAG_GIE_REST if (tmpGIE) GIE = 1;*/ // SAVE+REST = 7 ROM //volatile unsigned char touche; // AFFICHEUR LCD #define LCD_INIT_VALUE 0x30 // TEMPO #define FREQ_MULT (FOSC)/(4000000L) //================================================== ====================================== // Temporisation pour le LCD //================================================== ====================================== // x * 1us ( DelayUs(200) = 170.9us) void DelayUs(unsigned char x) { unsigned char tmp; for(tmp = x>>1; tmp!=0; tmp--) { } } void DelayMs(unsigned char cnt) { unsigned char i; while (cnt--) { for (i=5 ;i!=0 ;i--) { DelayUs(234); // Adjuster pour 200us } } } //================================================== ====================================== void tempo_x65ms(unsigned char nbr){ while(nbr--) { DelayMs(65); } } //================================================== ====================================== // LCD HD44780 4 bits MSB sur PORTD // initialisation du LCD //================================================== ====================================== void lcd_init(void) { LCD_RS = 0; LCD_DATA = 0; LCD_EN = 0; DelayMs(15); LCD_DATA = LCD_INIT_VALUE; LCD_STROBE(); DelayMs(5); LCD_DATA = LCD_INIT_VALUE; LCD_STROBE(); DelayUs(200); LCD_DATA = LCD_INIT_VALUE; LCD_STROBE(); DelayMs(5); //#TEMPO LCD_DATA = 0x20; // Set 4-bit mode LCD_STROBE(); lcd_putcmd(0x28); // Function Set lcd_putcmd(0x01); //Display Clear *1 lcd_putcmd(0x0C); //Display On lcd_putcmd(0x06); //Entry Mode lcd_putcmd(0x0C); //Disp On /*lcd_putcmd(CLR_DISP); // clr Home lcd_putcmd(DISP_ON); // display on clign off lcd_putcmd(ENTRY_INC); // pas de decalage lcd_putcmd(DISP_ON); // display on*/ DelayMs(25); // ajout sinon PB cgRam } //================================================== ====================================== // Lecture LCD (sans attente) //================================================== ====================================== unsigned char lcd_read_cmd_nowait(void) { unsigned char c, readc; LCD_TRIS = LCD_TRIS_IN; LCD_RW = 1; // Read LCD asm("nop"); // short propagation delay asm("nop"); // short propagation delay LCD_STROBE_READ(readc); // Read high nibble // Move 4 bits to high nibble while zeroing low nibble c = ( ( readc << 4 ) & 0xF0 ); LCD_STROBE_READ(readc); // Read low nibble c |= readc & 0x0F ; // Or in 4 more bits to low nibble LCD_RW = 0; // Return to default mode of writing LCD LCD_TRIS = LCD_TRIS_OUT; // Return to default mode of writing LCD return(c); } //================================================== ====================================== // Check Busy : Boucle tant que le LCD n'est pas pret (ou timeout) //================================================== ====================================== void lcd_check_busy(void) { // To avoid hanging forever in event there's a bad or // missing LCD on hardware. Will just run SLOW, but still run. unsigned char retry; unsigned char c; for (retry=255; retry!=0; retry--) { c = lcd_read_cmd_nowait(); if ((c&0x80)==0x00) break; // Check busy bit. If zero, no longer busy } } //================================================== ====================================== // ecrit une commande sur le LCD //================================================== ====================================== void lcd_putcmd(unsigned char c) { //DelayMs(5); //#TEMPO AJUSTER DelayUs(10); //lcd_check_busy(); LCD_RS = 0; LCD_DATA &= 0x0F; LCD_DATA |= (c & 0xF0); LCD_STROBE(); LCD_DATA &= 0x0F; LCD_DATA |= (c << 4); LCD_STROBE(); } //================================================== ====================================== // ecrit un caractère sur le LCD //================================================== ====================================== lcd_putchar(unsigned char c){ //DelayMs(5); //#TEMPO AJUSTER DelayUs(10); //lcd_check_busy(); LCD_RS = 1; LCD_DATA &= 0x0F; LCD_DATA |= (c & 0xF0); LCD_STROBE(); LCD_DATA &= 0x0F; LCD_DATA |= (c << 4); LCD_STROBE(); LCD_RS = 0; } //================================================== ====================================== // ecrit une string de caracteres sur le LCD //================================================== ====================================== lcd_puts(const char * s){ while(*s) lcd_putchar(*s++); } //================================================== ====================================== // Clear and home the LCD //================================================== ====================================== void lcd_clear(void){ lcd_putcmd(0x01); DelayMs(10); // 2ms } //================================================== ====================================== // convertit un nombre hexadecimal en ascii //================================================== ====================================== unsigned char hexa2ascii(unsigned char tmp){ tmp += 0x30; if (tmp>0x39) tmp+=7; return tmp; } //================================================== ====================================== // convertit un nombre ascii en hexa //================================================== ====================================== unsigned char ascii2hexa(unsigned char tmp){ tmp -= 0x30; if (tmp>0x09) tmp-=7; return tmp; } //================================================== ====================================== // ecrit un nombre en hexa sur le LCD //================================================== ====================================== lcd_hexa(unsigned char c){ lcd_putchar( hexa2ascii(c >> 4) ); lcd_putchar( hexa2ascii(c & 0x0F) ); } //================================================== ====================================== // ecrit un espace a la place d'un '0' //================================================== ====================================== void lcd_putchar_0(unsigned char car, unsigned char* zero){ unsigned char tmp; if ((car=='0')&&(*zero==0)) tmp = ' '; else { tmp = car; (*zero)++; } lcd_putchar(tmp); } //================================================== ====================================== // ecrit un unsigned char sur le LCD //================================================== ====================================== void lcd_uchar(unsigned char u, unsigned char pos){ unsigned char Dtemp, zero=0; lcd_goto(pos); lcd_putchar_0(u/100+0x30, &zero); // cent (elimine '0' non significatif) Dtemp = u%100; lcd_putchar_0(Dtemp/10+0x30, &zero); // dix lcd_putchar(Dtemp%10+0x30); // unite } //================================================== ====================================== // ecrit un unsigned int sur le LCD //================================================== ====================================== void lcd_uint(unsigned int u, unsigned char pos){ unsigned char zero=0; unsigned int Dtemp; lcd_goto(pos); lcd_putchar_0(u/1000+0x30, &zero); // mille (elimine '0' non significatif) Dtemp = u%1000; lcd_putchar_0(Dtemp/100+0x30, &zero); // cent Dtemp = u%100; lcd_putchar_0(Dtemp/10+0x30, &zero); // dix lcd_putchar(Dtemp%10+0x30); // unite } //================================================== ====================================== // Entree analogique Mode 8 bits (justify) // Renvoie la tension d'alim 12V //================================================== ====================================== unsigned char ana12(void){ unsigned char volt; ADGO = 1; while(ADGO); volt = ADRESH + (ADRESH>>3); // volt = ADRESH*(1+1/8) return volt; } //================================================== ====================================== // Valeur ANA Mode 10bits //================================================== ====================================== void adc_read(unsigned char channel, unsigned int* val) { //0xC1; // enable ADC, RC osc. ADCON0 = (channel << 3) + 0x81; // => Fosc/32, enable ADC ADGO = 1; while(ADGO); // wait for conversion complete *val = (unsigned int)(ADRESH<<8) + ADRESL; } //================================================== ====================================== // Sortie PWM pour buzzer // Timer 2 presc : 1:16 // => PR2=0 => 115KHz, 12=> 8.8KHz, 64=> 1700Hz, 255=> 450Hz //================================================== ====================================== void init_pwm(void) { // *** INITIALISATION MODULE PWM *** // (1) Initialisation de la periode PWM (PR2 register). // PWM period = [(PR2) + 1] ? 4 ? TOSC ? (TMR2 prescale value) // >>TOSC = 1/7.3728MHz = 0.136 us PR2 = 64; // 64 -> 30.769KHz // (2) Initialisation du rapport cyclique PWM (CCPR1L register & CCP1CON<5:4> bits). // PWM duty cycle = (CCPR1L:CCP1CON<5:4>) Tosc ? (TMR2 prescale value) //CCPR1L = 0; // duty = 0% ; CCPR1L = 64 -> 100% CCPR1L = PR2 >> 2; // duty = 50% CCP1CON = 0x00; // PWM off + LSB = 0x0 // (3) broche CCP1 en sortie (TRISB<3> bit = 0). // OK // (4) Initialisation du prescaler et activation du TMR2 (T2CON). //T2CON = 0b00000100; // post 1:1, T2 on, pre 1:1 //T2CON = 0b01111100; // post1:16?, T2 on, pre 1:1 T2CON = 0b00000110; // post1:1, T2 on, pre 1:16 // (5) Activation du module PWM. CCP1CON = 0b00001100; // PWM on + LSB = 0x0 } //================================================== ====================================== // Mise a jour PWM (nouvelle frequence duty 50%) // FPWM = 1 / ((PR2+1)*4*TOSC*TMR2presc) avec TOSC = 0.136us, TMR2presc = 16 // = 115200 / (PR2+1) => [450Hz - 115KHz] //================================================== ====================================== void update_pwm(unsigned char val) { PR2 = val; CCPR1L = val >> 2; } //================================================== ====================================== // Port Serie RS232 8bits, no parity, 1 bit de stop //================================================== ====================================== init232(char debit){ // Baud Rate = Fosc/(16(SPBRG+1)) SPBRG = debit; // 103 : 9600bds, 51 : 19200bds, 16 : 57600bds, 8: 115kbds, 255 : 1Mbps!!! pour 16MHz // 155 : 9600bds, 77 : 19200bds, 25 : 57600bds, 12 : 115kbds pour 24MHz TXSTA = 0b00100100;//0b10100100; // Asynchronous, 8bits, TXEN, Asynchronous, High speed RCSTA = 0b10010000; // SPEN : enable port, CREN : reception continue //rx232(); // correction bug bootloader (sinon port bloque ?) /* SPBRG = DIVIDER; TXSTA = (SPEED|NINE_BITS|0x20); RCSTA = (NINE_BITS|0x90);*/ /*TRISC6=OUTPUT; TRISC7=INPUT; rx232();*/ } tx232(char val){ while(TRMT==0); // attendre que le tampon soit vide TXREG = val; // emet le caractere } char rx232(void){ unsigned char tmp; // #### UTILE ??? cf doc MidRange if (OERR==1) { //overrun Error CREN = 0; CREN = 1; tmp = RCREG; } RCIF = 0; // reset flag ISR return RCREG; // retourne le caractere recu } // ecrit une string de caracteres sur le port serie tx232_puts(const char * s){ while(*s) tx232(*s++); } /*// detection de reception char rx232_detc(void){ while(!RCIF); return rx232(); }*/ // ecrit 2 caracteres ascii tx232_2ascii(unsigned char car){ tx232(hexa2ascii(car >> 4)); tx232(hexa2ascii(car & 0x0F)); } //================================================== ====================================== // LECTURE d'un octet dans l'EEPROM //================================================== ====================================== unsigned char readEE(unsigned char adr){ //return EEPROM_READ(adr); // bug -W-3 no effect !! EEADR = adr; // selectionne la bonne adresse EEPGD = 0; // memoire donnees RD = 1; // commence la lecture return EEDATA; // renvoie l'octet lu- } //================================================== ====================================== // ECRITURE d'un octet dans l'EEPROM //================================================== ====================================== writeEE(unsigned char adr, unsigned char data){ //EEPROM_WRITE(adr, data); // avec blocage ISR + remise en route ISR /*//char tmp; if (GIE==1) CARRY = 1; // tmp = 1; else CARRY = 0; // tmp = 0; while (WR==1); // attend la fin de l'ecriture precedante EEADR = adr; // selectionne la bonne adresse EEDATA = data; // donnee a ecrire EEPGD = 0; // memoire donnees WREN = 1; // autorise l'ecriture GIE = 0; // desactive les ISR si activees EECON2 = 0x55; // nombres magiques EECON2 = 0xAA; // WR = 1; // commence l'ecriture GIE = CARRY; //(bit)tmp; // reactive les interruptions WREN = 0; // interdit l'ecriture */ // HI-TECH macro + Microchip P43 ex4-2 while(WR)continue; // attends la fin de l'ecriture precedante EEADR=adr; // selectionne la bonne adresse EEDATA=data; // donnee a ecrire EEPGD=0; // memoire donnees WREN=1; // autorise l'ecriture CARRY=0; // sauvegarde & desactive GIE if(GIE) CARRY=1; GIE=0; // desactive les ISR si activees EECON2=0x55; // nombres magiques EECON2=0xAA; WR=1; // commence l'ecriture if(CARRY) GIE=1; // reactive les interruptions WREN=0; // interdit l'ecriture } /* // ajoute 37 octets ROM // A TESTER //================================================== ====================================== // STOCKAGE variables RAM persistant //================================================== ====================================== // LECTURE d'une suite d'octet dans l'EEPROM : ZONE PERSISTANTE // appel : read_from_eeprom(_Lnvram, _Hnvram-_Lnvram); //================================================== ====================================== read_from_eeprom(char * start, unsigned char length){ unsigned char i; for(i=0; i<length; i++){ *start = readEE(i); start++; } } //================================================== ====================================== // ECRITURE d'une suite d'octet dans l'EEPROM : ZONE PERSISTANTE // appel : write_to_eeprom(_Lnvram, _Hnvram-_Lnvram); //================================================== ====================================== write_to_eeprom(char * start, unsigned char length){ unsigned char i; for(i=0; i<length; i++){ writeEE(i, *start); start++; } }*/ //EOF// | |
I don't even need to look at the source... The problem is that 1x16 LCDs are mapped differently from 2x16 LCDs. In the 2x16 LCD that was originally used, the character positions on the first line are at LCD addresses 0x00-0x0F, and the positions on the second line are at addresses 0x40-0x4F. Since he was only using the first line, the author of your code could display strings simply by writing to consecutive LCD addresses in the range 0x00-0x0F. On your 1x16 LCD, though, the first 8 positions are at addresses 0x00- 0x07, BUT THE NEXT 8 ARE AT 0x40-0x47! You'll need to modify your LCD display routines so they'll write to 0x40-47 instead of to 0x08- 0x0F. If you don't have access to the LCD display routines (if they're in a library or something), you may be able to work around the problem by displaying every string TWICE: Once as you're doing it now (starting at 0x00 or whatever address x is specified in the code), and then again at 0x38 (or at 0x38 + x). The duplicate writes won't hurt anything; they'll just slow things down a little. Good luck... BTW, if you require further help, do a search for "lcd routines+USA."
__________________ these colors don\'t run.... | |
| code, revew |
