| hi i am trying to use a pic to sense for alcohol content, i am going to be using a pot as the sensor as we cannot get hold of one. therefore i want to mimic the circuit. basically all i want it to do is light either and led stating "dont drive" or "ok to drive". So i was going to have two inputs there for if the voltage input to one pin is higher than the other(reference) i want the led to come one. The problem is i am unsure how to read inputs into a pic, i have made the code below, i have not tested it yet but before i do i wanted to make sure i have not missed anything out. P.S the delay is put in there for the heater in the sensor (not being used in this case) Finally i have never wired up a PIC using the internal occilator. do i just need to add 5V and 0V anything else i need to add? '************************************************* *************** '* Name : groupproject.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2005 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 23/01/2005 * '* Version : 1.0 * '* Notes : * '* : * '************************************************* *************** xtal=4 '4mhz symbol LED = Portb.0 'Delay on led symbol LED2 = Portb.1 'output led1 symbol LED3 = Portb.2 'output led2 SYMBOL PIN1 = PORTB.3 'inputs SYMBOL PIN2 = PORTB.4 'inputs INPUT PORTB.3 'defining input INPUT PORTB.4 'defining input Delayms 40000 'sensor warm up time 40secs High LED 'sensor warm led on after 40secs Start: 'start Low LED2 'led off Low LED3 'led off IF PIN1 > PIN2 THEN High LED2 'if pin1 is less than pin2 make led come on IF PIN2 > Pin1 THEN High LED3 'if pin2 is less than pin1 make led come on Goto Start 'go back to start | |
| i think the above is wrong i have now changed it to this, P.S the value "50" is totally random at the moment. ************************************************** ************** '* Name : groupproject.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2005 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 23/01/2005 * '* Version : 1.0 * '* Notes : * '* : * '************************************************* *************** xtal=4 '4mhz DIM VAR1 as BYTE symbol LED = Portb.0 'Delay on led symbol LED2 = Portb.1 'output led1 symbol LED3 = Portb.2 'output led2 'SYMBOL PIN1 = PORTB.3 'inputs 'SYMBOL PIN2 = PORTB.4 'inputs INPUT PORTB.3 'defining input 'INput PORTB.4 'defining input Low LED2 'led off Low LED3 'led off Delayms 40000 'sensor warm up time 40secs High LED 'sensor warm led on after 40secs Start: 'start VAR1 = POT PORTB.3 , 255 IF VAR1 > 50 THEN High LED2 'if pin1 is less than pin2 make led come on IF VAR1 < 50 THEN High LED3 'if pin2 is less than pin1 make led come on Goto Start 'go back to start the problem with this method is there are only 255 steps over a wide resistance range there for sensing a very small change is not possible, is there a way round this? | |
