Thanks nigel.
btw my project has to be done with 8052 micro. concerning about the BCD, u mean i just need to write the code to output the data as demical value, no BCD chip is needed, am i right??
Anyone has any idea about how to start with assembly language?
Originally Posted by Nigel Goodwin Quote: |
Originally Posted by soohino im doing a project. it deals with a 8-bit ADC to convert my analog data into digitized data then the data would be fit into 8052. after processing, the digitized data would be output in 7 segment display. analog data > ADC > 8052 microC > BCD decoder > 7 segment display
i have no idea how to start off to write my assembly language code. anyone have a hint for me how to write it?? thanks!! | I can't help you with 8052 code, but there's no need for a BCD decoder, the micro can do everything required quite easily.
If you would like to use a PIC instead, my tutorials show everything you need - plus it's a cheap single chip solution. |
