hi its not the first time i use one of the application notes from microchip and i find that the code has bugs and it dose'nt work. this time its the AN690 i wonder if anyone tryed to use this code , this is what i did i made the PCB for there schematic but i used 16F877 insted of the 16C54 , i modefied the code to work with the mid range PIC but the display never worked right, after i got frustrated with the code i thought iam doing something wrong, i programed a PIC16C54 and wired it up to the display , and just like i thought it did not work .!!! i dont know why they do that ......are they expecting us to troubelshoot the code???. any way can someone please take alook at the code and find the bugs or mabe someone has aalready constructed the AN690 and found the erros. the problem's are with the display updating and mapping. thanks. | |
I haven't actually constructed this, nor tried to extract the code from the PDF and simulate it, but I'll take a stab at it. You say you are having problems with the display. The sheet you attached says that it is using common cathode 7-segment displays. Are you using CC's, which recieve the active high data on individual anodes, or are you erroneously using common anode displays which are expecting active low data on the cathodes? Another thing is that they are using PNP transistors with the collector (diagonal without the arrow) grounded. Code lines 00091 through 00095 confirm that they want a PNP, because the single 0's they have bringing the base (straight line) low activates the connection to ground. I find their use of PNPs peculiar, as I have only used a PNP with the emitter (arrowed line) connected to supply voltage. The collector then powers anything connected to it whenever the base input drops below the emitter voltage. With NPN's, however, I connect the emitters to ground. The collector provides a sink to whatever is connected to it when the base voltage rises above the emitter. Those are the only two configurations I have ever used. When I look at their diagram with the PNPs emitter connected to the common cathode of the LEDs, I have to wonder what condition would cause the transistor to activate? I can only assume: When the base voltage drops below whatever random signal is momentarily present on the LEDs, it shorts the grounded collector "up" to the emitter, providing a sink for the display. I don't like that. It may be perfectly acceptable, or maybe they just had some PNPs laying around. I don't know. But if I was designing the circut, I would put NPN transistors in place, ground the emitters, connect the collectors to the common cathodes, and change lines 00091 to 00095 of the code to reflect that change: Code: DISP1 equ B’00000001’ DISP2 equ B’00000010’ ; Mapping of Active Display Selection (PORT_A) DISP3 equ B’00000100’ DISP4 equ B’00001000’ DISPOFF equ H’00’ Another thing you might want to double check is a decoupling capacitor. Some people say that you don't need them for some applications, and they're right. You can make simple circuits that work acceptably without any caps. Sometimes adding a capacitor somewhere on your board between the supply and ground will fix a problem. I found that out when a capacitor made my own homemade clock start working. 8) Sometime you may even need to put a capacitor right beside the PIC's own power and ground pins. If these suggestions don't fix your problem, perhaps you could describe in more detail exactly what is happening? | |
HI first of all the display lights up no problem the digits can be drived on by one i did a test code on them they are fine. i am using a CA 7-segments .(look at the drive.gif) .oh and the IC between the PIC and the disply is a ULN2003 (7 NPN's) the errors are 1. the display should startup at 12:00 it starts at 00:00 2. from R to L the first 3 digits count together MINUTS 3. the forth digit count 10's MINUTS iam not worried for know about the function off the switches iam trying to get the display correct. note: my display lines are b'00000001' b'00000010' b'00000100' b'00001000' to drive a NPN i tryed re assigne the digits to the disply postion in the CYCLE lines at the end fo the CODE, i got the MINUTS in the first digit (0) and the digit next to it count 10's but the 3rd and forth they folow the MINUTS insted fo HOURS. thanks | |
hi just an update ................you are right i did not pay attention to the transistors they are PNP and now the clock works fine and the display is fine . and the maze is the display will not show the correct numbers if i use NPN transistors even if i change the disply BITS in the code. isnt against electricty rules to use PNP on the CC of a disply or they are using this TRICK so the PNP leaks to the display not to sink!!!!!!!!!!!!!!! NOW i have to find a diffrent way to drive my CA displys and make the code work for them. | |
hi did 'not hear from you the code is working fine with the CC displays and PIC16C54 on the proto_ board...BUT not with my big CA displays and 16F877 . iam posting my code can you please take a look and kind direct me in the right way to fix it, the big CA diplay's as its wired working fine i did some test codes and i can display scaned numbers on it with no problem. | |
| | #6 |
I didn't realize you were asking a question. You mentioned it was working fine, then you said you were going to set off to making it work with common anode displays. It you look at their connection diagram, you will see that B0 is connected to the decimal point, B1 to segment A, B2 to segment B, etc..., and you see the position of the segments in the picture. You did not change your equates for ZERO, ONE, TWO, etc. They are still the same as the ones given on the original program listing, starting with line 00068. These need to be changed. Code: A --- F| G |B --- These are the 7 segment labels E| |C --- D Now, if we want to switch over to driving common anode displays, the way to turn on a particular segment is to output grounds. For the number three, you would want A, B, C, D, and G grounded. Give them zeros, and everything else ones. 0110 0001 = H'61'. Do the rest of your numbers like that. | |
| | #7 |
thanks for replaying i agree with you on the sigments change ...but that will work if the cathod sigments conected directly to PORTD. in my case if you look at DRIVE.GIF i have a ULN2003 driving the sigments. witch mean i need a 1 at the inputs to have a (0) at the output thats why i left the sigments decoding the same way. like i said i can display all the numbers fine if i send test code to the displays. its just the clock code will not work!!! this is a code for the PIC54 and iam using F877 dose the RAM file reasigment affect the code its start at 0x08 and i start it at 0x20 for the F877. | |
| | #8 |
any suggestion guy's !!!
| | #9 |
whoah.. lol what was that mess..that you call clock code.. maybe if you use the code tab in the post screen it will look better.. | |
| | #10 |
Do you have anything better...? this code was written by MICROCHIP engineers 1997 it's called AN590. it was for the PIC16C54 , i only changed it to work with PIC16F877 and i am having problems to make it work and i only get a laugh from you thanks | |
| | #11 | |
Code: ;********************************************************** ;* J-CLOCK.ASM ;********************************************************** ;* ;* DEC 05 2004 ;* Assembled with MPASM V5.70.40 ;********************************************************** ;* SW2 = RA4 (no sw1) ;* SW3 = RA5 ;* TEMP_port = AN0 . AN2 . AN3 (not used for now) ;* T1 = RB0 ;* T2 = RB1 ;* T3 = RB2 ;* T4 = RB3 ;* RD0 = DP ;* RD1 = SIG A ;* RD2 = SIG B ;* RD3 = SIG C ;* RD4 = SIG D ;* RD5 = SIG E ;* RD6 = SIG F ;* RD7 = SIG G ;* ;********************************************************** list p=16F877 ; Include file, change directory if needed include C:\PROGRA~1\MPLAB\P16F877.inc ;************************** Header ************************* ;***** VARIABLE DEFINITIONS w_temp EQU 0x70 ; variable used for context saving status_temp EQU 0x71 ; variable used for context saving ; POINTER equ 0x00 TMR0 equ 0x01 ; ; REG. Bits CARRY equ 0 ; Carry Bit is Bit.0 of F3 C equ 0 DCARRY equ 1 DC equ 1 Z_bit equ 2 ; Bit 2 of F3 is Zero Bit Z equ 2 P_DOWN equ 3 PD equ 3 T_OUT equ 4 TO equ 4 ; ZERO equ H'7E' ONE equ H'0C' TWO equ H'B6' THREE equ H'9E' FOUR equ H'CC' FIVE equ H'DA' SIX equ H'FA' ; Mapping of segments for display (PORT_D) SEVEN equ H'0E' EIGHT equ H'FE' NINE equ H'CE' COLON equ H'01' T equ H'F0' BLANK equ H'00' ; MAXNTHS equ D'12' ; constants for timer variable count up MAXSECS equ D'196' ; variables roll over in HEX at time roll over, see variable MAXMINS equ D'196' ; explanation MAXHRS equ D'244' MINHRS equ D'243' ADJMIN equ D'9' ; number of nths that need to be subtracted each minute ADJHR equ D'34' ; nths added each hour for accurate time ADJDAY equ D'3' ; nths subtracted each 1/2 day rollover ; DISP1 equ B'00000001' DISP2 equ B'00000010' ; Mapping of Active Display Selection (PORT_b) DISP3 equ B'00000100' DISP4 equ B'00001000' DISPOFF equ H'00' SWITCH equ B'00110000' ; Activate RA0,2,3 for switch inputs ; ; Flag bit assignments SEC equ H'0' ; update time display values for sec, min, or hours MIN equ H'1' HRS equ H'2' CHG equ H'3' ; a change has occurred on a switch or to a potentially displayed value SW1 equ H'4' ; Flag bit assignments - switches that are on = 1 SW2 equ H'5' ; SW1 is Seconds-minutes, SW2-hours, SW3-mode SW3 equ H'6' SW_ON equ H'7' ; a switch has been pressed ; ; VARIABLES keys equ H'31' ; variable location - which keys are pressed? bit0/sw1... flags equ H'32' ; bit flags; 0-SEC, 1-MIN, 2-HRS, 3-CHG, 4-SW1, 5-SW2, 6-SW3 ; equ H'33' ; Not Used display equ H'34' ; variable location - which display to update digit1 equ H'35' ; Rightmost display value digit2 equ H'36' ; Second display from right digit3 equ H'37' ; Third " " " digit4 equ H'38' ; Fourth (and Leftmost) ; ; timer variables start at a number that allows rollover in sync with time rollover, ; i.e. seconds starts at decimal 195 so that sixty 1-second increments causes 0. sec_nth equ H'39' ; seconds, fractional place seconds equ H'3A' ; seconds minutes equ H'3B' ; minutes hours equ H'3C' ; hours var equ H'3E' ; variable for misc math computations count equ H'3D' ; loop counter variable count2 equ H'3F' ; 2nd loop counter for nested loops ; ;******************************************************************************** | ||
| | #12 |
thats why i suggested using the CODE tab..
| | #13 |
thanks for replaying i did find the lines that i should change (the hard way) and the display part is working fine now, iam going to work on remapping the switches from PORTB to PORTA and change it from LOW to HI. if i need more help i will post the code as .ASM in ZIP format. thanks any way | |
| | #14 | |
How are you seeing all that A) displayed in this message thread and B) without line feed/returns? When I look at this thread, I see his j_clock.txt as an attachment that you can download. When I click on the paperclip it downloads, and then opens in Notepad, in nice neat readable form. I'm not sure how you are experiencing the problem that you are. :? | ||
| | #15 |
You can post your code like this .. in the "post a Reply" screen just paste your code AFTER you click on the the code tab.. Code: ;
LIST P = 16C54, n = 66
; Clock
; PROGRAM DESCRIPTION
; This program runs on a PIC16C54.
; Hardware Description
; DISPLAYS
; Four 7 segment displays are multiplexed. The segments are tied together, with
; the common cathode pins broken out separately. The display appears as a clock
; with a center semicolon ( 88:88 ). The segments are assigned to Port B, with the
; semicolon being RB0, and segments A through F assigned as RB1 to RB7 respectively.
; The four common cathodes are attached to the four Port A pins through transistors.
; RA0 for LED0, RA1/LED1... through LED3. The center semicolon is made from the decimals
; of LED 2 and 3. LED display 2 is turned upside down to put its decimal into position,
; but it is wired with a corrected A-F assignment to compensate. Both decimals
; are tied together at RB0, but the display cathodes are still separate.
; SWITCHES
; Because all twelve I/O pins are already used for the muxed displays, the four
; switches must be switched in alternatingly through software. The switches
; lie across Port B pins, which wil be changed to inputs momentarily during read
; and changed back to outputs during display.
; Program: CLOCK54.ASM
; Revision Date:
; 1-16-97 Compatibility with MPASMWIN 1.40
PIC54 equ H'01FF'
PIC56 equ H'03FF'
POINTER equ H'00'
RTCC equ H'01'
PC equ H'02'
STATUS equ H'03' ; F3 Reg is STATUS Reg.
FSR equ H'04'
PORT_A equ H'05' ; 7 segment Display Common Cathodes
PORT_B equ H'06' ; Center Colon and Muxed Display Segments (Switches when inputs)
; STATUS REG. Bits
C equ 0
DCARRY equ 1
DC equ 1
Z equ 2
P_DOWN equ 3
PD equ 3
T_OUT equ 4
TO equ 4
PA0 equ 5 ;16C5X Status bits
PA1 equ 6 ;16C5X Status bits
PA2 equ 7 ;16C5X Status bits
ZERO equ H'7E'
ONE equ H'0C'
TWO equ H'B6'
THREE equ H'9E'
FOUR equ H'CC'
FIVE equ H'DA'
SIX equ H'FA' ; Mapping of segments for display (PORT_B)
SEVEN equ H'0E'
EIGHT equ H'FE'
NINE equ H'CE'
COLON equ H'01'
T equ H'F0'
BLANK equ H'00'
MAXHRS equ D'244'
MINHRS equ D'243'
DISP1 equ B'11111110'
DISP2 equ B'11111101' ; Mapping of Active Display Selection (PORT_A)
DISP3 equ B'11111011'
DISP4 equ B'11110111'
DISPOFF equ H'FF'
SWITCH equ B'00001110' ; Activate RB1-3 for switch inputs
MIN equ H'1'
HRS equ H'2'
SW3 equ H'6'
; VARIABLES
keys equ H'08' ; variable location - which keys are pressed? bit0/sw1...
flags equ H'09' ; bit flags; 0-SEC, 1-MIN, 2-HRS, 3-CHG, 4-SW1, 5-SW2, 6-SW3
; equ H'0A' ; Not Used
display equ H'0B' ; variable location - which display to update
digit1 equ H'0C' ; Rightmost display value
digit2 equ H'0D' ; Second display from right
digit3 equ H'0E' ; Third " " "
digit4 equ H'0F' ; Fourth (and Leftmost)
sec_nth equ H'10' ; seconds, fractional place
seconds equ H'11' ; seconds
minutes equ H'12' ; minutes
hours equ H'13' ; hours
var equ H'14' ; variable for misc math computations
count equ H'15' ; loop counter variable
count2 equ H'16' ; 2nd loop counter for nested loops
; Initialize Ports all outputs, blank display
START movlw H'03' ; set option register, transition on clock,
option ; Prescale RTCC, 1:16
movlw 0
tris PORT_A ; Set all port pins as outputs
tris PORT_B
movlw BLANK
movwf PORT_B ; Blank the display
bcf STATUS,PA1
bcf STATUS,PA0
; initialize variables
movlw H'01'
movwf RTCC ; set RTCC above zero so initial wait period occurs
movlw H'FE'
movwf display ; initializes display selected to first display.
movlw BLANK ; put all displays to blank, no visible segments
movwf digit1
movwf digit2
movwf digit3
movwf digit4
movlw MAXNTHS ; set timer variables to initial values
movwf sec_nth
movlw MAXSECS
movwf seconds
movlw MAXMINS
movwf minutes
movlw H'FF' ; hours start at 12 which is max at FF
movwf hours
movlw H'00'
movwf flags
;? call converts for minutes and hours to initialize display vsriables
MAIN
; wait for RTCC to roll-over
RTCC_FILL
movf RTCC,0
btfss STATUS,Z ; note, RTCC is left free running to not lose clock cycles on writes
goto RTCC_FILL
incfsz sec_nth,1 ; add 1 to nths, n X nths = 1 sec, n is based on prescaler
goto TIME_DONE
movlw MAXNTHS
movwf sec_nth ; restore sec_nths variable for next round
CHECK_SW
btfss flags,SW_ON ; if no switches press, bypass this
goto SET_TIME
btfsc flags,SW1
goto SET_TIME ; if seconds display is pressed, do not change time
movlw MAXSECS
movwf seconds ; reset seconds to zero when setting clock
movlw H'7F'
movwf sec_nth ; advance second timer 1/2 second to speed time setting
btfss flags,SW2
goto HOURSET ; minutes do not need changing, check hours
movlw H'AF'
movwf sec_nth ; advances timer faster when setting minutes
incfsz minutes,1
goto HOURSET
movlw MAXMINS
movwf minutes
HOURSET btfsc flags,SW2
goto CHECK_TIME ; not changing hours
incfsz hours,1
goto CHECK_TIME
movlw MAXHRS
movwf hours
goto CHECK_TIME ; since no timing is required, go to display changes
SET_TIME
bsf flags,SEC ; seconds, if displayed, should be updated
bsf flags,CHG ; a flag change was made.
incfsz seconds,1 ; add 1 to seconds
goto TIME_DONE
movlw MAXSECS
movwf seconds ; restore seconds variable for next round
bsf flags,MIN ; minutes, if displayed, should be updated
bsf flags,CHG
movlw ADJMIN
subwf sec_nth,1 ; subtraction needed adjustment for each minute
incfsz minutes,1 ; add 1 to minutes
goto TIME_DONE
movlw MAXMINS
movwf minutes ; restore minutes variable for next hour countdown
bsf flags,HRS
bsf flags,CHG
movlw ADJHR
addwf sec_nth,1 ; add needed adjustment for each hour
incfsz hours,1 ; add 1 to hours
goto TIME_DONE
movlw MAXHRS
movwf hours ; restore hours variable for next round
movlw ADJDAY
subwf sec_nth,1 ; subtraction adjustment for each 1/2 day rollover
TIME_DONE
btfss flags,CHG ; if no switches or potentially dislayed numbers were
goto CYCLE ; changed, then skip updating display variables
CHECK_SECONDS
; if seconds is button was pushed and not mode display seconds
btfss flags,SW1
goto CHECK_TIME
movlw H'00'
movwf digit2 ; 3rd digit variable used to store temp hex value for hours display
movwf digit3
movwf digit4
movlw MAXSECS
subwf seconds,0
movwf digit1 ; 1st digit variable temporarily holds hex value for seconds display
goto SPLIT_HEX
CHECK_TIME
movlw H'00'
movwf digit4 ; zero out tens places in case there is no tens increment
movwf digit2
movlw MINHRS
subwf hours,0
movwf digit3 ; 3rd digit variable temporarily holds hex value for hours
movlw MAXMINS
subwf minutes,0
movwf digit1 ; 1st digit temporarily holds hex value for minutes
SPLIT_HEX ; split into two hex display variables and write
movlw H'02'
movwf count ; loop to convert each number - seconds - or minutes and hours
;1st time through, FSR = digit1, 2nd time FSR = digit3
movlw digit1 ;
movwf FSR ; address of digit1 into File Select Register enables POINTER
goto LOOP ; this loop is used to modify the minutes/seconds place
LOOP2 movlw digit3
movwf FSR ; this loop is used to modify the hours place
LOOP
movlw D'10'
subwf POINTER,1 ; find out how many tens in number,
btfsc STATUS,C ; was a borrow needed?
goto INCREMENT_10S ; if not, add 1 to tens position
addwf POINTER,1 ; if so, do not increment tens place, add ten back on to get 1s
goto NEXT_DIGIT
INCREMENT_10S
incf FSR,1 ; bump address pointed to from 1s positoion to 10s
incf POINTER,1 ; add 1 to 10s position as determined by previous subtract
decf FSR,1 ; put POINTER value back to 1s place for next subtraction
goto LOOP ; go back and keep subtracting until finished
NEXT_DIGIT
decfsz count,1
goto LOOP2
CONVERT_HEX_TO_DISPLAY ; converts hex number in digit variables to decimal display code
movlw digit1
movwf FSR ; put the address of the first digit into the FSR to enable POINTER
movlw H'04'
movwf count ; prepare count variable to loop for all four displays
NEXT_HEX
movf POINTER,0 ; get the hex value of the current digit variable
call RETURN_CODE ; call for the hex to decimal display conversion
movwf POINTER ; put the returned display code back into the digit variable
incf FSR,1 ; increment the pointer to the next digit variable address
decfsz count,1 ; allow only count(4) times through loop
goto NEXT_HEX
FIX_DISPLAY
movlw ZERO
subwf digit4,0
btfss STATUS,Z
goto FIX_SEC
movlw BLANK
movwf digit4
FIX_SEC btfss flags,SW1
goto CLEAR_FLAGS
movwf digit3
CLEAR_FLAGS
movlw H'F0'
andwf flags,1 ; clear the lower 4 flag bits to show update status
CYCLE
movlw DISPOFF
movwf PORT_A ; Turn off LED Displays
movlw SWITCH
tris PORT_B ; Set some port B pins as switch inputs
movlw H'0F'
andwf flags,1 ; reset switch flags to zero
nop ; nop may not be needed, allows old outputs to bleed
nop ; off through 10k R before reading port pins
nop
movf PORT_B,0
movwf var
btfss var,1
goto SWITCH2
bsf flags,CHG
bsf flags,SW1
bsf flags,SW_ON
SWITCH2 btfss var,2
goto SWITCH3
bsf flags,CHG
bsf flags,SW2
bsf flags,SW_ON
SWITCH3 btfss var,3
goto SETPORT
bsf flags,CHG
bsf flags,SW3
bsf flags,SW_ON
SETPORT movlw H'00'
tris PORT_B
movlw BLANK
movwf PORT_B
; determine which display needs updating and cycle it on
btfss display,0 ; if 1st display, get 1st digit
movf digit4,0
btfss display,1 ; if 2nd display, get 2nd digit
movf digit3,0
btfss display,2 ; if 3rd display, get 3rd digit
movf digit2,0
btfss display,3 ; if 4th display, get 4th digit
movf digit1,0
movwf PORT_B ; put the number out to display
btfsc sec_nth,7
bsf PORT_B,0 ; sets colon decimal on %50 duty using highest bit
movf display,0 ; get display needing cycle on
movwf PORT_A ; enables proper display
movwf display ; returns old w if not done, new w if resetting display
rlf display,1 ; rotate display "on" bit to next position
bsf display,0 ; assures a 1 on lowest position since rotated carry is zero
btfss display,4 ; check if last display was already updated
bcf display,0 ; if it was, set display back to 1st (bit 0 set)
goto MAIN
RETURN_CODE
addwf PC,1
retlw ZERO
retlw ONE
retlw TWO
retlw THREE
retlw FOUR
retlw FIVE
retlw SIX
retlw SEVEN
retlw EIGHT
retlw NINE
org PIC54
goto START
END
| a590, application, microchip, or display |
