Old 20th November 2004, 03:53 AM   (permalink)
Default PIC16F877 serial program
I am programming a PIC16F877 serial port. I am trying to send to the serial port the character 'e'. I am using hyperterminal to view the said character. I use 9600 baud rate, one stop bit,no parity and no hardware control settings. But the character I am trying to send to the hyperterminal does not seem to appear, mostly the its just a series of 1's and s.
here is my code. Your comments and suggestiions will be appreciated! Thank you in advance!!!
;source code(firmaware fragment) for the PIC16F877 serial communications
#include "P16f877.inc"
__config _wdt_off & _pwrte_on & _xt_osc & _boden_on & _wrt_enable_on & _lvp_off & _cpd_off
errorlevel -302
#define transmitEnable portc,5
cblock h'20'
temp
char
endc
org h'0000'
init
bcf STATUS,RP1
bsf STATUS,RP0 ;selects bank1
movlw b'10000000'
movwf TRISC ;makes pin7<RX> of portC input
movlw b'1000000' ;Fosc = 12Mhz
movwf SPBRG ;9600 baud rate hispeed
bsf TXSTA,BRGH ;bit2: High speed
bcf TXSTA,SYNC ;bit4: Asynchronous mode
bcf TXSTA,TX9 ;bit6: 8-Bit Transmit Enable bit
bcf PIE1,TXIE ;bit4: USART transmit Interrupt Enable bit
bsf TXSTA,TXEN ;bit5: Transmit enable bit
bcf STATUS,RP0 ;selects bank0
movlw b'10010000'
movwf RCSTA ;bit7: Serial Port Enable bit
bsf transmitEnable
main
call message_one
goto main
message_one
movlw d'101'
call sendit
call delay
call delay
call delay
return
sendit
btfss PIR1,TXIF ;poll bit4: Transmit Interrupt Flag
goto sendit
movwf TXREG
return
delay
movlw d'255'
movwf char
movwf temp
delayloop
decfsz char
goto delayloop
decfsz temp
goto delayloop
return
end
Erwin_Macaraig is offline
Old 20th November 2004, 05:30 AM   (permalink)
Looking at your code, your baud rate setting may be incorrect. Assuming you're using a 12Mhz crystal as comments in your code suggest, the value of b'1000000' or 40h for SPBRG is wrong.
With BRGH=1, the correct value for 9600baud @ 12Mhz is D'77'.
"Having to do with Motion Control"
motion is offline
Old 20th November 2004, 07:02 AM   (permalink)
You might also try my tutorials, I have an RS232 one which includes the 16F876/7 - but using a 20MHz clock - as motion says, you would have to make changes for your clock speed.
Old 21st November 2004, 04:31 PM   (permalink)
thank you guys. But do you think that the remaining code are ok?
