Old 19th November 2004, 08:04 AM   #1
Default Multi-Array LED Display Module
My professor is asking me to find a schematic diagram of a MULTI-ARRAY LED DISPLAY MODULE and build it. It will be connected to an I/O interface module which I already have. The display module must be controlled by the I/O interface.The diagram can be found at http://www.southwest.com.au/~jfuller/sio5.html. Pls. give me some tips on how to build a multi array LED display module and where I can find the schematic diagram. Thanks :P
shreik is offline
Old 19th November 2004, 11:30 AM   #2
it is interresting that you are using Visual Basic for your project.
http://www.southwest.com.au/~jfuller/vb/vbout.htm
i would enjoy learning that..
williB is offline
Old 19th November 2004, 02:47 PM   #3
So this multi array module will be connected to the circuit that is in the link?
You are going to use VB to control it?
Anyhoo, shift registers are what you need, I'm currently working on a similar project, only I'm going to use a micro to control the I/O
You shift the bits in at high speed, that is, you send the bits into the SR one at a time, this speed is determined by the clock signal. there are 8 bits per register so once you shift the 9th bit in, it is carried over to the next SR. (Sorry if I confused you, I gotta run to class, maybe someone else can explain it more or they have a better schematic)
heres a quick schematic
Jeff
jrz126 is offline
display, led, module, multiarray
