| Im having trouble creating PIC based counter system i want to count how many button presses (push and release increases counter by 1) was on RA0 and RA1. i can write code that counts one push at a time, but there may be cases where one button is pressed down, then second button is pressed down, then button one or two is released (counter goes +1 here) if other button is released then (counter goes +1) can anyone help me with that and sorry for my bad english msn: andero@cma.ee | |
| Use 2 diffenrent counter variables in your PIC's RAM. If one switch is released its corresponding variable will be incremented and similar for other.
__________________ "There is no way to peace, peace is the way!" | |
| i thaught about it, but i cant seem to generate code that can monitor those pushes/releases im new with pic risc assembler those pushes come in randomly and have random duration so i need a code that scans for pushes paralelly not serialy can anyone give an example or even send me that code? | |
| What do you mean by parallel and serial scanning? I think you are talking about bit-scanning and scanning the entire port in one shot. To solve your problem, you can use Internal Timer to periodically scan the swithces. Store the data of previous scan in some variable say 'old' and then store the newly scanned data into 'new'. Compare both of them and if they are not equal, that means there was a push, or release of button. If the bit changed from 0 to 1 it was push (this depends on your switch logic) and vice-versa.
| i use that code for counter loop movf TRISA bcf STATUS,Z xorwf stat btfss STATUS,Z call changed goto loop changed movf TRISA movwf stat call add ; movlw 'x' ; call snd retlw 0x00 what is wrong? | |
