| i need ur suggestions and help to make a project study.... anything relted to robotics, microprocessor, anything electronics pls, pls, pls....... thank you in advance!!!! godspeed!!!!
__________________ i\'m currently a 4th year bs electronics and communications engineering student. i hope we can help each other.... ciao!!!! | |
| make a propeller clock, these are pretty cool, there was someone in the projects section that was building one. There is plenty of info on the net about them too. Also, why do people put pls, pls, pls,, !!!!!!!!'s, and lots of .......'s in their posts? It is quite annoying
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| Make an ankle-worn pedometer that uses a two-axis accelerometer, and is thus able to calculate work done in climbing hills, as well as distance covered. | |
| | (permalink) | ||
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |||
| Make an ankle-worn pedometer that uses a two-axis accelerometer, and is thus able to calculate work done in climbing hills, as well as distance covered. how does it work?
| How would I know, you haven't designed it yet have you? I thought you were asking for suggestions. | |
| I've been sending you PM's seems you are ot responding. | |
