Old 13th October 2004, 10:18 AM   #1
Default Assembly Language???
Anyone has another assembly language support PIC16F84A... beside MPLAB IDE V 6.6... :lol:
The world without engineer is the world without control!
amady is offline
Old 13th October 2004, 03:53 PM   #2
could you explain your question a little bit? why do you want to use something other than the widely accepted MPLAB development package. i read somewhere that PIC can be programmed in about two dialects of assembly language; MPASM and TASM (or something like that). MPLAB contains the MPASM assembler and it works great. why would u want to migrate to another dialect of assembly. if u do want to try something else, try a high level language like C.
samcheetah is offline
Old 13th October 2004, 05:58 PM   #3
MPASM is the 'real' assembly for pic's, it uses all the names and terms that you find in the datasheets. It would be counterproductive to use something else.
Exo is offline
Old 14th October 2004, 01:41 AM   #4
This is because i got the problem when to generate the .hex file... the error is : succeded the 62 characters...
amady is offline
Old 14th October 2004, 01:53 AM   #5
is it fixed ?
williB is offline
Old 14th October 2004, 02:34 AM   #6
Originally Posted by "williB
is it fixed ?
What do you mean?? The error still has when i'm running the MPLAB.... :cry:
amady is offline
Old 14th October 2004, 02:58 AM   #7
Default The solution should be simple...
As far as I know, the path to the directory where the project is located should be less than 62 chars in length.
In my laptop and my PC at the bench I put the project file in the Desktop (WIN 98SE and WIN ME).
Hope this solve that awful problem.
Agustín Tomás
atferrari is offline
Old 14th October 2004, 03:06 AM   #8
Default Re: The solution should be simple...
Agustín Tomás
Thank you atferrari it work's.. i was put at my C directory...
amady is offline
Old 14th October 2004, 02:34 PM   #9
im glad things worked out for you. actually im really frustated with this type of error. the first time i started using MPASM i always got this error but then i read the error carefully and then consulted the help file. and voila!!!!!! i figured the solution. so the next time you get some error think about it a little bit and dont go for throwing out the software
Old 18th October 2004, 04:08 AM   #10
OK, thank for your advice
amady is offline
Old 22nd October 2004, 04:13 PM   #11
Default Hello guys i am in
Hey i need some help on my projects...i am trying to make a 7segment display based clock...i also have a forum www.varunulaa.com/forum in there i have posted some of my projects so ppl join they too to help.......
techknow is offline
Old 22nd October 2004, 04:49 PM   #12
Default Re: Hello guys i am in
i dont like the color ..too dark
williB is offline
Old 22nd October 2004, 08:52 PM   #13
Default Thanks for commenting
Thank for commenting...anyway i have changed the template to subsilver...now it is better i guess.Hope u guys will be interested on my projects and give me some good ideas to get forward..
Thanks willibi...thank u very much
techknow is offline
Old 22nd October 2004, 09:34 PM   #14
Default An help wanted
Does anyone have a simple asm code for LCD and PIC16F628 interface...cause i got some big codes..damm ..so i need an simple one which can print an "hello" word. cause i am also a biginner for microcontroller programing from asm. and i use MPLAB and ICPROG..i hope u guys will get me a good working and simple asm code for LCD intreface. any way thanks for willib
techknow is offline
Old 22nd October 2004, 09:48 PM   #15
Default Re: An help wanted
Try reading my tutorials!.
assembly, language
