+ Reply to Thread
Page 2 of 4
First 1 2 3 4 Last
Results 16 to 30 of 59
Thread: Assembly Language???
  1. #16
    amady Newbie
    Join Date
    Sep 2004
    Posts
    55
    Default Re: An help wanted
    Quote Originally Posted by techknow
    Does anyone have a simple asm code for LCD and PIC16F628 interface...cause i got some big codes..damm ..so i need an simple one which can print an "hello" word. cause i am also a biginner for microcontroller programing from asm. and i use MPLAB and ICPROG..i hope u guys will get me a good working and simple asm code for LCD intreface. any way thanks for willib
    You can look at Nigel's website or..http://home.iae.nl/users/pouweha/lcd/lcd.shtml
    and i need the PIC programmer from you! TQ
    The world without engineer is the world without control!
  2. #17
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default Thank you guys
    Hello amady and Nigel Goodwin...thank you guys for helping...i have visited the site that u guys mentioned...and it was very help full...tonight i will work on that and inform you guys..
  3. #18
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default Hello amady
    Do u need the circuit diagram of my picprogrammer or the software...
  4. #19
    amady Newbie
    Join Date
    Sep 2004
    Posts
    55
    Default Re: Hello amady
    all :lol:
  5. #20
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default here is ...
    Amady here is the program and the circuit that i am using..it is working perfectly..so u try it and letme know...
    http://www.ic-prog.com/index1.htm from here you can get the software and the sys file ..if u r using windows XP or NT...If u need to view a picture of the working programmer here is the link.
    http://www.varunulaa.com/forum/viewtopic.php?p=217#217
  6. #21
    williB Good williB Good
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    Default Re: here is ...
    that is a real nice circuit ..what did you use to draw it .??
  7. #22
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default I need help
    hey guys did anyone interface HT9202G to a pic16f628...cause i am trying to make a DTMF dialer...i have some difficulty to write the code. hope u guys will help me .
  8. #23
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default hey willib
    Hello willib..so u like it..i drew it on protel (the latest professional circuit drawing software) it very easy..and the best part is all the compornent library is there and PCB also can be draw to the scale..hope for more from u
  9. #24
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    have you got a link to the pdf for HT9202G ?
  10. #25
    samcheetah Newbie
    Join Date
    Dec 2003
    Location
    Pakistan
    Posts
    874
    Default Re: I need help
    ive always wanted to build a DTMF dialer with a PIC. but i havent had enough time and the knowledge of building one. can you give more info on DTMF dialers. and have u seen a good DTMF project (based on a PIC) on the net ??
  11. #26
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default hi willib
    hello willibi here is the link to HT9202G.pdf
    http://www.alldatasheet.com/datashee...K/HT9202G.html
    i am realy in need of a guy who can help me to make this work...it work with a keypad but the difficulty is when i connect it to a pic it does not..so hope for a solution
  12. #27
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default hi samcheetah
    hello samcheetah. i am trying to make HT9202G works with pic16f628 but still it did not. the difficult part is its very difficult to get an DTMF IC which can interface to pic. But i have seen another cool ic from holtek it is HT9200A and HT9200B these two ic's can be interface to a microcontroller like pic and etc...and u can get data sheet from
    http://www.alldatasheet.com/datashee...K/HT9200B.html
    This DTMF ic is very easy to interface to microcontroller...by serialy and parallel..but i could not get from my region...
    i am in maldives which is located in indian ocean and i face lots of difficulties to get compornents..i got HT9202G from a telephone. I think it is an general DTMF dialer ic which everyone use for phone applications..
    hope a good news from u..
  13. #28
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Default Re: hi willib
    Your problem is that the HT9202G is designed for a multiplexed keypad, so you can't simply connect the PIC to it - you need free-floating switches to feed the HT9202G.
    The simplest way would be to use small DIL relays fed from the PIC, one for each button - rather crude, but it would work.
  14. #29
    techknow Newbie
    Join Date
    Oct 2004
    Posts
    70
    Default hi Nigel Goodwin
    hello Nigel Goodwin...thanks for the hint..
    i thought insted of relays i can use CD4066 indeed it is an CMOS QUAD BILATERAL SWITCH it will work with PIC ,which is the voltage level is compatible. relays makes more sound anyway thanks for all that.
    http://www.alldatasheet.com/datashee...TI/CD4066.html
    can u give me an DTMF ic which can get easyly but it should be interface with PIC
  15. #30
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
+ Reply to Thread
Page 2 of 4
First 1 2 3 4 Last
Tags for this Thread
