| hey guys. i have a huge problem. i blew up my car amplifier. it is two "controllers" i dont know what they do or if i can replace them. here are the numbers: pic16c710-0479 and ds1267-100 if you can give me any advice on what they do and if i can easily replace them, i would be in your debt. thank you | |
| The DS1267 is a dual digital potentiometer chip from Maxim/Dallas. http://www.maxim-ic.com/quick_view2...._pk/2676/ln/en You should be able to order one in an electronics store and just replace it... The Pic16C710 however is a bigger problem. It's a microcontroller, so it functions according to it's software programming. You'll need to order a replacement from your amp manufacturer, specifically programmed for that amp model. by just buying a pic16c710 you'll get a blank one, wich does nothing... | |
| thanks for your help. this means im totally screwed. the amp is orion and they dont help their customers at all. | |
| Sure they help- they'll sell you a new one! If they didn't "code protect" that PIC, you could find another amp of the exact same revision and clone the chip. But it's dicey that you'd find one and unlikely they'd have left it unprotected. Realistically, these components are not in the power stage, that would have been a more straightforward repair. If they're visibly damaged, then the 5V logic supply was probably fried, so everything fed off that line could be damaged, visible or not. | |
| two control chips blew and a resistor..i checked everything else. its a somple amp, but has no protection at all | |
As already suggested, a strong possibility is the 5V regulator, puting the full 12V on the chips - or connecting power to it the wrong way round?. | ||
| there are 4 rca jacks. 2 inputs and 2 out to another amp. stupidly i was connecting them while it was powered up. one of the cables i was connecting touched the wrong rca POOF! a chunk blew right of the chip | |
| which chip blew off??? if its the PIC then u should post a picture of it. i have never heard or seen a chunk from a chip being blown out. i would love to see some snaps of it. | |
But never a PIC, or any other low power chip - it's usually output chips, or PSU chips. | ||
So remember, if you think there's a chanse something might blow, wear glasses. | ||
| and get afew drinks in her before you ask! LOL | |
| i blew one too, when i was experimenting with the PIC16F877's internal A/D Function, i thought i used 3.65V at the A/D pins I selected. then suddenly, the PIC blew off!! when I looked at the voltage supply, it was set at 36.5V. my stupidity
__________________ Learning is a life-long process... | |
| okay thanx guys for telling me that a chip does have the ability to blow. until now i considered chips to be indestructible. now im a believer!!!!!! :lol: | |
| I recall the phrase, "chips run on blue smoke ... you cant let it out" | |
| does anyone here know how to solve my problem? | |
