Old 10th September 2004, 09:03 PM   (permalink)
Default JMD Programmer Prob - Programming Voltage
I'm new to PICs, and to get myself started I built the JMD serial PIC programmer, but when I try to program a 16F84A PIC, I get the error "Verify failed at address 0000h !".
I think i've tracked the problem to the programming voltage. During programming, the _MCLR pin is only at 6.3v.
Anyone have any suggestions?
Mostly Harmless
Kamikaze47 is offline
Old 10th September 2004, 09:38 PM   (permalink)
Default Re: JMD Programmer Prob - Programming Voltage
Use a parallel port programmer instead!, the JDM is well known for it's problems.
Old 10th September 2004, 09:53 PM   (permalink)
I would, but my PC doesnt have an avaliable parallel port.
So i'm kinda out of ideas
Mostly Harmless
Old 10th September 2004, 10:00 PM   (permalink)
Either use a 'proper' serial port programmer, although these are the most expensive ones!, or search the internet for varients on the JDM programmer - there are lOAD'S of sites with improved versions, basically providing it with a proper power supply.
If you're using a laptop that could well explain your problem, the JDM programmer relies on the computer having an above spec serial port, and laptops are usually way below RS232 spec.
Old 10th September 2004, 10:18 PM   (permalink)
6.3V is seriously low, you need to measure between MCLR and the pic's ground connection (pin 5). not to the Pc's ground.
If you realy have only 6.3V that would mean your pc's serial port output is between -3 and +3 volt, no pc has that low values.
Exo is offline
Old 10th September 2004, 10:29 PM   (permalink)
I am measuring the voltage between Pin 5 (GND) and Pin 4 (_MCLR).
I thought it was strange that I am only getting 6.3v... I dont know whats wrong. I'm not using a laptop, just a standard desktop PC.
Nigel Goodwin: I cant find any schematics for a serial programmer with power supply. Do you have a link?
Thanx
Mostly Harmless
Old 10th September 2004, 10:37 PM   (permalink)
have you tried another computer yet?
Also try measuring the serial port's voltage without the programmer connected. If it is much higher then +3 / -3V then there's probably an error in your programmer wich pulls the ports voltage down.
Exo is offline
Old 11th September 2004, 06:53 AM   (permalink)
Thanx
There are details on the original designers website, try http://www.jdm.homepage.dk/solution.htm.
Old 11th September 2004, 02:58 PM   (permalink)
When i check the voltage from my serial port while the programmer is unplugged, i get +11.6v and -11.1v
so does this mean theres something wrong with my programmer?
Mostly Harmless
Old 11th September 2004, 06:10 PM   (permalink)
I've found the problem. One of the transistors was faulty :roll:
I've replaced the transistor, and now get 13v on _MCLR, and the programmer works perfectly.
Thanks for your help guys.
Mostly Harmless
