| When I try to compile my code I get a bunch of errors, but that's not the problem. Using MPLAB IDE 6.6 The problem is my code is only 105 lines long. The error messages say that I have errors on lines 137, 145, 160 etc. This makes debugging rather difficult as these lines dont exist. Here is another possible clue: On some of these non-existant lines, the error is #116: "Address label duplicated or different in second pass" This makes me think it is looping and adding line numbers somehow? Can anyone explain this? BTW, this code is the 1-wire protocol for Dallas DS1820 temp sensor downloaded from the Dallas website. | |
| Try posting the code, I presume you're actually doing something really silly?, and hopefully it will be easy to spot?. Make sure you surround the code with ' Code: ' and ' | |
| I've written C for the DS18S20. The thing to watch out for is how long interrupts might take, since the slave only holds the 0 low for so long AND if the master holds it low for long enough, the slave will interpret it as a reset. It's often hard to definitively predict how long interrupts can take if your system has any kind of complexity, so it's best to disable them for the time-critical parts of the protocol. | |
| Here it is, straight from the Dallas website. The only changes Ive made are to make it PORTA, Bit 7 instead of PORTB. I agree, its probably something really simple that Ive overlooked. Ive actually saved this code as an "include" file that I call at the top of my LCD code file. Im listing it separately here because the following code wont even compile on its own. This is the first time Ive used an "include" file, other than the ones specific for the processor. Can someone explain this to me? is this any different than calling a macro? You will also see in the code below that the variable TIME is undefined. This is how they wrote it, I havent figured that out yet either. There are some additional notes explaining the code here: http://www.maxim-ic.com/appnotes.cfm...te_number/2420 Thanks for all the help! Code:
; Dallas 1-Wire Support for PIC16F628
; Processor has 4MHz clock and 1µs per instruction cycle.
; Dallas Semiconductor 1-Wire MACROS
OW_HIZ:MACRO
BSF STATUS,RP0 ; Select Bank 1 of data memory
BSF TRISA, 7 ; Make DQ pin High Z
BCF STATUS,RP0 ; Select Bank 0 of data memory
ENDM
OW_LO:MACRO
BCF PORTA, 7 ; Clear the DQ bit
BCF TRISA, 7 ; Make DQ pin an output
ENDM
WAIT:MACRO TIME
;Delay for TIME µs.
;Variable time must be in multiples of 5µs.
MOVLW (TIME/5)-1 ;1µs
MOVWF TMP0 ;1µs
CALL WAIT5U ;2µs
ENDM
; Dallas Semiconductor 1-Wire ROUTINES
WAIT5U:
;This takes 5uS to complete
NOP ;1µs
NOP ;1µs
DECFSZ TMP0,F ;1µs or 2µs
GOTO WAIT5U ;2µs
RETLW 0 ;2µs
OW_RESET:
OW_HIZ ; Start with the line high
CLRF PDBYTE ; Clear the PD byte
OW_LO
WAIT .500 ; Drive Low for 500µs
OW_HIZ
WAIT .70 ; Release line and wait 70µs for PD Pulse
BTFSS PORTA,7 ; Read for a PD Pulse
INCF PDBYTE,F ; Set PDBYTE to 1 if get a PD Pulse
WAIT .400 ; Wait 400µs after PD Pulse
RETLW 0
DSRXBYTE: ; Byte read is stored in IOBYTE
MOVLW .8
MOVWF COUNT ; Set COUNT equal to 8 to count the bits
DSRXLP:
OW_LO
NOP
NOP
NOP
NOP
NOP
NOP ; Bring DQ low for 6µs
OW_HIZ
NOP
NOP
NOP
NOP ; Change to HiZ and Wait 4µs
MOVF PORTA,W ; Read DQ
ANDLW 1<<DQ ; Mask off the DQ bit
ADDLW .255 ; C=1 if DQ=1: C=0 if DQ=0
RRF IOBYTE,F ; Shift C into IOBYTE
WAIT .50 ; Wait 50µs to end of time slot
DECFSZ COUNT,F ; Decrement the bit counter
GOTO DSRXLP
RETLW 0
DSTXBYTE: ; Byte to send starts in W
MOVWF IOBYTE ; We send it from IOBYTE
MOVLW .8
DSTXLP:
OW_LO
NOP
NOP
NOP
NOP
NOP ; Drive the line low for 5µs
RRF IOBYTE,F ; The data byte
BTFSC STATUS,C ; Check the LSB of IOBYTE for 1 or 0
BSF PORTA,7 ; Drive the line high if LSB is 1
WAIT .60 ; Continue driving line for 60µs
OW_HIZ ; Release the line for pullup
NOP
NOP ; Recovery time of 2µs
GOTO DSTXLP
RETLW 0
| When a compiler give an impossible error it could be because of a bad configuration check the MPLAB prefs or configurations for your project device etc etc it could be something wrong since the compiler also gives more errors !! :lol: remember that this code is for PIC 16F628 :lol: i guess that you allready have this checked the code seems ok for me but i don't program in assembler. It's most likelly an bad project configuration for the compiler ! | |
| This is the main program file witch include "#INCLUDE 1w_16f6x.inc " The file you posted is only a macro file, you need to save that as 1w_16fx.inc and call it from your main ASM codes !...?!!! Macro is save time but doesn't have to be saving space. Macro can contain definitions constant and function you are intend to use repeatedly in you program, using the macro you don't need to create the code 10 times, you just call it from your main program with the fuc or var you need to use. Try to compile only the Dallas asm and inc file first, once you get those running ad your on lines "inc" files. I hope this helps. STEVE Code: '
; Dallas Semiconductor PIC code
; This code will interface a PIC16F628 microcontroller to
; a DS2761 High-Precision Li+ Battery Monitor
; VCC
; \ Rpup
; 16F628 | DS2761
; RB1 (pin 7) ------------------------------ DQ (pin 7)
; List your processor here.
list p=16F628
; Include the processor header file here.
#include <p16F628.inc>
; Assign the PORTB with Constants
constant DQ=1 ; Use RB1 (pin7) for 1-Wire
; These constants are standard 1-Wire ROM commands
constant SRCHROM=0xF0
constant RDROM=0x33
constant MTCHROM=0x55
constant SKPROM=0xCC
; These constants are used throughout the code
cblock 0x20
IOBYTE
TMP0 ; Address 0x23
COUNT ; Keep track of bits
PICMSB ; Store the MSB
PICLSB ; Store the LSB
PDBYTE ; Presence Detect Pulse
endc
; Setup your configuration word by using __config.
; For the 16F628, the bits are:
; CP1,CP0,CP1,CP0,N/A, CPD, LVP, BODEN, MCLRE, FOSC2, PWRTE, WDTE, FOSC1, FOSC0
; CP1 and CP0 are the Code Protection bits
; CPD: is the Data Code Protection Bit
; LVP is the Low Voltage Programming Enable bit
; PWRTE is the power-up Timer enable bit
; WDTE is the Watchdog timer enable bit
; FOSC2, FOSC1 and FOSC0 are the oscillator selection bits.
; CP disabled, LVP disabled, BOD disabled, MCLR enabled, PWRT disabled, WDT disabled, INTRC I/O oscillator
; 11111100111000
__config 0x3F38
; Set the program origin for subsequent code.
org 0x00
GOTO SETUP
NOP
NOP
NOP
GOTO INTERRUPT ; PC 0x04...INTERRUPT VECTOR!
INTERRUPT:
SLEEP
; Option Register bits
; ____
; RBPU,INTEDG,TOCS,TOSE,PSA,PS2,PS1,PS0
; 7=PORTB Pullup Enable, 6=Interrupt Edge Select, 5=TMR0 Source,
; 4=TMR0 Source Edge, 3=Prescaler Assign, 2-0=Prescaler Rate Select
; 11010111
; PORTB pullups disabled,rising edge,internal,hightolow,TMR0,1:256
SETUP:
BCF STATUS,RP1
MOVLW 0xD7
MOVWF OPTION_REG
BCF INTCON,7 ; Disable all interrupts.
GOTO START
; Include the 1-Wire communication routines and macros
START:
GET_TEMP:
CALL OW_RESET ; Send Reset Pulse and read for Presence Detect Pulse
BTFSS PDBYTE,0 ; 1 = Presence Detect Detected
GOTO NOPDPULSE
MOVLW SKPROM
CALL DSTXBYTE ; Send Skip ROM Command (0xCC)
MOVLW 0x69
CALL DSTXBYTE ; Send Read Data Command (0x69)
MOVLW 0x0E
CALL DSTXBYTE ; Send the DS2761 Current Register MSB address (0x0E)
CALL DSRXBYTE ; Read the DS2761 Current Register MSB
MOVF IOBYTE,W
MOVWF PICMSB ; Put the Current MSB into file PICMSB
CALL DSRXBYTE ; Read the DS2761 Current Register LSB
MOVF IOBYTE,W
MOVWF PICLSB ; Put the Current LSB into file PICLSB
CALL OW_RESET
NOPDPULSE: ; Add some error processing here!
SLEEP ; Put PIC to sleep
end
| For the 1-wire protocol, use the RA4 pin on the 16F628 unless you need it for a second clock source. RA4 is physically limited to being an open drain pin, which is perfect for the 1-wire and you won't have to write code to keep setting and clearing the TRIS bits back and forth. It also frees up another full complimentary pin for more useful things. | |
| There ya go ! Simple wasn't it But remember that 1-Wire is fun, it takes less i/o pins but it takes much program execution time making the signal modulation !!! Since it doesn't have the data being clocked and it has a very specific time intervals for the 1's and 0's, majorly it delays the other code ! But it also has the overdrive mode i guess but even so the software must make too many NOP to make the right timings ! Take care ! | |
| Csaba911: I did save that code as an include file and was calling it from my main program! (read my post above). I will look it over again tonight and make sure, but I think there is another problem. | |
The code posted by Dallas is compile under MPLAB IDE v6.60, no errors ! You called the macros from your ASM codes !? Code: '
cblock 0x20
IOBYTE
TMP0 ; Address 0x23
endc
' Sorry I tried ! STEVE | ||
| Well two things i'm sure, Microchip hasn't anounced any problem with the compiler, and Dallas Semi. whould not loose costumers with wrong codes in their page :lol: so the problem must be there, wy guilt the code ?? the problem must be in the project creation or MPLAB prefs if not then maybe someone has casted a spell on your computer ! :lol: | |
| Geez, just write your own. It's not that big. Also, there are better implementations. As I mentioned, the best solution is to disable interrupts but only during time-critical periods. It's also rather slow, so if your chip is slow or you've got a particularly "busy" system, it's good to break down the 1-wire transaction over iterations of a main code loop. i.e. you do critical update tasks once, send out the timed pulse to initiate a read bit to the DS18S20, read the result, then loop back and do the critical stuff again. At minimum, you probably want to let other things go on between initiating a DS18S20 conversion and waiting for the conversion result to become available. It's a pretty long wait. | |
