has anybody used the "Small Device C Compiler" for programming PICs in C??
i know that it is a text based complier and the open source software people are developing it but it seems promising. u can find it here http://sourceforge.net/projects/sdcc/ a short description of the compiler from the above link Quote:
now i dont want to start another debate on C Vs Assembly or Pascal or anything like that. i realize the importance of all programming languages and i respect the users of all programming languages (aint i good at making diplomatic statements 8) ) i just want to know that has anyone had experience with this compiler? |
I know its possible, but i have had no luck. Problem is its not user friendly, if you dont know linux and are not used to command line apps then ur dead.
I will see if i can contact someone who knows, he used it with the PIC18F4xx series (or a couple of em). The PIC16Fxxx series is not supported, at least i do not think there are any libaries for it. The main problem is a IDE, they have a windows version but it would be great if someone could write a tut for getting it to work in a IDE, even better if someone made a downloadable pre-fab setup |
SDCC is a very good idea but as already mentioned it is not very user friendly. Tried using it but in the end, took the easy way out and used PICCLite from Hi-Tech (extremely simple set-up and 16f877 is supported - with limitations on the Lite version).
On the IDE side, have been using Eclipse with the C/C++ plugin. With a make file, you can hide all the command line stuff ... sweet :P . |
I also use SDCC for p89v51rd2, not friendly user when compare with RIDE, Keil C. However, when I combine with MIDE (also free) it quite comfortable.
Microcontroller Programming: http://mcu-programming.blogspot.com uC - News, Resources and Tutorials |
