Old 25th August 2004, 11:14 PM   (permalink)
Default labels vs. subroutines
I was reading a discussion in the archives about which is better and when to use each, but Im still confused.
Is the PIC able distinguish between a Label and Sub? How? Every sub starts with a label (right?).
Can you only use RETURN after a CALL? is this the difference?
NewGeek is offline
Old 25th August 2004, 11:58 PM   (permalink)
Default Re: labels vs. subroutines
Basically yes, a subroutine ends with a RETURN (or RETLW) which pops the previous address off the stack, and carries on executing from that previous address - the stack is very small in PIC's, you can only nest a very small number of subroutine calls.
A GOTO simply jumps to a new address, the old address isn't saved in any way - so it's a very different affair, you've no way of returning to where it started from.
Old 26th August 2004, 12:30 AM   (permalink)
I can understand your confusion. First, you must understand what a PIC does and does not do.
A PIC executes a program encoded as machine code. In machine code, there are no labels. Labels are already removed and translated by the assembler or compiler that processed the source program (the one containing labels) to machine code. That procedure was done in your PC not at the PIC. Without labels in the machine code, the PIC cannot distinguish them.
Yes, it's good programming practice to tack a label at the start of every subroutine. But you don't have to.
If you define a subroutine to be a section of a program that ends with a return, lookup tables are implemented in the PIC using a series of RETLW instructions. You don't have to put a label on each and every one.
"Having to do with Motion Control"
motion is offline
