| i found a code that is used with lcd i understood most of it but there's still one part that i didn't understand actually the code is written for a micro that i don't know how to use i only know the pic family 16f and 18fthis part of the code that i didn't understand is:; Procedure of step by step and scan ;************************************************* ***************************** STP_SC: MOV C,S_S JC STEP RET STEP: MOV C,STP MOV R5,#0FH LOPE: MOV R6,#0FFH LOPH: DJNZ R6,LOPH DJNZ R5,LOPE JNB S_S,LOUT JNC STEP LOUT: RET the whole code is this: ;************************************************* ***************************** ; KS0107,KS0108 ;************************************************* ***************************** .SYMBOLS ;************************************************* ***************************** ; DEFINE OUTPUT PORORT ;************************************************* ***************************** RS REG P3.0 E REG P3.4 CS1 REG P3.3 CS2 REG P3.5 R_W REG P3.7 STP REG P2.0 S_S REG P2.1 BCD EQU 01H ;************************************************* ***************************** ORG 0H LJMP START ORG 50H START: ;program reset start here ;INITIAL MOV A,#40H ;Set Y Column Address >From 0 LCALL WRITE_COMMAND1 LCALL WRITE_COMMAND2 MOV A,#B8H ;Set Page From 0 LCALL WRITE_COMMAND1 LCALL WRITE_COMMAND2 MOV A,#C0H ;Set Display Start Line LCALL WRITE_COMMAND1 LCALL WRITE_COMMAND2 MOV A,#3FH ;Set Display ON LCALL WRITE_COMMAND1 LCALL WRITE_COMMAND2 ;************************************************* ***************************** ; FULL ON ;************************************************* ***************************** FULL_ON: MOV R0,#0 MOV R1,#0 FOLOOP1: MOV A,R1 ;Set Page Address FROM 00H ORL A,#B8H ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter FOLOOP2: ;Write Data To Chip I MOV A,#FFH CALL WRITE_DATA1 INC R0 CJNE R0,#64,FOLOOP2 FOLOOP3: ;Write Data To Chip II MOV A,#FFH CALL WRITE_DATA2 INC R0 CJNE R0,#128,FOLOOP3 INC R1 CJNE R1,#8,FOLOOP1 LCALL DELAY LCALL STP_SC SJMP SHOWM ;************************************************* ***************************** ; SHOW MODEL ;************************************************* ***************************** SHOWM: MOV R0,#0 MOV R1,#0 MOV DPTR,#SHOW_WG SMLOOP1: MOV A,#B8H ;Set Page Address FROM 00H ADD A,R1 ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter SMLOOP2: ;Write Data To Chip I XRL A,A MOVC A,@A+DPTR CALL WRITE_DATA1 INC R0 INC DPTR CJNE R0,#64,SMLOOP2 SMLOOP3: ;Write Data To Chip II XRL A,A MOVC A,@A+DPTR CALL WRITE_DATA2 INC R0 INC DPTR CJNE R0,#128,SMLOOP3 INC R1 CJNE R1,#8,SMLOOP1 LCALL DELAY LCALL STP_SC SJMP VLINE ;************************************************* ***************************** ; VERTIAL LINE ;************************************************* ***************************** VLINE: MOV R0,#0 MOV R1,#0 VLLOOP1: MOV A,#B8H ;Set Page Address FROM 00H ADD A,R1 ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter VLLOOP2: ;Write Data To Chip I MOV A,#FFH CALL WRITE_DATA1 INC R0 MOV A,#00H CALL WRITE_DATA1 INC R0 CJNE R0,#64,VLLOOP2 VLLOOP3: ;Write Data To Chip II MOV A,#FFH CALL WRITE_DATA2 INC R0 MOV A,#00H CALL WRITE_DATA2 INC R0 CJNE R0,#128,VLLOOP3 INC R1 CJNE R1,#8,VLLOOP1 LCALL DELAY LCALL STP_SC SJMP HLINE ;************************************************* ***************************** ; HORIZONTAL LINE ;************************************************* ***************************** HLINE: MOV R0,#0 MOV R1,#0 HLLOOP1: MOV A,#B8H ;Set Page Address FROM 00H ADD A,R1 ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter HLLOOP2: ;Write Data To Chip I MOV A,#AAH CALL WRITE_DATA1 INC R0 CJNE R0,#64,HLLOOP2 HLLOOP3: ;Write Data To Chip II MOV A,#AAH CALL WRITE_DATA2 INC R0 CJNE R0,#128,HLLOOP3 INC R1 CJNE R1,#8,HLLOOP1 LCALL DELAY LCALL STP_SC SJMP CROSS_DOT ;************************************************* ***************************** ; BIG CROSS DOT ;************************************************* ***************************** CROSS_DOT: MOV R0,#0 MOV R1,#0 CDLOOP1: MOV A,#B8H ;Set Page Address FROM 00H ADD A,R1 ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter CDLOOP2: ;Write Data To Chip I MOV A,#CCH CALL WRITE_DATA1 CALL WRITE_DATA1 MOV A,#33H CALL WRITE_DATA1 CALL WRITE_DATA1 INC R0 CJNE R0,#16,CDLOOP2 CDLOOP3: ;Write Data To Chip II MOV A,#CCH CALL WRITE_DATA2 CALL WRITE_DATA2 MOV A,#33H CALL WRITE_DATA2 CALL WRITE_DATA2 INC R0 CJNE R0,#32,CDLOOP3 INC R1 CJNE R1,#8,CDLOOP1 LCALL DELAY LCALL STP_SC SJMP SHOWC ;************************************************* ***************************** ; SHOW CHARACTER ;************************************************* ***************************** SHOWC: MOV R0,#0 MOV R1,#0 MOV DPTR,#SHOW_CH SCLOOP1: MOV A,#B8H ;Set Page Address FROM 00H ADD A,R1 ;Command B8H~BFH CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV A,#40H ;Set Column Address FROM 40H CALL WRITE_COMMAND1 CALL WRITE_COMMAND2 MOV R0,#0 ;Rest Counter SCLOOP2: ;Write Data To Chip I XRL A,A MOVC A,@A+DPTR CALL WRITE_DATA1 INC R0 INC DPTR CJNE R0,#64,SCLOOP2 SCLOOP3: ;Write Data To Chip II XRL A,A MOVC A,@A+DPTR CALL WRITE_DATA2 INC R0 INC DPTR CJNE R0,#128,SCLOOP3 INC R1 CJNE R1,#8,SCLOOP1 LCALL DELAY LCALL STP_SC LJMP START ;repeat test ;************************************************* ***************************** CHK_BUSY: MOV P1,#0FFH ;SET PORT1=INPUT CLR RS ;SET IR MODE RS=0 SETB R_W ;SET READ MODE R/W=1 SETB E ;ENABLE LCM MOV C,P1.7 ;CHECK BUSY FLAGE(BIT7) CLR E JC CHK_BUSY RET ;************************************************* ***************************** ; DELAY ;************************************************* ***************************** DELAY: CALL CBCD MOV R4,BCD LOPC: MOV R5,#2FH LOPB: MOV R6,#0FFH LOPA: DJNZ R6,LOPA DJNZ R5,LOPB DJNZ R4,LOPC RET ;************************************************* ***************************** ;* Timing ;************************************************* ***************************** WRITE_COMMAND1: ;Write Command To CS1 CLR CS1 SETB CS2 CLR RS CLR R_W MOV P1,A SETB E NOP CLR E RET ;************************************************* ***************************** WRITE_DATA1: ;Write Data To CS1 CLR CS1 SETB CS2 SETB RS CLR R_W MOV P1,A SETB E NOP CLR E RET ;************************************************* ***************************** WRITE_COMMAND2: ;Write Command To CS2 CLR CS2 SETB CS1 CLR RS CLR R_W MOV P1,A SETB E NOP CLR E RET ;************************************************* ***************************** WRITE_DATA2: ;Write Data To CS2 CLR CS2 SETB CS1 SETB RS CLR R_W MOV P1,A SETB E NOP CLR E RET ;************************************************* ***************************** ; Procedure of step by step and scan ;************************************************* ***************************** STP_SC: MOV C,S_S JC STEP RET STEP: MOV C,STP MOV R5,#0FH LOPE: MOV R6,#0FFH LOPH: DJNZ R6,LOPH DJNZ R5,LOPE JNB S_S,LOUT JNC STEP LOUT: RET ;************************************************* ***************************** ; BCD DELAY TIME SELECT ;************************************************* ***************************** CBCD: PUSH A MOV A,P0 ANL A,#0FH RL A RL A MOV BCD,A POP A RET ;************************************************* ***************************** ;* DISPLAY DATA ;************************************************* ***************************** SHOW_CH: DB 0FFH,01H,01H,01H,01H,0C1H,01H,01H DB 01H,01H,01H,01H,0C1H,0C1H,01H,0C1H DB 0C1H,01H,01H,01H,0C1H,01H,01H,01H DB 0C1H,01H,01H,01H,81H,81H,0E1H,81H DB 81H,01H,01H,81H,41H,81H,01H,01H DB 01H,01H,01H,81H,41H,41H,41H,81H DB 01H,01H,01H,01H,01H,0C1H,0C1H,01H DB 01H,01H,01H,01H,01H,01H,01H,81H DB 41H,01H,01H,01H,41H,81H,01H,01H DB 01H,01H,01H,01H,01H,01H,01H,01H DB 01H,01H,01H,01H,01H,01H,01H,01H DB 01H,01H,01H,01H,81H,41H,41H,41H DB 81H,01H,01H,01H,01H,81H,0C1H,01H DB 01H,01H,01H,01H,81H,41H,41H,41H DB 81H,01H,01H,01H,81H,41H,41H,41H DB 81H,01H,01H,01H,01H,01H,01H,0FFH DB 0FFH,00H,00H,00H,00H,9FH,00H,00H DB 00H,00H,00H,00H,02H,01H,00H,02H DB 01H,00H,00H,41H,0FFH,41H,41H,41H DB 0FFH,41H,00H,67H,88H,88H,0FFH,88H DB 88H,73H,00H,41H,22H,11H,08H,0C4H DB 22H,0C1H,00H,0E3H,14H,08H,14H,0A3H DB 0C0H,20H,00H,00H,00H,02H,01H,00H DB 00H,00H,00H,00H,00H,00H,3EH,0C1H DB 00H,00H,00H,00H,00H,0C1H,3EH,00H DB 00H,00H,00H,08H,08H,08H,7FH,08H DB 08H,08H,00H,00H,14H,08H,3EH,08H DB 14H,00H,00H,03H,00H,00H,0B0H,08H DB 08H,07H,00H,00H,01H,00H,0FFH,00H DB 00H,00H,00H,0C3H,20H,10H,10H,08H DB 08H,07H,00H,41H,80H,08H,08H,08H DB 94H,63H,00H,00H,00H,00H,00H,0FFH DB 0FFH,00H,00H,00H,00H,01H,0C0H,20H DB 0F0H,00H,00H,0F0H,10H,10H,10H,10H DB 10H,00H,00H,0C0H,21H,10H,10H,10H DB 21H,40H,00H,70H,10H,10H,13H,90H DB 50H,30H,00H,0C0H,20H,10H,10H,10H DB 21H,0C0H,00H,0C0H,21H,11H,11H,10H DB 20H,0C1H,00H,0E0H,10H,10H,10H,90H DB 70H,0E0H,00H,00H,00H,80H,80H,00H DB 01H,00H,00H,00H,01H,80H,80H,00H DB 00H,00H,00H,40H,20H,10H,10H,10H DB 20H,0C0H,00H,00H,00H,00H,00H,00H DB 80H,40H,00H,00H,00H,00H,01H,00H DB 00H,00H,00H,00H,00H,01H,01H,01H DB 00H,00H,00H,81H,41H,21H,11H,21H DB 41H,81H,00H,0F0H,10H,11H,11H,11H DB 20H,0C0H,00H,00H,00H,00H,00H,0FFH DB 0FFH,00H,00H,10H,1CH,13H,10H,10H DB 7FH,10H,00H,13H,22H,41H,41H,41H DB 22H,1CH,00H,1FH,22H,41H,41H,41H DB 22H,1CH,00H,00H,00H,00H,7EH,01H DB 00H,00H,00H,18H,25H,42H,42H,42H DB 25H,18H,00H,11H,22H,44H,44H,44H DB 22H,1FH,00H,3FH,70H,4CH,42H,41H DB 40H,3FH,00H,00H,00H,0B1H,71H,00H DB 00H,00H,00H,00H,00H,31H,31H,00H DB 00H,00H,00H,3EH,41H,41H,3EH,40H DB 40H,3FH,00H,10H,08H,04H,02H,01H DB 00H,00H,00H,00H,00H,0B0H,70H,00H DB 00H,00H,00H,00H,00H,60H,60H,00H DB 00H,00H,00H,7FH,08H,08H,08H,08H DB 08H,7FH,00H,7FH,42H,42H,42H,42H DB 25H,18H,00H,00H,00H,00H,00H,0FFH DB 0FFH,00H,00H,0F0H,08H,04H,04H,04H DB 08H,10H,00H,04H,0FCH,04H,04H,04H DB 08H,0F0H,00H,0FCH,84H,84H,84H,84H DB 84H,04H,00H,0FCH,84H,84H,84H,84H DB 84H,04H,00H,0F0H,08H,04H,04H,84H DB 88H,90H,00H,0FCH,80H,80H,80H,80H DB 80H,0FCH,00H,00H,00H,04H,0FCH,04H DB 00H,00H,00H,00H,00H,00H,00H,04H DB 0FCH,04H,00H,0FCH,80H,40H,20H,10H DB 08H,04H,00H,00H,0FCH,00H,00H,00H DB 00H,00H,00H,0FCH,08H,10H,60H,10H DB 08H,0FCH,00H,0FCH,08H,30H,0C0H,00H DB 00H,0FCH,00H,0F0H,08H,04H,04H,04H DB 08H,0F0H,00H,0FCH,04H,04H,04H,04H DB 88H,70H,00H,0F0H,08H,04H,04H,04H DB 08H,0F0H,00H,00H,00H,00H,00H,0FFH DB 0FFH,00H,00H,07H,08H,10H,10H,10H DB 08H,04H,00H,10H,1FH,10H,10H,10H DB 08H,07H,00H,1FH,10H,10H,10H,10H DB 10H,10H,00H,1FH,00H,00H,00H,00H DB 00H,00H,00H,07H,08H,10H,10H,10H DB 08H,1FH,00H,1FH,00H,00H,00H,00H DB 00H,1FH,00H,00H,00H,10H,1FH,10H DB 00H,00H,00H,0CH,10H,10H,10H,08H DB 07H,00H,00H,1FH,00H,01H,02H,04H DB 08H,10H,00H,00H,1FH,10H,90H,10H DB 10H,10H,00H,1FH,00H,00H,00H,00H DB 00H,1FH,00H,1FH,00H,00H,00H,03H DB 04H,1FH,00H,07H,08H,10H,10H,10H DB 08H,07H,00H,1FH,01H,01H,01H,01H DB 00H,00H,00H,07H,0CH,12H,12H,12H DB 0CH,17H,00H,00H,00H,00H,00H,0FFH DB 0FFH,00H,00H,0FFH,21H,21H,61H,0A1H DB 12H,0CH,00H,0CH,12H,21H,21H,21H DB 42H,84H,00H,01H,01H,01H,0FFH,01H DB 01H,01H,00H,0FFH,00H,00H,00H,00H DB 00H,0FFH,00H,0FFH,00H,00H,00H,00H DB 00H,0FFH,00H,0FFH,00H,80H,60H,80H DB 00H,0FFH,00H,07H,88H,50H,20H,50H DB 88H,07H,00H,07H,08H,10H,0E0H,10H DB 08H,07H,00H,01H,81H,41H,21H,11H DB 09H,07H,00H,00H,00H,00H,87H,00H DB 00H,00H,00H,00H,00H,00H,00H,00H DB 00H,00H,00H,00H,00H,00H,0FFH,01H DB 01H,00H,00H,00H,01H,01H,0FFH,00H DB 00H,00H,00H,00H,00H,20H,0DEH,01H DB 01H,00H,00H,00H,01H,01H,0DEH,20H DB 00H,00H,00H,00H,00H,00H,00H,0FFH DB 0FFH,80H,80H,87H,80H,80H,80H,80H DB 83H,84H,80H,81H,82H,84H,84H,84H DB 82H,81H,80H,80H,80H,80H,87H,80H DB 80H,80H,80H,83H,84H,84H,84H,84H DB 84H,83H,80H,80H,81H,82H,84H,82H DB 81H,80H,80H,81H,86H,81H,80H,81H DB 86H,81H,80H,87H,80H,80H,80H,80H DB 80H,87H,80H,80H,80H,80H,87H,80H DB 80H,80H,80H,87H,84H,84H,84H,84H DB 84H,84H,80H,80H,80H,80H,87H,80H DB 80H,80H,80H,84H,84H,84H,84H,84H DB 84H,84H,80H,80H,80H,80H,87H,84H DB 84H,80H,80H,80H,84H,84H,87H,80H DB 80H,80H,80H,80H,80H,80H,83H,84H DB 84H,80H,80H,80H,84H,84H,83H,80H DB 80H,80H,80H,80H,80H,80H,80H,0FFH SHOW_WG: DB 010h,010h,000h,000h,003h,000h,040h,080h DB 040h,08Fh,040h,080h,040h,080h,043h,080h DB 040h,080h,040h,08Fh,040h,080h,040h,080h DB 043h,080h,040h,080h,040h,08Fh,040h,080h DB 040h,080h,043h,080h,040h,080h,040h,08Fh DB 040h,080h,040h,000h,003h,000h,080h,080h DB 080h,00Fh,080h,080h,080h,000h,003h,000h DB 040h,080h,040h,08Fh,040h,080h,040h,080h DB 043h,080h,040h,080h,040h,08Fh,040h,080h DB 040h,080h,043h,080h,040h,080h,040h,08Fh DB 040h,080h,040h,080h,043h,080h,040h,080h DB 040h,08Fh,040h,080h,040h,000h,003h,000h DB 080h,000h,080h,08Fh,080h,000h,080h,080h DB 083h,000h,000h,000h,040h,08Fh,040h,080h DB 040h,080h,043h,080h,040h,080h,040h,08Fh DB 040h,080h,040h,080h,055h,0AAh,055h,0AAh DB 042h,042h,002h,002h,000h,000h,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,080h,040h,080h,04Bh,08Ah DB 04Eh,080h,04Fh,088h,04Fh,080h,040h,080h DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,080h,040h,080h DB 04Fh,080h,04Fh,088h,04Fh,080h,04Fh,088h DB 04Fh,080h,040h,080h,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 008h,008h,008h,008h,000h,000h,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 021h,021h,020h,020h,000h,000h,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 084h,084h,080h,080h,000h,000h,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 010h,010h,000h,000h,000h,000h,015h,08Ah DB 095h,08Ah,015h,08Ah,095h,08Ah,015h,00Ah DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 042h,042h,002h,002h,000h,000h,040h,08Bh DB 04Ah,08Eh,040h,08Fh,048h,08Fh,040h,080h DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 058h,0A8h,058h,0A8h,050h,0A0h,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh END | |
| If you want PIC LCD code, consult my tutorials. | |
