Hi, I just posted a question about a related problem in the General Chat lounge, but I also have a question on programming/running a PIC16F627. I am trying to rule out problems on a Velleman kit board, I am able to program a chip on it and read/verify the data, but on selecting RUN with a switch, the chip fails to function. Is the oscillator on OSC1 / OSC2 required during the programming phase? I removed the OSC, and was able to program the chip, but I wonder whether the crystal is faulty. The circuit diagram is available at the following URL: http://www.velleman.be/Downloads/0/Manual_K8048_UK.pdf Page 10. Any guidance? | |
The oscillator is not required for programming... -Did you verify the program (read it back out and compare to the original) , to see if it was programmed correctly? -Did you place the correct jumpers on the board to connect the crystal to the right socket where your 16f627 is installed (JP3 - JP4)... -Did you set the switch to PGM when programming and to RUN when running the software? -Are you sure the program you uploaded to the pic is without bugs ? -Did you set the configuration word to the right oscillator (XT) ? To test your oscillator you could always set the 16f627 oscillator to use the internal 4Mhz oscillator (be sure to disconnect the crystal if you try this) | |
| | #3 | ||||||
I have a feeling that there is an electrical issue on the board. I have an LED which fails to light intermittantly, it's LD9 on the circuit diagram. It is a flashing LED, but only lights up fully, or not at all... I will replace it with another LED as it may be a misnomer. I have double checked the resistor values/transistors/etc, and have checked for bridges between solder joints. As I said, programming is OK, RUN is not... EXO... thanks for your assitance on this and the other query... | |||||||
Yes, INT-OSC is the pics internal oscillator... LD9 seems to be a special led with a 'blinker' build in... It's not required for normal circuit operation , its just an indiation power is on and you should not remove the pic. You can just remove the led and give it a try if you think the led's to blaim. once a pic is programmed it needs very little to run. when in run check there is 5V on pin 14 and pin 4. | |
Exo, they are the points I chose to test also. I'll complete this tonight. I suspect the LED is damaged as it never worked correctly, it is supposed to flash but doesn't. It has it's own current limiter built in, so I'll install a resistor and standard LED in it's place. | |
| | #6 |
Don't forget MCLR, did you use a resistor to +V or tie it up internally?
| | #7 |
Hi guys, I tested the board last night. I found that all the voltages are OK (5v to Vpp and Vcc when in RUN). I then loaded another program, (supplied by Velleman for the kit) and noticed that it lit one LED. It's supposed to be a running LED display... I managed to edit one part of the code to change the light display, and it worked... So now I know that the problem is code related... I'll work to correct it, and let the guys at Velleman know. That's three faults I have found with the kit so far. Thanks for assistance. | |
| circuit, crystal, oscillator, testing |
