Old 26th July 2004, 01:41 PM   (permalink)
Default interfacing low power microcontroller
hi I'm using a microcontroller (low power), and the logic level is measured at about 2.93V for high. when interfacing with normal logic IC (AND, OR,...), the high level is 5V. How do i convert from 2.93V to 5V? Is there any level shifter chip i can use? or is there any other way?
banh is offline   Reply With Quote
Old 26th July 2004, 09:43 PM   (permalink)
Default Re: interfacing low power microcontroller
That would probably be fine, it should be within the 5V logic specs. However, why is it only 2.93V? - are you running it from a lower HT rail?.
If it is too low, you could use a simple transistor inverter to change the levels, although it would invert the logic.
Old 27th July 2004, 12:31 AM   (permalink)
thanks, i find that it's just fine; no need to convert
