| I want to get started with microcontrollers, and want a cheap programmer to learn with. I found his on the net and wondered if anyone could tell me whether or not it would be any good? http://www.256.co.uk[/url]
__________________ Will Neo wake up and say, \"Bill, dude, you won\'t believe this bitchin\' dream I just had...\"? | |
It's only problem is the very small range of PIC's it supports, but their next programmer up is a great deal more expensive. You can get programmers a lot cheaper that do a lot more than the PICKit 1, have a look at the details on my site listed below. You can get a nice cheap kit for the P16PRO40 from various places, Quasar Electronics at http://www.quasarelectronics.com/3096.htm is one, and only £11.95 as a kit - you can use my free software with it, or IC-Prog. But there's nothing wrong with the PICKit 1, in fact I keep meaning to buy one to play with!. | ||
which microcontroller are u going to start with? i would recommend that u start with the PIC. but the choice is yours go to http://www.winpicprog.co.uk u can find great PIC tutorials there and a simple and easy programmer for the PIC. ive recently built the programmer at the above mentioned site, so if u need help with it plz ask. | ||
| I think PIC (how's i pronounced by the way? P-I-C or PIC) is going to be the best bet, I hopefully going to go to universty to study electronics but i see electronics as a hobby rather than a career path. So any advice you can offer will be greatly appriciated.
its good to hear that u are going to study electronics. good choice! but electronics is more than just a hobby. it has unlimited applications. the horizon of electronics is very huge. u should reconsider about chosing your career path. living with electronics for your whole life is the best thing that can happen to you. | ||
| I started off PIC on a 100% DIY basis from the programmer to the development board. I'm using an ICDv1 programmer flashed with CCS's firmware. There are certain considerations which you should note for the programmer. 1. An ICSP programmer is a MUST if you are doing PIC develoopment. It is probably cheaper too since you do not need a ZIF socket. 2. All programmer's need to be powered, one way or another. The main thing about PIC programmers is that it needs to generate 13V to kick the PIC into programming mode. My programmer only needs a 5V external power input to work, which I conveniently drew from the target circuit through the ICSP cable, saving me the need of a external power adaptor. 3. Programmer's usually interface to the PC thru serial, parallel or usb ports. USB is of course the best, but I'm quite comfortable with serial ports as well. 4. One minor point I'm happy with using CCS's firmware is because their uploading program allows you to run/stop the program using software control. With the ICD2, I still had to manually disconnect the ICSP cable in order for the PIC to start running. 5. Lastly, CCS's uploading program is user-friendly enough for me. Programming often takes only 2 clicks of the mouse. Running the program takes another click :P In all, I'm very satisfied with my programmer, since there is no need at all to touch the entire hardware setup once it's finalized, as everything is software controlled. Of course, I still went to the trouble of powering down the circuit whenever I'm not using it. :lol: | |
| | (permalink) | |||
Personally I've never found occasion to use it, I prefer to leave maximum versatility on the target board - and it's also simpler!. Quote:
| | (permalink) | ||
Anyway, it's all a matter of preference. What I'm suggesting here are some minor points that will affect your programming experience. Cheers! | |||
and the power cable is just one more cable. i dont think thats much of a problem. anyway as u said, its just a matter of choice. the programmer which i built is the Ozipic'er http://www.plmsdevelopments.com/ozip...s_ozipicer.htm Nigel's website also has the layout and schematic of this programmer. and for all u ICD fans go to http://www.mcu.cz/modules/news/article.php?storyid=449 for the clone of the ICD2. its cheaper than the one available from microchip. | ||
