+ Reply to Thread
Results 1 to 1 of 1
Thread: program clarification
  1. #1
    jimmyvarghese143 Newbie
    Join Date
    Sep 2009
    Posts
    46
    Default program clarification
    LIST P = PIC16F877A
    #INCLUDE "P16F877A.INC"
    __CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _LVP_OFF
    cblock 20h
    hibyte
    lowbyte
    temp
    IRWaitCnt
    msb,lsb,ones,tens,hund,thus,ss,sp,rr,tmp,tmp1,STOR E,blink,hunds,tmp2,timer
    endc
    ORG 0X00
    MOVLW 00H
    MOVWF PCLATH
    CLRF STATUS
    GOTO main
    org 04h
    movwf temp
    swapf STATUS,W
    movwf STORE
    clrf STATUS
    GOTO ISR
    retfie
    lookup:
    addwf PCL,F ;digit to be displayed
    retlw b'00111111' ;'0'
    retlw b'00000110' ;'1'
    retlw b'01011011' ;'2'
    retlw b'01001111' ;'3'
    retlw b'01100110' ;'4'
    retlw b'01101101' ;'5'
    retlw b'01111101' ;'6'
    retlw b'00000111' ;'7'
    retlw b'01111111' ;'8'
    retlw b'01101111' ;'9'
    retlw b'01110111' ;'a'
    retlw b'01111100' ;'b'
    retlw b'00111001' ;'c'
    retlw b'01011110' ;'d'
    retlw b'01111001' ;'e'
    retlw b'01110001' ;'f'
    retlw b'00000000'
    initport:
    bsf STATUS,RP0
    bcf TRISC,1
    bcf TRISC,0
    movlw 0x06
    movwf OPTION_REG
    movlw b'00000000'
    movwf TRISD
    bcf TRISB,5
    movlw b'11010000'
    movwf TRISB
    bsf PIE1,TMR1IE
    bcf STATUS,RP0
    bcf PIR1,TMR1IF
    bsf INTCON,GIE
    bsf INTCON,PEIE
    bsf T1CON,0
    bcf T1CON,2
    bcf T1CON,1
    clrf TMR0
    clrf TMR1L
    clrf TMR1H
    bcf PORTC,0
    bcf PORTC,1
    movlw b'11110000'
    andwf PORTB,F
    clrf PORTD
    bsf PORTC,0
    bcf PORTC,0
    movlw 0x5f
    movwf ss
    bsf tmp,0
    movlw 0x01
    movwf ones
    movlw 0x02
    movwf tens
    movlw 0x03
    movwf hunds
    movlw 0x04
    movwf thus
    clrf blink
    return
    mainline:
    bcf INTCON,T0IF
    bcf PIR1,TMR1IF
    nop
    btfsc PORTB,4
    goto mainline
    call start
    xorlw 0FFh
    btfss STATUS,Z
    goto mainline
    movlw 0FFh
    movwf PORTD
    bsf PORTC,1
    call delay
    bcf PORTC,1
    movfw lowbyte
    movfw hibyte
    movwf tmp1
    movfw lowbyte
    movwf tmp
    xorlw .1
    btfss STATUS,Z
    goto next1
    goto chkOvr
    next1: movfw lowbyte
    xorlw .2
    btfss STATUS,Z
    goto next2
    goto chkOvr
    next2: movfw lowbyte
    xorlw .3
    btfss STATUS,Z
    goto next3
    goto chkOvr
    next3: movfw lowbyte
    xorlw .4
    btfss STATUS,Z
    goto next4
    goto chkOvr
    next4: movfw lowbyte
    xorlw .5
    btfss STATUS,Z
    goto next5
    goto chkOvr
    next5: movfw lowbyte
    xorlw .6
    btfss STATUS,Z
    goto next6
    goto chkOvr
    next6: movfw lowbyte
    xorlw .7
    btfss STATUS,Z
    goto next7
    goto chkOvr
    next7: movfw lowbyte
    xorlw .8
    btfss STATUS,Z
    goto chkOvr
    goto chkOvr
    chkOvr:
    call convert
    clrf lowbyte
    clrf hibyte
    goto mainline
    chk: clrf tmp1
    retlw 0Fh
    start :
    nop
    incf tmp1,f
    movlw .45
    subwf tmp1,w
    skpc
    goto start
    clrf tmp1
    clrf TMR0
    movlw 0x06
    movwf TMR0
    bcf INTCON,T0IF
    call Wlow
    call Whigh
    btfsc INTCON,T0IF
    retlw 0x0F
    movfw TMR0
    clrf TMR0
    movwf timer
    movwf temp
    clrc
    rrf temp,f
    clrc
    rrf temp,f
    movf temp,w
    subwf timer,
    movlw 0x0c
    movwf temp
    nextBit : movfw timer
    subwf TMR0,w
    skpz
    goto nextBit
    btfss PORTB,4
    goto waitlow
    call Whigh
    setc
    goto clock
    waitlow: call Wlow
    clrc
    clock: clrf TMR0
    btfsc INTCON,T0IF
    retlw 0x00
    rlf lowbyte,F
    rlf hibyte,F
    decfsz temp,f
    goto nextBit
    movfw lowbyte
    movwf temp
    rlf temp,f
    rlf hibyte,F
    rlf temp,f
    rlf hibyte,F
    movlw 0x3f
    andwf hibyte,F
    movlw 0x3f
    andwf lowbyte,F
    retlw 0xff
    Wlow : btfsc INTCON,T0IF
    return
    btfss PORTB,4
    goto Wlow
    return
    Whigh : btfsc INTCON,T0IF
    return
    btfsc PORTB,4
    goto Whigh
    return
    ISR:
    btfsc INTCON,T0IF
    ; goto finish
    goto mainline
    btfss tmp,0
    goto one
    bcf PORTB,0
    movfw ones
    call lookup
    movwf PORTD
    btfsc blink,0
    btfsc ss,5
    bsf PORTB,0
    rlf tmp,F
    GOTO finish
    one:
    btfss tmp,1
    goto ten
    bcf PORTB,0
    movfw tens
    call lookup
    movwf PORTD
    btfsc blink,1
    btfsc ss,5
    bsf PORTB,1
    rlf tmp,F
    goto finish
    ten: btfss tmp,2
    goto hund1
    bcf PORTB,1
    movfw hunds
    call lookup
    movwf PORTD
    btfsc blink,2
    btfsc ss,5
    bsf PORTB,2
    rlf tmp,F
    goto finish
    hund1: btfss tmp,3
    goto thuds
    bcf PORTB,2
    movfw thus
    call lookup
    movwf PORTD
    btfsc blink,3
    btfsc ss,5
    bsf PORTB,3
    rlf tmp,1
    goto finish
    thuds: btfss tmp,4
    goto finish
    bcf PORTB,3
    clrf tmp
    bsf tmp,0
    goto finish
    finish:
    swapf STORE,W
    movwf STATUS
    swapf temp,F
    swapf temp,W
    bcf INTCON,T0IF
    bcf PIR1,TMR1IF
    clrf TMR1L
    clrf TMR1H
    movlw 0xf0
    movwf TMR1L
    movlw 0xee
    movwf TMR1H
    retfie
    return
    convert:
    movf tmp,0
    movwf lsb
    movf lsb,0
    movwf ones
    bcf ones,7
    bcf ones,6
    bcf ones,5
    bcf ones,4
    call ISR
    return
    delay
    movlw 0x05
    movwf rr
    back2: movlw 0xff
    movwf sp
    back decfsz sp,1
    goto back
    decfsz rr,1
    goto back2
    return
    main
    call initport
    goto mainline
    end
    hai,
    this prrogram is mainly used for interfacing the remote controller and 7sedment dspy..i used timer1 for the display and timer0 for decoding the IR code...bt nw am facing a program that i didnt got the proper out...this projct s for changing the display using remote...wl u pls help me to getting the output?????
+ Reply to Thread
  1. need little clarification about the code
    By wejos in forum Micro Controllers
    Latest: 13th April 2009, 01:21 PM
  2. Capacitor smoothing clarification
    By shaneshane1 in forum General Electronics Chat
    Latest: 22nd May 2008, 11:59 AM
  3. Clarification with IR receiver!!!
    By maheshcet in forum Robotics Chat
    Latest: 30th September 2007, 08:03 PM
  4. Clarification WV??
    By ZIGGY_DAN in forum General Electronics Chat
    Latest: 21st June 2006, 05:45 PM
  5. DMA CLarification
    By dknguyen in forum Micro Controllers
    Latest: 31st May 2006, 01:47 AM
Tags for this Thread
