Hello,
I am trying to decide on a battery switchover IC. I see that there are many options.
I am running a PIC24 micro and need to be able to retain data in the RTCC in deep sleep mode once the main battery is too low for the processor to run. I will l have a battery backup (CR2032) to run the Micro in the sleep mode low power mode.
I am wondering what you guys are using for your applications. All I need is an IC that sends an interrupt to alert the that a battery switchover has occurred.
I see that maxim has a pretty good line of ic's that run with a low backup current. It appears that I will need one with a batt-on output to let me know when the switchover has occurred.
Do you recommend other vendors for this kind of function?
