Hi guys, my PIC is connected to a buzzer, and I want to make my code in way that when I press a button the frequency of the buzzer changes.
To change that frequency, I *MUST* use interrupts.
I use cc5x compiler.
I was thinking of something like:
I´m at school now and I can´t test the code.Code:void interrupt isr() { static volatile bit saved_dtr; saved_dtr = dtr; ; // save the current status of dtr ; // disable reception of serial chars dtr = B_HIGH; if(TMR1IF) { ++tmr_aux; TMR1IF = false; PORTB.1=~PORTB.1; } dtr = saved_dtr; ; // restore the status of dtr } }
I need some directions on how to make interrupts with variable timers, and some documentation on TIMERS in the cc5x compiler.
Thanks in advance, I really need to understand that.
My finished code looks like this now
Code:void interrupt isr(void) { if ( T0IF) /* TMR0 overflow interrupt */ { CLK3=~CLK3; //The buzzer port TMR0 = 0; // For reseting Timmer 0 value T0IF = 0; /* reset Timmer 0 flag INTCON<2>*/ } } (...) main() (...) T0CON = 0b.1100.0100; TMR0 = 0; /* 256 @ 64 = 1.64ms/2 delay */ INTCON = 0xF0; // Enable interupt (...) /*the function I call if the button is pressed (Every time the button is pressed, the frequency should increase to a maximum then return to the first value)*/ void muda_p(void) { switch(T0CON) { case 0b.1100.0111: T0CON=0b.1100.0100; break; case 0b.1100.0110: T0CON=0b.1100.0111; break; case 0b.1100.0101: T0CON=0b.1100.0110; break; case 0b.1100.0100: T0CON=0b.1100.0101; break; } }
