+ Reply to Thread
Results 1 to 5 of 5
Thread: will damage occur?
  1. #1
    qtommer Newbie
    Join Date
    Jan 2009
    Posts
    92
    will damage occur?
    on behalf of a friend, I would like to ask that if a PIC microcontroller is not supplied any power but a voltage of 5V is applied to any I/O pin...will the microcontroller be damaged/burned?
  2. #2
    Number17 Newbie
    Join Date
    Jul 2009
    Location
    South Africa
    Posts
    80
    Don't know, I've done it many times by accident. Nothing happend.
    "Did you know if it weren't for Edison, we would be watching tv by a candle light" ( I can't remember who the author is )
  3. #3
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,399
    Blog Entries
    11
    I think most of us have inserted them backwards or applied power to the the wrong pins. I have yet to hear of one that was ruined with VCC.
    BCHS/3v0's Tutorials
  4. #4
    Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent
    Join Date
    Apr 2004
    Location
    Austin, Tx
    Posts
    2,733
    Potentially, yes, but unlikely.
    On all the IO pins is a diode going from the pin to the Vdd rail. It starts to forward-bias when Vio>(Vdd+0.3v). I don't know if it's actually a schottky or std silicon diode. The spec sheet says 0.3v which implies schottky, but that may be to a very low criteria for current. Anyhow, that means that putting 5v on the IO pin results in 4.7v on Vdd rail and the Vdd power pin with no power hooked up.
    The chip may start running. However, that diode is not a power diode. It was not meant to bear current. If the chip has no significant output loads (like LEDs), then the diode's rating may be ok. If you have power loads- or, get this- say the Vdd trace was broken before it reaches the regulator on the PCB, but that Vdd trace reaches other loads on the board. That Vdd trace and the other loads may be energized THROUGH the IO pin.
    The same situation can result if the ground pin is disconnected.
    If the current's high enough, then the diode can fry. How much current that diode can take is not really clear, I've asked that of chip makers before and they said "uhh... we don't specify, but 'not much' ". The 12F-18F series are tough though. I doubt you could blow them with any likely setup. There are newer 18x parts designed with a different silicon process solely for low voltage and I can't attest to those one way or the other.
    Note this may ruin your reset strategy. Say you've got a large capacitor or battery or whatever on an IO, some independent voltage source. If you remove power, the device will remain powered through that pin. Restore power and it won't undergo a reset. It's potentially possible that the voltage will drop into the "brownout" range where it scrambles the RAM states, but restoring power is not enough of a voltage gain to guarantee a reset on MCLR, resulting in a powered but nonfunctioning state.
  5. #5
    Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,612
    Blog Entries
    1
    Quote Originally Posted by qtommer View Post
    You mean you still did not supply voltage to VDD & VSS but you are giving some voltages to some other pins on the PIC?
    You must make sure the giving pins of the PIC must set as inputs.
+ Reply to Thread
  1. Damage testing
    By giftiger_wunsch in forum General Electronics Chat
    Latest: 17th August 2009, 10:13 AM
  2. I want to damage... Not repair...
    By Yun Tao in forum Repairing Consumer Electronics
    Latest: 13th April 2009, 05:38 AM
  3. LCD with Center Damage
    By ks2k in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th August 2007, 11:42 PM
  4. Solder Iron damage...
    By TKS in forum General Electronics Chat
    Latest: 24th March 2006, 12:13 AM
  5. PLC damage.
    By Wiseco in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th November 2002, 05:50 AM
Tags for this Thread
