+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 20
Thread: VGA, Composite, TFT
  1. #1
    AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent AtomSoft Excellent
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    VGA, Composite, TFT
    hey guys i need a ton of info.. i want to learn how to use the things in the title: VGA, Composite Video and TFT...
    i need links to pages with info on VSYNC / HSYNC and all that good stuff. i have to goto work now but would love as many comments as possible please...
    even if you dont understand it but have info on it i will try to learn it and show what i learned here as good as i can...
    VGA and Composite Video are the far most important... i think TFT fits into both of those anyway....
    so please any info on VGA pinouts, protocols or what ever... post your heart away....
    Thanks in advance guys ( and gals )
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,372
    TFT is really nothing to do with any of those, it's merely a particular type of LCD construction.
    What are you actually trying to do?.
  3. #3
    Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent
    Join Date
    Apr 2004
    Location
    Austin, Tx
    Posts
    2,733
    You're gonna be hard pressed to display stuff with a microcontroller on VGA. It's probably possible, people have driven NTSC video signals before (which would be "composite" video). However, the capabilities are limited. The PIC can't buffer an entire full-resolution frame, and there's not a whole lot of cycles available to calculate each pixel. But they can display text, simple graphs, or a pong-like game.
  4. #4
    Smartie Newbie
    Join Date
    Oct 2008
    Location
    Auckland, New Zealand
    Posts
    51
    just a quick google search gave me this pdf that breifly describes what your after (composite)
    http://pdfserv.maxim-ic.com/en/an/AN734.pdf
  5. #5
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    who said it was for PIC micros? i was going to use a ARM7 device to create a translator type device...
    where i can use a pic to talk to the ARM7 which in turn controls the video devices.
    now can someone post links for me? heh thanks
  6. #6
    DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent DirtyLude Excellent
    Join Date
    Aug 2003
    Location
    Toronto, Canada
    Posts
    1,241
    I think the Uzebox is one of the more popular 8bit micro projects that use composite video. It uses an interface chip to help with the video.
    They have a primer here:
    Uzebox - The ATMega Game Console
    and the hardware outline here:
    Mark Higgins
  7. #7
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    nice i might do that uzebox heh the AD725 is $9 tho heh.. expensive ic... but heh if i can use a pic then why not...
    i might just use monochrome for now tho... not sure.. .maybe if i find another solution...
  8. #8
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    i might do this first seems super simple circuit:
    VCR Pong
    and color isnt needed right now... heh i would love o just make a small terminal type computer heh.. with sd access and stuff.
  9. #9
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    would i be correct assuming that a tft doesnt have that same color issue as composite.... i can just load color and sync it?
    now im off to read more about tft and vga
  10. #10
    Join Date
    Aug 2003
    Location
    Toronto, Canada
    Posts
    1,241
    Quote Originally Posted by AtomSoft View Post
    Like Nigel mentioned. TFT is a type of LCD display, it's not an interface.
    I know the Parallax Propeller does VGA. It's one of the favorite applications for it. I've seen some fancy rendered 3d graphics with it and also some dumb terminal style applications.
    Mark Higgins
  11. #11
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    ok guys understand im new to this and also i thought it was different because:
    Composite is a analog thing where DAC is used
    TFT has a parallel interface for control which includes color which is all digital no DAC needed.... but has sync like composite and VGA
    VGA i havent looked into but i assume its like TFT but more strict with timing and power and such
  12. #12
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,372
    No, that's completely incorrect - TFT is a specific technique of manufacturing LCD panels, that's all. It's got nothing whatsoever to do with any kind of connections.
  13. #13
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    Ok I do understand that but. Wasn't talking about the actual physical difference I was talking about communication/control difference and stuff
  14. #14
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,372
    TFT doesn't have "communication/control difference and stuff", it's down to the external circuitry that interfaces to it, just as with anything else - it's that you need to interface to.
    Basically the TFT is the 'tube' if was a CRT - you don't interface to the tube, you interface to the circuitry that connects to the tube.
  15. #15
    Join Date
    Feb 2008
    Location
    Brooklyn, NY US
    Posts
    3,588
    Nigel why you killing me here heh what im trying to say is...
    Composite is tricky to do color since you need to use DAC
    TFT no DAC needed to do color because its controlled via digital interface..
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. VGA to Composite?
    By things in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th December 2008, 01:12 AM
  2. PAL Composite to VGA output i/c ?
    By rmn_tech in forum Datasheet/Parts Requests
    Latest: 28th August 2007, 09:43 AM
  3. TFT
    By hjl4 in forum General Electronics Chat
    Latest: 25th February 2006, 06:22 PM
  4. Composite Video to RGB with composite sync
    By charliez in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th April 2004, 10:39 PM
  5. PAL Composite video into VGA RGB format
    By ofer_lapid in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd March 2004, 11:03 AM
Tags for this Thread
