Old 14th November 2009, 09:29 AM   #1
Default Test different IC with Microcontroller
I am constructing an IC tester with micro-controller.
The IC i test for now is op-amp and 555 Timer, and later may be Digital Logic gate IC.
How should I synchronize all the different IC test by using micro-controller?
For example, different IC pin got different Vcc, GND, different input and so on.
What should I do to test these different IC with micro-controller?
Besides that, I am using window comparator for the testing output, the output voltage is 13-14V and 0V. What should I use to step down the voltage to 5V to fit in micro-controller? As I heard from some people may use High to Low shifter, is it ok?
conanhaha is offline
microcontroller, test
What is it? How do I test it? LM294OCT HyperionShrike Datasheet/Parts Requests 2 29th September 2009 05:47 PM
HOW TO INTERFACE A MICROCONTROLLER TO PIC17C44 microcontroller alsa7er Micro Controllers 2 4th February 2008 08:43 PM
how to interface a ADC 0809 TO MICROCONTROLLER AND THEN MICROCONTROLLER TO DECODER praneeth22 Micro Controllers 1 9th March 2007 07:20 PM
Test For Inductor Motor :No-Load and Blocked Rotor Test shermaine General Electronics Chat 7 28th March 2004 03:06 AM
