+ Reply to Thread
Results 1 to 8 of 8
Thread: Problem in Reading input in 16F72
  1. #1
    GreenBeret Newbie
    Join Date
    Oct 2009
    Posts
    22
    I am facing some problem while reading input through PORTB in 16F72 PIC.
    I wrote a simple code which shows a number between 0-9 in a seven-segment. When i press button connected to RB5, then number should increment to a different number. It works fine in Simulator. But when I tried in PIC, it shows digit 8, and have a flickering too....
    Below given is my source code written in HiTech C. Please help. I am stuck with this problem for a long perios....
    //include file
    #include <pic.h>
    //16F72 configuration word according to the features required.
    __CONFIG(0x3FB1);
    int i;
    // This macro is to make a delay after showing a digit in a segment.
    #define my_delay() for ( i = 0; i <= 20; i++ );
    void showNumber ( unsigned char *num )
    switch ( (*num) )
    case 0:
    PORTC = 0b11111100;
    PORTB = 0b00000000;
    break;
    case 1:
    PORTC = 0b00011000;
    PORTB = 0b00000000;
    break;
    case 2:
    PORTC = 0b01101100;
    PORTB = 0b00000001;
    break;
    case 3:
    PORTC = 0b00111100;
    PORTB = 0b00000001;
    break;
    case 4:
    PORTC = 0b10011000;
    PORTB = 0b00000001;
    break;
    case 5:
    PORTC = 0b10110100;
    PORTB = 0b00000001;
    break;
    case 6:
    PORTC = 0b11110100;
    PORTB = 0b00000001;
    break;
    case 7:
    PORTC = 0b00011100;
    PORTB = 0b00000000;
    break;
    case 8:
    PORTC = 0b11111100;
    PORTB = 0b00000001;
    break;
    case 9:
    PORTC = 0b10111100;
    PORTB = 0b00000001;
    break;
    case 10:
    PORTC = 0b0;
    PORTB = 0b0;
    PORTA = 0b0;
    break;
    //main function
    void main ( void )
    unsigned int noShow = 10;
    unsigned int temp = 0;
    unsigned long swith_1_Count = 0;
    unsigned int flag1 = 0;
    TRISB = 0b00100000;
    TRISA = 0x00;
    TRISC = 0x00;
    PORTC = 0;
    PORTB = 0;
    PORTA = 0;
    while ( 1 )
    if ( ( PORTB & 0b00100000 ) == 0b00100000 )
    temp = ( temp +1 ) % 10;
    PORTA = 0b00000001;
    showNumber(&temp);
    my_delay();
  2. #2
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,696
    I would guess that it is showing all numbers very fast and so it looks like an 8. Try increasing your delay lots.
    Also, use the correct labels for the config. No one knows what CONFIG(0x3FB1); does.
    GreenBeret Newbie
    Join Date
    Oct 2009
    Posts
    22
    Thanks for your reply..
    Its not showing all numbers very fast. even if i increase my delay it seems to be like that... But still according to the source code, how will it behaves like this?
  4. #4
    GreenBeret Newbie
    Join Date
    Oct 2009
    Posts
    22
    Now here one basic doubt...
    Can i use some of the pins in PORTB as Input and some of the pins in PORTB as output at the same time?...
    This problem happens when i am doing so...
    Please help
  5. #5
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,696
    Yes, you can set any combination of input/output.
    eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent eng1 Excellent
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Quote Originally Posted by GreenBeret View Post
    A difference between simulation and real circuits is that switches 'bounce' for milliseconds. Consider adding software de-bouncing in your code.
  7. #7
    GreenBeret Newbie
    Join Date
    Oct 2009
    Posts
    22
    Hi eng1, thanx for your reply. I am new to PIC. Can u brief on wat is software de-bouncing or could pls give any link abt this... ?
  8. #8
    Join Date
    Apr 2006
    Location
    Italy
    Posts
    938
    Each time a button is pressed (or released), this doesn't result in a clean transition from Vdd to GND (from GND to Vdd). Lots of transitions between the two states happen for millisenconds. Since the PIC run fast, it could read this 'noise', causing unpredictable behaviour.
    De-bouncing allows you to interpret the change in switch state correctly.
    With the most basic implementation in software, you check the switch and when its state has changed, you generate a 20 ms delay (this is considered enough for most switches); then, you check again the state of the switch (assuming that it's staying in the same state), and take actions accordingly.
    Since you have already a delay elsewhere in your code, that might work if it is increased to about 20 ms; how much delay do you have now?
    How is the switch connected? It is common to have a pull-up resistor (from RB5 to Vdd) and the switch to ground; if this is the case, you should be checking for a logic 0 at the PIC input (switch closed).
+ Reply to Thread
  1. reading an input
    By hobby_85 in forum Micro Controllers
    Latest: 18th August 2009, 03:23 AM
  2. 18F4431 - RC6 not reading the input
    By atferrari in forum Micro Controllers
    Latest: 25th May 2009, 12:41 PM
  3. problem reading diagram
    By wjyates in forum General Electronics Chat
    Latest: 24th May 2009, 08:21 PM
  4. a Problem with Reading a Circuit!!
    By Muhammad89 in forum General Electronics Chat
    Latest: 23rd August 2008, 10:34 PM
  5. PIC16F84A Reading input
    By mouse9911 in forum Micro Controllers
    Latest: 23rd May 2007, 03:15 AM
Tags for this Thread
