Yeah, this is the 'Joule-Thief' circuit, should have just posted the link, just incase you left something out or misquoted something.
After studying Transformers for hours, I found a simple circuit used for increasing power to a LED from a 1.2 to 1.5 Volt battery, because the LED you are using may require 2.0 to 3.0 Volts. This circuit uses parts that every hobbyist should have. If you dont have these parts, you may want to find a new career path
The circuit is extremely basic, using only 1 capacitor, 1 resistor, 1 LED, and 1 NPN 2222A transistor. It also requires 1.2V to 1.5V input (a AA battery or button cell). It is a very easy circuit, fun for anybody starting electronics. It is based off a inductor, or ferromagnetic core (in my case, a bolt). It MUST be magnetic, or it would do nothing except look like a coil of wire around a bolt. Mine happened to fit perfectly into a small AA battery holder, making it very compact and super sweet looking.
Parts required:
1x 0.1uf capacitor
1x 1k resistor
1x red LED
1x NPN PN2222A Transistor
1.2-1.5 Volt Battery
Some thin insulation wire (24 gauge with thin insulation wire, such as Cat5e wire)
A Bolt slightly shorter than a AA battery (if you want it to fit inside a AA battery holder)
Electricians tape
Tools Required
Soldering Iron
Wire cutter/stripper
Solder
Nippy cutters
Dremel (for cutting the hole in the case, my T13/4 LED fit perfectly snug in the case screw holder)
Pliers
STEP 1. Take the Transistor and Bend the Emitter and Collector 90 degrees to opposide sides (facing away from the Base). Take the LED and push the Leads together so they are close but not touching eachother. Then insert the Transistor between the leads (cathode to emitter and anode to collector) and push all the way through so it is almost laying on the transistor's labeled side. Solder and clip the LED leads.
STEP 2. Spread the capacitor's leads apart and put the resistor inbetween them so the resistor is in parallel with the capacitor. Make sure they are as close to eachother as possible. Clip the capacitor's leads and solder one side to the base. Make sure you have everything as compact as possible.
STEP 3. Take your bolt and some long wire and start wrapping it tightly around the bolt. Make sure it is uniform and neat, and it will look good. Have it end at the other side of the bolt (like a electromagnet nail). Take the other wire and wrap that round the wire and bolt too. End it on the opposide side you started. Solder 2 different sides together, and solder one of the remaining 2 sides to the capacitor resistor, and the other to the collector of the transistor.
The above image is the circuit when finished. I substituted the 2700pf cap with a 0.1uf cap, but you can use anything within 0.1uf to 1000pf capacitor.
finish the circuit and you are done!
Mine works excellent and it looks awesome. Hope you have luck with yours.
If you want to have fun with your circuit, change around the capacitance of the cap on it. I am going to make a solar powered flasher next and post it in the projects forum
Here is the website just in case you want to look at it
http://www.cappels.org/dproj/ledpage...il_Night_Light
NOTE: I will post pictures later today/tomorrow.
I will post the link in the edit. I can make one of these in like 2 minutes xD
So has anybody had any progress on their own Mini Volt Booster?
If so post pictures! i wana see these things!
The circuit with a real ferrite core in the inductor works much better than the circuit with a rusty nail.
I bet it would.
I used a very magnetic bolt that worked well.
I am going to pry apart some transformers and grab their magnetic magicness out of them.
I was messing around with magnetic inductor designs, and I came up with a few wierd ones that worked suprisingly. It was a peice of magnetic rector set beam that had the wire weaved through it. Works pretty good.
Take apart a few old keyboards or monitor's with longish cables, they usually have RF chokes on them, they make pretty good cores for inductors.
Moved to Chit Chat.
The Electronics Project forum is for your own fully working projects, not simply copying someone elses work.
Moderator.
Ok, so today is yesterday's tomorrow, now where are the pictures?Originally Posted by krumlink
Why not move it into the Ideas projects and review spot instead of Chit Chat?
Here are the pictures:
The LED was so bright it messed up my camera's automatic brightness adjuster. It is a 2000mcd white LED.
1523: The inductor coil in background, with circuitry in forefront.
1521: The finished product, the LED was on but was so bright I had to take out battery to make sure it diddnt damage the camera
1525: Another picture
It works really great, and it has a project spot on my website.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| i want mini projects on basic electronics | vinay2006 | General Electronics Chat | 23 | 21st September 2009, 02:00 AM |
| Voltage booster? | bananasiong | Electronic Projects Design/Ideas/Reviews | 24 | 31st December 2006, 03:51 PM |
| Does anyone here have a WIFI signal booster circuit? | moody07747 | General Electronics Chat | 19 | 3rd November 2006, 09:47 PM |
| need current booster | rhold_07 | General Electronics Chat | 2 | 21st October 2006, 02:00 PM |
| How to get 1.5v from 9v? | Axe_Murderer | General Electronics Chat | 3 | 17th November 2003, 01:35 PM |
