This much Dust ! Yeah its my PC. Im Shocked
1 2 3 4 5 Last »
Results 1 to 10 of 41
Reply to Thread
  1. #1
    pasanlaksiri
    pasanlaksiri is offline
    Default This much Dust ! Yeah its my PC. Im Shocked
    After one and half years of continuous service its looks like this. I also Shocked after I saw it. My PC is still working. I think I better install a Air purifier.
    click to enlarge
    Hi.. Visit My Projects >> pasanmicroprojects.wordpress.com
  2. #2
    Boncuk
    Boncuk is offline
    Hi Pasan,
    quite impressive, but nothing compared to the dust on the country side which cloggs up the air intake of the power supply within three months.
    Use a soft brush and a vacuum cleaner at regular intervals.
    I do not recommend using any purifiers or filters since the fans inside the PC have low total pressure and will stall (aerodynamically) if the resistance gets too high.
    A stalled fan won't cause any air movement at all. The result will be worse than a bit of dust on the fan blades - and probably overheat components like the graphic acellerator card and HDDs.
    Boncuk
    I'm not a complete idiot. Some parts are still missing.
  3. #3
    pasanlaksiri
    Thanks for the advice Mr.Boncuk
  4. #4
    Number17
    Number17 is offline
    Now I don't feel bad about my dirty pc anymore.
    "Did you know if it weren't for Edison, we would be watching tv by a candle light" ( I can't remember who the author is )
  5. #5
    pasanlaksiri
    Quote Originally Posted by Number17 View Post
    He he hee looks like I WIN from the dirty PC Contest
  6. #6
    HiTech
    HiTech is offline
    You should consider relocating the PC away from high dust sources. Possibly check your heating/cooling system in your location for dust accumulations in air handling ductwork. There are companies that will vacuum the ductwork. Just think about it, you are breathing in that same dust over time.
    I will not explain electronic theory. For those who know, no explanation is necessary. For those who do not, no explanation is possible!
  7. #7
    pasanlaksiri
    Quote Originally Posted by HiTech View Post
    PC can buy! how about my poor lung. Its also sucking dust like this. But still working
    Yes agreed Sir.
  8. #8
    smanches
    smanches is offline
    Be careful if you use a vacuum. They create a lot of static electricity and if you get to close to electronics, ZAP. They make specially grounded vacuums just for cleaning out such things.
    Better would be to blow it out as best you can, then clean up your work area.
  9. #9
    pasanlaksiri
    Ah yeah im agree with you 100%. One of my friend clean his cisco router using mini Blower. Snap ! after that it isnt booting up.
  10. #10
    birdman0_o
    birdman0_o is offline
    Yikes :O
    I don't think my desktop has EVEEEER been that bad!!!
    Mike
    My website: www.ElectroBird.net
1 2 3 4 5 Last »
Reply to Thread
  1. Shocked from a tranformer
    By goofeedad in Electronic Projects Design/Ideas/Reviews
    Latest: 13th August 2009, 03:55 PM
  2. dust sensor
    By crush24 in Electronic Projects Design/Ideas/Reviews
    Latest: 9th August 2008, 06:21 AM
  3. 1.5mbps yeah right
    By things in Electronic Projects Design/Ideas/Reviews
    Latest: 10th April 2007, 12:58 PM
  4. Static Shocked
    By Spectacular Butter in General Electronics Chat
    Latest: 25th March 2005, 07:52 PM
  5. yeah
    By TKS in Microcontrollers
    Latest: 13th May 2004, 07:42 PM
