| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
I have been working on a Science Project and several issues have come up. Among them is ferrite saturation. In the experiment I need to minimize the current needed to saturate soft ferrite. So I am looking for inexpensive methods to measure saturation. I am passing current through a coil around the soft ferrite. Intuition tells me that shape and volume are factors. I also note that a ferrite toroid is a closed magnetic circuit (no air gap) and that a rod is not a closed magnetic circuit. Thank you for weighing in on this subject. | |
Have you searched on mag amp (magnetic amplifier)? Here are a couple of hits: Method and apparatus for magnetic amplifier to reduce minimum load requirement - US Patent 6501666 Claims Magnetic amplifier having a co-axial winding - Patent 4092607 The second seems to be particularly on point. I think you will be better off with a toroid or cylinder (as described in second patent). John | |
Hi, One way is by measuring the inductance and looking for a drop for some current level. Since the material becomes magnetized when the current flows and the magnetic field gets stronger as the current increases until saturation, you might use a hall effect sensor to detect the field near one of the poles and as you apply more and more current the field will keep increasing until it nears saturation and then the field will either stop increasing or start to increase much less for the same increase in current. Some of the linear hall effect sensors are not that expensive. You'll also need a small power supply to power it. There is a problem however when trying to saturate a material that does not have a closed magnetic path, and that is that the reluctance of the material is very low but the reluctance of the air is not, and the air becomes part of the magnetic path. The combination of the magnetic material and the air means the material may look like it takes a huge huge current to saturate because the magnetic properties of the entire construction (air and material) appear like a very linear choke because of the linearizing effect of the air. In fact, air gaps are often introduced into power chokes for that very reason: to make saturating harder to do (require more current) and with a huge air gap such as that which would be the same length as the material itself, i would think it would take a huge current to see anything like saturation. On the other hand, with a material that can fold back onto itself such as a piece of material that forms a closed loop, that may saturate quite easily as most of the field would be concentrated inside the material. I guess this also says how to minimize the current needed to saturate the material: construct it into a closed loop with as little air gap(s) as possible. This reminds me of an interesting experiment i did once... Take a regular toroid core and wrap some turns of wire around it, then measure the inductance and the dc current that it takes to saturate it or at least start to saturate it. Take the turns of wire off,wrap the core in a clean rag, put that into a vise, tighten slowly until the core cracks. Take the pieces out trying not to loose any, then glue it back together with super glue. Put the same number of turns of wire back on. Measure the inductance again and the saturation current, and note that the inductance goes down and the current needed to enter saturation goes up. The reason being that the cracks filled with glue now act as gaps, and the way most cores break like this there ends up being four gaps, and even that thin glue layer four times over creates air gaps that are effective enough to dramatically change the characteristic of the core. You can also glue two of the four pieces back together and then vary the gap by placing the two halves close together, which means two gaps will be larger. Perhaps some hot glue would help keep them together just to make the measurements. Last edited by MrAl; 4th October 2009 at 01:59 PM. | |
One way is to measure the small signal inductance of a coil that has a variable D.C. bias applied. The tricky part is injecting the D.C. current without impacting the small signal inductance measurement. The brut force way is to put chokes to the coil inductance to inject the d.c. current on the coil to be measured. You have to know the characteristics of the chokes, primarily that they are not saturating and maintain high impedance relative to the measurement inductance. A more predictable and simpler way is to put coil in the collector (or drain) of a common emitter (or common source) amplifier that you can change the D.C. bias on. The amplifer has lots of A.C. feedback via emitter (source) degeneration resistor to keep the A.C. transfer gain constant over changes in the device d.c. bias. You can parallel resonate the collector tank with a known value capacitor and detect the frequency of peaking A.C. swing, keeping it just large enough to detect by adjusting the A.C. signal level on input of amplifier. Another way, particularly useful for switching power supply coils is to actually measure the V= L di/dt effect. This is done by using a variable pulse width function generator to drive a MOSFET. Drain goes to coil and a scope is placed across a low valued resistor in series with coil at Vcc end of coil to measure the current ramp. The current ramp will start out linear and will start to increase in rate as saturation is getting close. A Schottky diode to a resistor is used to discharge the coil between pulses. You need to start out with short pulses and work your way up to keep things from getting out of control otherwise you will trash a MOSFET. Heat sink on MOSFET as necessary for its Rs and current. | |
| ferrite, saturating |
| Ferrite Cores | Njguy | General Electronics Chat | 14 | 16th September 2009 12:58 AM |
| HV ferrite transformer | kamalifard | Electronic Projects Design/Ideas/Reviews | 2 | 2nd August 2009 01:47 PM |
| Ferrite Bead not available?:( | Wond3rboy | Micro Controllers | 2 | 4th May 2009 06:12 AM |
| What is this part? Is it ferrite? | AlainB | General Electronics Chat | 6 | 11th March 2009 01:42 AM |
| Saturating a BJT | afesheir | General Electronics Chat | 9 | 18th July 2008 03:46 PM |
