| Math and Physics Discuss the complex nature of mathmatics and physics relating to electronic circuitry. |
Hey Everyone, I've seen this "Angular Frequency" expressed as "ω", and I was wondering what it meant. I know that frequency can be expressed as a sine wave and then a circle in degrees so would this angular frequency calculate a certain angle of a true frequency? What is the purpose of angular frequency and how do you use it? I've also seen a lot of other "angular" type things such as "angular velocity." Thanks! | |
Angular frequency is the same thing as Hertz in a form more suited for trigonometry. 1 Hertz is one cycle per second. In trig there are 2*pi radians (or 360 degrees) in a single rotation around a circle (or a cycle if you will). It is more suited to trignometry than both Hz and degrees because radians is what trigonometry is based on. Hz and degrees are just easier for humans to visualize. So 1Hz is the same as the angular frequency of 2*pi radians per second. Angular frequency = Frequency * 2*pi
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 2nd October 2009 at 09:03 PM. | |
| | #3 | |
__________________ She 'tis not there. Last edited by jasonbe; 4th October 2009 at 09:57 PM. | ||
| angular, frequency |
| Angular rate sensor vs Gyroscope | danielsmusic | Electronic Projects Design/Ideas/Reviews | 20 | 22nd October 2009 07:14 PM |
| Brainstorming a 6 motor h bridge w/pwm and angular feed-back | urthlight | Micro Controllers | 9 | 26th May 2009 03:58 AM |
| angular displacement sensors | gastonanthony | General Electronics Chat | 9 | 14th June 2005 03:05 PM |
| controlling angular displacement... | AMPdeck | Robotics Chat | 4 | 21st January 2005 12:57 AM |
| Angular Control of Stepper Motor by 8051 | cyw1984 | General Electronics Chat | 3 | 10th October 2004 01:43 PM |
